Question about JBL PP-600II System
Dvd player says no disk.
When i put a dvd or cd in it says its reading the disk,then it says no disk.can you help? thanks.
    President:
  • 3,130 Answers
Cleaning the LENS could very well be your problem.. See if the disc spins, if it does not, the spindle motor is defective or the laser assy. is bad. If this is the case, most likely the unit will not be worth repairing. Good Luck
Posted on Mar 16, 2007
    New Friend:
  • 50 Answers
CLEAN THE LENCE IT WILL SOLVE YOUR PROBLEM
Posted on Mar 15, 2007
My dvd combi is saying invalid disc and sounds like its spinning but then makes a clicking noise
Make sure the disk you put in the player is compatible with what is in the manual. Don't try to use disks you burned yourself when the manual does not say it is compatible with CD R or DVD R + or -
And when it is compatible with CD / DVD R, put the files on the disk in a format the player can read. Don't try to play MP4 disks, because almost no MP4 format is compatible with w DVD player.
Jan 14, 2015 | Televison & Video
Polaroid portable dvd player won't recognize disk
You have put a dirty CD in and now the laser lenses is dirty and cant read the finer details of a DVD.It needs a clean.
Dec 06, 2013 | Polaroid Televison & Video
It's not reading cd, or DVD
Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
Jan 03, 2013 | Televison & Video
When i put a disk in, it says disk error
Your best bet is to clean the lens with a commercial lens cleaner for DVD/CD. If that doesn't work the problem could get more expensive to repair, and since DVD players are cheaper to buy (some) than repair, you might want to consider that as an option.
Jan 31, 2010 | Electronics - Others
Please Help :S
try clean the lens using only cotton buds no pressure just smoothly wipe, if it would turn ok then great... but still disame, try put vcd cd/ or cd audio only if one click it reads... then the lens has over heated or partially burn, need to replaced.
Dec 31, 2009 | Insignia IS-PDVD10 Portable DVD Player
Cd/dvd cannot be read by the player
EITHER CLEAN or replace THE OPTICAL LENS , try first to clean it directly with a DRY Q-tip ,and test player again. if it doesnt read , then replace the optical lens, hope this helps , AJ
May 19, 2009 | Televison & Video
DVD player is unable to read any disk to initialize play
Laser is probebly goin bad and can't read. try putting a music Cd in. If it can play the music CD but not the DVD it's the laser.
Apr 10, 2009 | Panasonic DVD-RV26 DVD Player
No Disk
The funny thing about dvd players is they just stop functioning after awhile. I've had mine for 2 years now (4 players before that), and that's a personal record. On the flipside I have a sony dvd burner that won't read CD's!
Really the only thing i can suggest is updating the firmware via cd if it supports it (if you give me your make and model # i can check on it). I would also try different DVD's- like ones that you know used to play. Some newer ones have really aggressive anti-piracy garbage that will keep older players from playing them.
Mar 25, 2008 | Harman Kardon DVD31 DVD Player
DVD not reading disk
have you tried other DVD's disks im thinkg your laser is getting weak.
Dec 03, 2007 | Sanyo DWM400 DVD Player
JBL PP-600II System Logo
344 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
