If printing is blurry even when the ink roller is in the proper position, replace the roller. Ink roller: Type EA-732R
WARNING APPLYING INK TO WORN INK ROLLER OR USE OF UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER.
1) Turn the power off. 2) Remove the printer cover. (Fig. 1) 3) Remove the ink roller by turning it counterclockwise and pulling it upward. (Fig. 2) 4) Install the new ink roller and press it in the correct position. Make sure that the ink roller is securely in place. (Fig. 3) 5) Put back the printer cover.
Ink roller: Type EA-772R WARNING: APPLYING INK TO WORN INK ROLLER OR USE OF UNAPPROVED INK ROLLER MAY CAUSE SERIOUS DAMAGE TO PRINTER. 1) Set the power switch to OFF. 2) Remove the printer cover. (Fig. 1) 3) Hold the top of the ink roller and remove the roller by pulling it toward you and then upward. (Fig. 2) 4) Install the new ink roller in the correct position. Make sure that the roller is securely in place. (Fig. 3) 5) Put back the printer cover.
The new ink roller types are EA-781R-BK (Black) and, EA-781R-RD (Red).
To change the ink rollers.
1). Set the power switch to off.
2). Remove the printer cover. The little paper guard or, flap on top.
3). Remove ink rollers by turning each one counterclockwise and, pulling upwards. With the calculator facing you. Red is on the left and, black is on the right.
4). Install the new ink rollers in there correct position's. Simply press them in one at a time and, make sure they are secure.
5).Put the print cover back on.
If calculator prints blurry, the rollers may not be not secure. If you have any questions about this calculator simply post a comment and, I'll respond quickly.
pulling it upward.
The instructions in the manual are (1) remove the printer cover by pressing down on the (triangle) mark. (2) Lift up the old ink roller and remove it (3) Insert the new ink roller by pressing it gently into position (Use Canon Ink Roller CP-16) (4) replace the printer cover. My roller has the term "Pull Up" on the left side of the roller.
I think on this one it takes a small ink roller that snaps in palce in the upper left of the printwheels. I think the ink rolls are purple on this model amd I right???
Unless the ink roller that you installed was dried out, usually, the replacement rollers just snap in place and are good to go. Check to make sure there is ink on the roller by either pulling the ink roller out again, and touching it with your finger. If no ink on your finger, you might have received a dried out replacement roller. Also the roller should be somewhat like a sponge. If you push against the sponge and it doesnt spring back and it stays indented, then the roller might also be bad. If you happen to have a bottle of ink for an ink pad, you can try soaking the roller with the ink so the roller is wet, (but not DRIPPING WET) and try it again in the calculator. IF you get some image for a little while, then I would say try a new fresh ink roller.
Hope this helps.
Hi , clean both end of roller clean rug or cotton tip , this may happen during cleaning time some ink expose both end of roller sometime in piece of paper .during the cartridge in the middlle pullout the power cord stop cartridge and push cartidge down and lock.
