Question about Nokia N73 Cellular Phone
Retention of time and date
Each and every time I switch on my mobile, I have to input the correct time and date, this surely cannot be correct! Any advice would be greatly appreciated and also prevent me from flushing the damn thing down the you know what!
  • shiakallisk Dec 11, 2008
    every time i swich on my phone asks for time and date
  • 337 Answers
How long have you been using your phone? it might be the battery inside your phone is already weak, there is a small battery (the same that is using in a watch) installed inside the phone you should change it,
Posted on Dec 22, 2008
Commonwealth login netbank
Check that the Date and time on your PC and phone are correct and the same (as well as the time zone). The codes are generated as a function of time.
May 26, 2014 | Computers & Internet
TM 6460-6752 Series loses its time and date when shut down
The coin cell battery on the motherboard is depleted. Get the number off it and get another one to replace it . You may have to go into the bios if it won't boot correctly to input the correct time and date.
May 06, 2014 | Computers & Internet
I have somehow changed the language into Japanese from English whilst trying to change the date. Please tell me how to change it back and also to put in the correct date.
On mine its ..
switch on .(make sure its not recording)
Record start/stop on mine is beside to on/off button
menu button twice (second menu)
on this option screen its the second option down - press record to select.
from there you can select your language.
One you've done that its the same input method for date , you just select the date and time options.
Jan 22, 2014 | HD DVR Hd Portable Dvr With 2.5 Tft Lcd...
Date and time wrong on start up
This indicates the BIOS battery is flat and therefore cannot store the correct date and time in the BIOS. You need to install a new BIOS battery and then go into the BIOS setup to set the Date & Time.
Nov 14, 2012 | Advent Clearance 5411 Laptop...
LawMate PV-AC30 manual
To set the time / date stamp you'll need your remote control and you'll need to hook it to a TV with AV inputs. Be sure to correctly select the AV input the camera is plugged into. This is the most overlooked step that causes a lot of users frustration.
I've attached a YouTube video on how to accomplish the time/date setting.
Aug 28, 2012 | LawMate PV-AC30 Wall AC Adaptor DVR...
Hello sir When I install gnubox in my mobile then i get error certificate expired
if you have s60 version mobile first download freesigner form install it in your mobile
then open freesigner add--->select .sisx or sis setup file of your software where its located--->self sign-->menu--->go!. after this a second setup file will be generated with yourfilename_signed.sis.
now install using this file.your problem solved
Apr 10, 2011 | Computers & Internet
Time and date on messages and cellphone are not the same
For SMS or MMS the received date and time is based on the mobile operator not with your mobile phone. try to use friend's other SIM card(Mobile network operator should be different than the one currently you have) and check.
May 27, 2009 | Sony Ericsson G700 Unlocked GSM Smartphone...
Replace front brake pad 2003 toyota 4 runner
Diagram is unnecessry.
Pull both front wheels
Work one at a time leaving the other for reference
Find the retention spring ... its a paperclip thickness wire spring... dislodge center retention loop and undo from both ends which engage brake pad retention rods.
Pull the rods out
Pull the old pads out... laying everything on the ground
Use scrap wooden wedges to pry between the rotor and the caliper ...inside and out until the calipers are fully withdrawn. Use the new pads to measure if they are far enough back.
Note... the brake fluid will have dropped in the master cylinder over many months of wear... do not fill it. When the calipers are pushed back they will fill the reservoir again... one wheel at a time.
Be sure to identify the correct pad based on what you took out and what is on the other side (if you screwed up the layout)
Make sure to take the old antisqueek backing plate from the old pad and place it on the new pad. They don't use lubricant on these anymore.
Replace the pads... the retention rods... then the retention spring
Do the other side
Then progressively step on the brake peddle until full tension is felt
Check the master cylinder reservoir... probably needs no additional fluid.
New pads will register in existing ridges in each disc in no time at all.
You should check the discs to see if they need to be replaced during this operation...using some calipers
Mar 19, 2009 | 2003 Toyota 4Runner
Abit bd7m - no video, no keyboard, no mouse
Why does the BD7 board fail to POST with sirens? Is the mainboard faulty? A:
  1. If the CPU retention unit or heat sink wasn't installed correctly, the bad heat dissipation will cause P4 CPU over temperature and fail to boot up.
  2. Please check the black CPU retention is fully inserted into the holes in the mainboard. Below picture illustrates a bad installation- there is a gap between retention unit and mainboard.
  3. Please make sure the white nails were fully inserted and can prevent CPU retention unit from loosen.
  4. Double check the back side of mainboard. If the feet of CPU retention unit and white nails were correctly installed?
Mar 04, 2008 | Abit BD7m Motherboard
Date and time reset at power-on
Canon point and shoot cameras have an internal backup battery (a very small watch battery sized cell). Look under your battery door - do you see a small tab that has "CR1220" or something like that marked on it? If so - this is your backup cell. Just replace it and you will be good to go. If you do not see this, then the backup battery is buried deep inside the camera and would require full disassembly to replace. David Millier Advance Camera Repair
Feb 18, 2007 | Canon PowerShot A510 Digital Camera
Nokia N73 Cellular Phone Logo
73 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
