Question about Lexmark Z611 InkJet Photo Printer
Installing without the disk
When my best friend was printing on her printer, it was printing in purple. Now, I just uninstalled it and I thought that she had the disk. How do I re install it without the disk and how come when she goes to print, it prints in purple and not what is on the screen?
  • Nicole Clemmons Mar 01, 2007
    This was great. It helped a lot. Now she has more than just one color in the printing process. She now can print without having everything in purple. Thanks again.
    Sorry, it is still printing with a lot of purple on it. How do I run the printers nozzle cleaning utility?
  • 624 Answers
Gabbyone, Here is the page to download drivers for your printer. Just click on the link for the appropriate operating system you need: http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:525:0:0&emeaframe=&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&target=http://downloads.lexmark.com/cgi-perl/downloads.cgi&&req=::::: As far as why is it printing purple it could be several reasons but some common ones are; you?ve run out of a particular ink color, one of your ink jets could be clogged or damaged, your cartridge was refilled wrong and on occasionally a software driver gets messed up. Reinstall your printer, do a test and if it still prints purple try running your printers nozzle cleaning utility. If that fails post another questions and give us some history, how long has it been since you?ve printed, are you using new Lexmark or refilled cartridges and any other pertinent information.
Posted on Mar 01, 2007
  • tomj23 Mar 01, 2007
    When you installed the driver it should have installed a program called the Lexmark Solution Center. The utility can be accessed from there. Note a couple of things about the nozzle cleaning utility, it uses a lot of ink and it may take a couple of tries to do the trick. Bottom line is that each time you run the utility it should get better each time.
All my photos are printing with purple/pink undertones. Can't figure out how to fix this? All ink cartridges are full and I have cleaned all the nozzles. Is there any way to factory reset the settings...
You should be able to cure this in the driver setup. You will find hue and saturation settings there.
A reset of the printer will make no difference. If your nozzles are all good and clear and u are using genuine ink tanks then it will just be the driver. You could uninstall the driver and download the appropriate driver from the canon site. When i say uninstall I mean uninstall and not delete. Also do a restart before installing the new driver with the usb cable disconnected.
Also the program you are printing with can make a difference. Photoshop is usually the best.
Calibrate your monitor as well.
Good luck
Jun 19, 2011 | Canon I900D InkJet Photo Printer
I tried to use my printer (hp 2115) after installing many other programmes and not using the printer for a while. It prints from excel not word, when it does print from word it only prints one line of the...
► do a L4 uninstallation i.e. by putting the disk for printer.... explore and go to Util and then CCC ... then select uninstallL4
► restart the comp
► download the driivers from Hp.com and then install it
► restart the comp
BEST OF LUCK
Feb 10, 2010 | HP PSC 2210 All-In-One InkJet Printer
Prints purple instead of black on photos only
My Canon printer has TWO slots for black ink cartridges. I assumed one was extra and didn't replace it when I ran out. Text printed just fine with only one installed, but my photos were printing with purple instead of black. I looked into it, and the two cartridges are different: one holds dye-based ink, the other has pigment based. Photos must require both kinds. If your printer is the same as mine, use both!
Jul 23, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Seems I can send faxes but have problems with receiving.
That's a driver problem. Uninstall the driver first before reinstalling it.
Apr 09, 2017 | NexxTech NSFTMD1
'Fatal communication error' - cannot print
My first recommendation is to carry a printer self test. Use the Menu on the front panel to do this ok. If both printers succeed in self test then the problem is reduced. Uninstall the previous drivers for these printers. Connect the printer data cable(USB) to the pc and check for communication. that is, whether or not it is detected by the pc's OS. This should be done one after the other on different ports. If the two printers are attached to same pc, I recommend you use a combination of USB and Parallel printer cables. If communication is successful then detach both cables from the pc. Install the drivers for the USB printer without attaching it to the pc. Then attach when prompted. That way, the printer is guaranteed. For the printer on the parallel port, connect it and install the drivers while attached to the pc. If nothing happens still, you should consider leaving only a printer on the pc. Good luck
May 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
Laserjet 1020 with mac osx
Ok, you may want to consider re-installing the printer driver or in any case download updated printer drivers. Just don't forget to reboot after installing:)
Oct 16, 2008 | HP LaserJet 1020 Printer
Error light on
Could be drum unit (imaging unit) at end of life
Sep 04, 2008 | Lexmark E120n Laser Printer
Printer Copies in Green Only
Uninstall and reinstall printer software if you still have your disk...
clean each cartridge and goto the properties on your printer settings and be sure they are set to default.. this should take care of the problem.. let me know how it goes..
thanks...d
Feb 28, 2008 | Office Equipment & Supplies
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:525:0:0&searchLang=en&os_group=WinXP&target= http://www.lexmark.com/lexmark/channel/frameset/home_no_nav/0,6951,204816596_659668502_0_en,00.html The top site is for the printer drivers the second site is the users manual. Let me know what happens. Good Luck, Tim
Mar 01, 2007 | Lexmark Z611 InkJet Photo Printer
Open Questions:
See all Lexmark Z611 InkJet Photo Printer Questions
Lexmark Z611 InkJet Photo Printer Logo
112 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
