Televison & Video Logo
Anonymous Posted on Dec 10, 2008
Convergence adjustment As a beginer in repairing Projector TV i have no idea on how to adjust the convergence. it looks like double the picture.
jason
Level 3:
  • Master 905 Answers
  • Posted on Dec 10, 2008
jason
Master
Level 3:
Answers
905
Questions
8
Helped
320936
Points
2511
You will probably have to replace this http://www.nteinc.com/specs/7100to7199/pdf/nte7178_81.pdf
as well as checking for bad resistors
because the color is not aligned and probably just happened it may be just a resistor unless there is a bow in it then the IC's will have to be replaced also
Anonymous
Level 3:
President:
  • Master 2,110 Answers
Anonymous
Master
Level 3:
President:
Answers
2110
Questions
Helped
611961
Points
6294
I just got a philips 46" projector TV from a
You need to replace the convergence ics. Repair is usually pretty reasonable. Hope this helps.
Toshiba big screen Model TZ50V60 Convergence Issue-Chips Replaced
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
2answers
Red color outline and double vision
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Your TV2_bing.gif may have one or more of the following symptoms....
1helpful
Bowed screen left side top to bottom probably 1 1/2" deflection... need to know how to adjust the projector lenses
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
I HAVE DOUBLE COLORS ON SCREEN THE RED AND THE BLEU AT ONCE ON AND I DON'T KNOW HOW TO ADJUST .
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
*Screen Looks 3-D
*Colors wont align
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Double picture on left side with red projector on Hitachi 55UX58B
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Distortion and double imaging
Projection sets have two very common problems.
*Screen Looks 3-D
*Colors wont align
Double picture
*Screen Looks 3-D
*Colors wont align
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
6helpful
7answers
Distorted Color and geometry of Picture
I've posted this solution several times but here goes. Try setting up the convergence through the menu by accessing the convergence setup menu. If this fails to work you have a bad digital convergence box and need a tech to replace it. About $60 to $100 fix.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
