Issue with my 17" Viewsonic VA1716w LCD monitor
Sir, Im having issue with my 17" Viewsonic VA1716w LCD monitor for the past 2 months. The problem is, i cant switch off/on my monitor, cant adjust the color, contrast, brightness etc., using their provided buttons.
plz give me a exact solution on this issue !
Regards,
Rajesh.J
jkrajesh@ymail.com
  • 55 Answers
If all the buttons on the front don't work I would beleive it was a cable that is not connected correctly. I've seen things like this happen on otherwise perfectly good equipment. It's probably an easy fix however, monitors have enough power to KILL YOU (dead not a little bit very dead) if your not sure what your doing find someone who is most things I encourage you to open up and play with but not monitors. (did I mention you could die)
Be careful
Rob
Posted on Dec 10, 2008
Problem in viewsonic VA1716w Sir, firstly my left side of screen got little darkish(right side was more brighter) after that all of a sudden picture disappeared. Whenever screen switch is tuned OFF and...
First i would check my connection cables. I have had a cable go bad in the past and monitor was fine after replacing the cable. if that doesnt help, fortunately, Vieiwsonic has on eof the better support depts.
start here and select "monitor turns on then off"
http://www5.nohold.net/ViewSonic/Loginr.aspx?pid=5&eroute=ChatEscalation,EmailEscalation
Good luck and dont forget to rate FIXYA
Mar 25, 2011 | Computers & Internet
Problem in viewsonic VA1716w Sir, firstly my left side of screen got little darkish(right side was more brighter) after that all of a sudden picture disappeared. Whenever screen switch is tuned OFF...
Sounds like a hardware failure inside your monitor.
If it's still under warranty I would suggest you return your monitor for a new one. If it's not, then I would recommend looking for a local repair shop to repair it or try to purchase a new or used monitor to replace it.
Mar 25, 2011 | ViewSonic VA1716w Monitor
Sir I have Viewsoni VA1716W model LCD monitor But power LED not on I measure SMPS output voltage 12V and 5 Volt are available but power led not glow what to do please give me some tips.
Since the power supply is OK, the next place to check will be the logic board, you need to find out if it is getting the 5vdc feeding it and also check for 3.3v, 1.8vdc, etc voltage regulators on the logic board. So far I cannot find free service manual to download for it.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Mar 22, 2011 | ViewSonic 17"...
I have installed viewsonic va1716w monitor using windows xp. I am unable to set its resolution to 1440X900. from display properties it going from 1024X768 to 1280X1024
It is possible that the video driver cannot support 1440X900 resolution.
Try installing the latest video driver and then try the higher screen resolution.
Mar 19, 2011 | ViewSonic VA1716w Monitor
ViewSonic VA703m 17'' LCD monitor Issue
I would make sure that all the cables are securely connected to both the monitor and the pc computer (screwing the screws from the cable to the port will help hold the cable in). Beyond that, the issue is likely with the monitor and not something that can be fixed by the end user.
If the device is still in warranty (and checking the cables don't work). I would recommend sending it back to ViewSonic to have it fixed.
May 16, 2010 | ViewSonic VA703mb Monitor
POWER ON ISSUE IN LCD
I do not know where service center is, but at least you can tell them what to look for: http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VA721/
Apr 01, 2010 | ViewSonic VA721 17" LCD Monitor
LCD monitor (viewsonic va720) "No signal"
You will need to disconnect the VGA cord that is connecting the monitor to the hard drive. Once you have that disconnected, try attaching another cord to determine if the cord is the issue. If you dont have another cord to test, then you will have to purchase another one from your local computer parts store and attach to determine if that is the issue you are having.
If the cord does not work, then you will have to take your monitor into a repair shop as there maybe an issue with the receiving port on the monitor.
I hope this was helpful and thanks for asking the experts.
Jan 05, 2010 | ViewSonic VA720 17" LCD Flat Panel Monitor
Viewsonic va721 monitor
Connect the monitor to a different computer system (if available) to see if the issue is with the video card or the monitor.
Make sure A/C power cord is securely connected to the LCD display.
Make sure the video cable supplied with the LCD display is tightly secured to the video
output port on the back of the computer. If the other end of the video cable is not attached
permanently to the LCD display, tightly secure it to the LCD display.
Your backlight may be going bad, or the small controller board may be going bad also.
Nov 29, 2007 | ViewSonic VA721 17" LCD Monitor
Computers & Internet Logo
484 people viewed this question
David Payne
David Payne
