Question about De Dietrich 18 in. VZ9456 Built-In Dishwasher
No hot water
Hi there, washing machine is doing the full wash cycle but with cold water, can you help? thank you. paolo
  • Anonymous Mar 25, 2014
    The water isn't getting hot but the wash does a full cycle
    Problem Solver:
  • 6 Answers
Some things to check. Is the hot water valve turned on? Is the hot water hose strainer and machine inlet strainer clear of clogs? If neither of those is the problem, then it has to be either the water temperature selector or the hot water solenoid valve. Depends on how handy you are if you want to tackle troubleshooting and possibly replacing ether of these.
Posted on Mar 01, 2007
Aquarius WML520 Cold Wash not working
Washing machines start a cold wash cycle with hot water to dissolve detergent.
May 19, 2016 | Washing Machines
The water no longer gets cold . What do I check ? Thanks !!
On a washing machine?
You have a hot fill inlet, you have a cold fill inlet. The controller dictates how much hot water and cold water to get the right temperature for the wash you have chosen. This is tested by the thermostat in base of the drum. The heater then warms the water to the correct temperature for the full wash.
Some washers are cold fill only and the heater in the washing machine does all the work. The wash cycles take a lot longer.
If you are in fact talking about a water cooler not getting cold, check the air filters and for dust on the compressor fins.
Jan 13, 2016 | Washing Machines
Hi. I've just been loaned a Whirlpool awm 5125/4 washing machine (while mines gone for repair), but it has on the back of the machine, a hot inlet and a cold inlet. My machine only requires a cold water...
Your machine can be connected for cold fill only but, you will need to connect a "Y-Piece" for it to work:
The tail of the "Y" attaches to the cold water valve on your pipework. You then attach both hot and cold water hoses to the branches of the "Y" and connect both hot and cold water hoses to your washing machine. The wash cycles will take longer when connected this way as the machine has to heat the water internally. It will also be less energy effecient.
Please post back if you need further assistance.
Regards,
BElectric
Dec 11, 2010 | Whirlpool AWM5125/1 Front Load Washer
When going to wash with my GW11 it stops during the was cycle and the cold and hot water light blink and the machine beeps
Hi just read your posting.Now, when the hot and cold lights flash at the same time it means that you are not getting enough or no hot or cold water.Remove the cold and hot inlet hoses from the machine end and put the ends into a bucket.Now turn the taps on to see if you have water coming out the hot and cold hose and if the water pressure is adequate.Try a cold fill on the wash cycle and see how it goes.please reply and let me know if there is water coming out of the hoses at a good pressure and also what water temp do you select on the wash cycle.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washing machine cycle far too long
Hi Fiona.I believe the cold valve is probably faulty & is not flowing fast Its probably dribbling water in?taking forever to fill.the machine should be giving up & beeping at you if thats the case.If you have a faulty cold valve then switching to warm won't help as the hot valve will close itself off to compensate for the lack of cold water..afterall you have told the machine to fill with warm,,if it cant make warm water because of a faulty cold valve then the hot will decrease to a point where its not letting any water thru..try a hot only wash..if it goes thru wash cycle ok then good chance its cold valve problem.wow i hope that helped.
May 30, 2010 | Fisher and Paykel Washing Machines
My washing machine (dwd-wd32ws) only uses hot water to wash!
hi,
try and switch your hot and cold water hoses around the other way. it should start the cycle with hot and rinse cold.. If it still does it you may have to have it serviced..
jm
Nov 27, 2009 | Daewoo Washing Machines
Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
May 13, 2009 | Whirlpool AWM5125/1 Front Load Washer
Cold water Washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Apr 07, 2009 | LG WM-1832C Front Load Washer
Magtag Washing Machine Can't use cold water only cycle
Stranger things have happened.
Glad it is working for you.
Apr 02, 2009 | Maytag Washing Machines
De Dietrich 18 in. VZ9456 Built-In Dishwasher Logo
183 people viewed this question
Top De Dietrich Dishwashers Experts
Steve Allison
Steve Allison
ray gallant
Are you a De Dietrich Dishwasher Expert? Answer questions, earn points and help others
