How vb.net windowapplication form can stablish connection with ms access database and how data in database can be matched with data in textbox on the form on click event of button.
    President:
  • 2,110 Answers
Http://www.startvbdotnet.com/ado/Simplebinding.aspx
pls go through this link..it might solve ur query..
Posted on Dec 10, 2008
I want to learn that how can i connect my HTML page with my DATABASE created in MS ACCESS so that i can fill my table in HTML page directly-
1. You can use Pages option in MS Access. The page in MS Access is the web page in MS Access which allows you to access database in MS Access database.
2. You can use MS Office Front Page application and use the Form builder and connect your database in that.
3. You can also use Google Apps Business Solution for this however the database will not remain in MS Access but will remain in Docs online.
4. You can use .net application developer for this as well but needs expertise in that.
Mar 09, 2010 | Microsoft Office Standard for PC
How to make the library managment project with VB.Net & using MS Access as for database.& please help me out what code should I use for making that project?
firstly you have to create a database and in that you have to create tables as per your requirement.
secondly, create forms in vb and connect the database, as per your requrement. it is not possible to give all the codes. use some e-books.
Nov 19, 2009 | Computers & Internet
Retrieving acess data which is password protected thru VB
You will need to use a connection string. But - before you can configure the string correctly, I'd need to know how the data is stored (Access, SQL, ODBC, etc). You can find examples online. Just know that you are looking for "Connection String." Here's two examples:
1. For MS Access (Jet files):
' Set up the connection string.
m_strConn = "Provider=Microsoft.Jet.OLEDB.4.0;" & _
"Data Source=" & strDestDBPath & ";" & _
"Jet OLEDB:Engine Type=5" ' NOTE: Use Type=5 for Jet 4.x.
2. For SQL database:
g_strADOConn = "Provider=SQLOLEDB;" & _
"Data Source=SERVER_NAME;" & _
"Initial Catalog=DATABASE_NAME;" & _
"User ID=mssql_userid;" & _
"Password=mssql_password;"
Apr 22, 2009 | Microsoft Visual Basic 6.0 for PC
What is the compatible database for visual basic 6.0?
Microsoft Access uses the Jet Engine. In VB 6, you can create a data connection using ODBC or OLE DB. Here is an example of OLE DB:
"Provider=Microsoft.Jet.OLEDB.4.0;Data Source=C:\YourAccessDB.mdb;User Id=;Password=;" Good luck
Mar 09, 2009 | Microsoft Press MS Access 2000 and Visual...
How to link database to vb 6.0
make sure that you have ODBC drivers that match the database you want to get data from. Often there is security involved and the correct ODBC driver will prompt you for security information to get at the desired data and handle the necessary protocols to exchange data
Jan 07, 2009 | Computers & Internet
Asp.Net
about the dynamic forms/pages, u can use sessions in asp.net C#, theyre very easy to use and try using commands like server.transfer and respond.redirect in ur code. for the connectivity thigee u asked, :) m sorry my friend u cant get it like a pan cake, u gotta study w3schools odbc connectivity in asp.net tag for this :P
Dec 21, 2008 | Microsoft ASP NET WEB MATRIX (583797)
How to use passwd character in a table in ms-access 2003
When you create table where you want to store passwords, go to Edit Table, then select a field where the password will be stored, go to Input Mask field in Properties and type Password in that field. That will set up the field needed for storing passwords.
Aug 18, 2008 | Microsoft Office Access 2003 (077-02871)...
Accessing data
Dear reader
Place an ADODC control on your form in VB.
In the properties of the ADODC control goto the TAB General.
click "Use Connection String. With the button Build you can point to your database.
Thats it.
With the following code you can connect to db:
With Adodc
.RecordSource = "SELECT * From YOURTABLE"
.Refresh
End With
Now you have the table in the adodc control.
you can now do this:
Label1.caption = Adodc.Recordset!YOURFIELD
YOURTABLE = the name of your table in the database.
YOURFIELD = the fieldname in YOURTABLE you want to show.
Kind regards Fred.
Jul 04, 2008 | Microsoft Office Access 2003 (077-02871)...
MS Access and ASP.net application
You probably need to be inserting the value of a text object (ie, a String) , not the object itself. In VB.NET, a String object is an actual, not unlike a Java String object. In "classic" VB, a String object isn't really handled by the interpreter as an object in the C# / Java sense, so it can be referred to directly without resolving the value via a method call. So attempting to insert an object reference into a database field from C# code will probably not work unless the database knows to call toSting() on the object, which I am 99.99999% sure it cannot (depends on the database-- in this case Access, and more particularly, what version you are using, and if there is any .NET framework interoperability).
Calling myString.toString() though returns a String object in C#, so using that is likely not going to work. What you may need to do is return a character array using the 'chars' and 'length' properties of the C# String object.
Finally, after all this, your problem could be a lot simpler: the value(s) you are trying to insert may not be right for the field-- check the length of the values being inserted, etc. Use .trim() to eliminate leading and trailing whitespace, for example. If you post your INSERT statement and an example of the data you are using, I may be able to tell you more. Also, you are in ASP.NET and data transfer from web containers to Access databases is notoriously bedeviled work.
Mar 07, 2008 | Computers & Internet
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
