Question about Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop
My laptop doesn't shut down after i press the key for
    President:
  • 2,110 Answers
Try to restore system back to previous date...
there might be some registry problem..
Posted on Dec 10, 2008
My lap top shut down and would not restart. I called the company and they said I needed to reinstall programs. They sent me two discs, but I cand get them to load.
Step 1:
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key this will vary depending on your computer and operating system Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
Mar 15, 2013 | Dell inspiron 14r-n4110 laptop intel
My monitor ia not coming on. How can I get the monitor to work?
How long does it take to shut down? Common causes:
1 You may have an external monitor selected. Hold the function key (might labeled Fn, it's usually near the left shift key) and press F8. If the screen doesn't come back press it again 'cause there are three options (panel, external and both)
2 The screen might be dead. Plug an external monitor in and see if you get a picture. If so repeat step one and check your video settings.
3 The laptop MB might be faulty. No real way for you to test this.
Aug 28, 2012 | Acer Aspire 5100 Notebook
How to run safe mode
When you start the Computer
Press "F8" key repeatedly after the IBM logo appears, but before the operating system logo appears.
then when menu appears press Down key and Select Safe Mode & Press Enter
If the "F8" key doesn't work, restart the computer and try pressing the "F11" key repeatedly.
Aug 23, 2012 | IBM Computers & Internet
Laptop is a sleep
press any key to wake it up, if that doesn't work for some reason press the power button once. it should wake up. if all else fails hold the power button down for 5 seconds until it shuts off and reboot it.
May 05, 2012 | IBM ThinkPad T30 2366 Notebook
Toshiba satellite C655 laptop has black screen with blinking cursor. It did complete some Windows updates. I was on the Internet then my laptop just shut down and it in this black screen with blinking...
Turn the computer off all of the way by holding in the power button until it shuts off.
Turn it back on and immediately start tapping the F8 key. It should bring you to a menu that has an option for going to "Last Known Good Configuration". Choose that option and see if it boots up.
If pressing F8 doesn't bring you to the menu - you may need to run diagnostics on the computer. To get to the diagnostics, attempt to boot to the Boot Menu by pressing F11 or F12 at the boot screen and see if it gives you the option to run diagnostics.
Nov 15, 2011 | Toshiba Computers & Internet
How did i boot my toshiba satlilit pro
Here is a solution for your problem.Please follow the below steps to boot your laptop.
1. First of all insert the CD from which you want to boot your laptop. 2. Shut down your system. 3. Press the power and then start it again and press the "C" key to boot from the CD.
If this method doesn't work, you can try pressing F2 or F12 at startup and selecting the CD drive from the list of options.
If neither method works, hold the "Esc" key while restarting the computer and press F1 when prompted to access the BIOS. From there, you can change the boot order so that the computer attempts to boot from the CD before any other devices.
This will surely help you out.
Thanks you. Have a good day.
Aug 10, 2011 | Toshiba Satellite A60 Notebook
Canon ir2870 error code e000002
these means that in fixing assy is low temperature. It can be that you only need to clear the error trough service mode, or you need to change thermistor.
To clear the error:
enter the service mode:
1) Press the asterisk key " * " on the control panel
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " " on the control panel.
then choose COPIER, then FUNCTION, then CLEAR and choose ERR. Shut down and back ON the copier.
If these doesn't helps, replace thermistor which is inside of fixing film ceramics.
Jun 12, 2011 | Canon Office Equipment & Supplies
I have now Win XP (SP2) on my HP ProBook 6555b. It dont wona shut down!
Hold down the Ctrl key and the Alt key then press the Del key. This will then bring up the Task Manager. Then click on Shut Down then click Turn Off.
This will then shut down your laptop properly.
May 25, 2011 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Power led remains lit at all times with battery or power plugged in. Fans turn on when powered on but no system response. Was able to get system to power on by compressing laptop above and below DVD with a...
ok you have laptop. Look for a key called "Fn" it should be around the ctrl or alt key on your keyboard. Try pressing that. After trying to turn it on and it wont. press the Fn key. The last time you were able to use the laptop how did you shut it down? Did you tell it by going threw the menu when logged on. Or just pressed the button? Or did you tell it to shut down then you closed the screen/lid before it actually shut down? Laptops will go into stand by after you tell it to shut down if you dont wait til it shuts down, before shutting the lid. ALso depending on the laptop company you have Trying to figure out which one it is. They have program installed with your system. And depending on how it's set up, will greatly effect how or even IF your laptop will shut down right.
Oct 10, 2009 | Gateway M675 Notebook
My monitor on my computer is shoing upside down
press Ctrl-Alt-Up - right side up 0n y0ur keyb0ard.
(If that doesn’t work, try Ctrl-Shift-R)
Jan 15, 2009 | Computers & Internet
Lenovo 3000 N100 0768 - Pentium Dual Core T2060 1.6 GHz - 15.4in. TFT PC Desktop Logo
35 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
