The blue on button keeps flashing and the screen remains black
  • 66 Answers
Check your VGA connection. f problem so check your Video Card and Memory.
Posted on Jan 06, 2009
Emerson flat screen won't power off and screen flashes blue ,green, red and black?
Sounds like the main board causing that type of symptom. You can get replacement main boards from www.tvrepairworld.com
Jan 10, 2013 | Televison & Video
I turn the netbook on and the blue power button is on, but the screen is still remaining black
sounds like the common BIOS flash fix.
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Nov 29, 2010 | Acer Aspire One AOD150-1920 Netbook
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
HP vs17 monitor power button flashes blue but screen stays black.
Try put off Monitor uplug power cord and the VGA cord for 1min and reinsert and restart your PC.
Nov 25, 2008 | HP Vs17 17" LCD Flat Panel Monitor
Samsung 940 BW Monitor Not working (Black screen)
Hi...there,
That's indicated your backlight inverter are busted. Need to replaced a new one or repaired it. To repaired look for a bad capacitors with a bulged on top of each caps. Not sure, just replaced all the caps... Have a nice weekend!
Oct 09, 2008 | Samsung Syncmaster 940BW LCD Monitor
Screen remains black and flashing blue light on power button
I also have the exact same problem. My monitors been collecting dust for a while now and I can't find the solution anywhere.
Aug 05, 2008 | HP f1905 19" Flat Panel LCD Monitor
Common problem...yet no working solution...
I think there's a capacitor that holds a charge for the blue-ring-of-death. The fix is to hold the menu button down for about 30 seconds (blue ring disappears) and continue holding for about 15 more seconds (or until re-boot). The additional time is required to discharge the capacitor.
If that fails, there is a safe-mode: place the device in hold, and press the mic and menu buttons at the same time. This usually doesn't apply to the blue-ring problem, but it may help.
Mar 11, 2008 | SanDisk Sansa e200 MP3 Player
BLACK SCREEN
hi there, you may have a inverter problem to your lcd. ty
Dec 29, 2007 | Gateway FPD-1930 19" Flat Panel LCD...
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
