Programing of C
Write a program to evaluate greatest common divisors and least common multiple of integers without gcd function.
    Brigadier General:
  • 10,406 Answers
Nice try!
Find an upper-class student to give you one-on-one tutoring for your homework.
Posted on Dec 02, 2009
WHAT IS A GREATEST COMMON MULTIPLE
Are you sure that is the correct term?
It is usually the greatest common divisor - the number which will divide into two numbers neither being zero, without remainder. For instance the highest common divisor of 12 and 16 is 4.
Nov 06, 2014 | Office Equipment & Supplies
How do I change a percentage to a fraction
Use this http://www.calculatorsoup.com/calculators/math/percent-to-fraction-calculator.php
OR to work it out yourself.....#
How to convert percent to fraction
  1. Divide the percent by 100 to get decimal number.
  2. Count the number of digits (d) to the right of the decimal point of the decimal number.Example: 2.56 has 2 digits to the right of the decimal point, so d=2.
  3. Calculate the factor (f) for making the decimal number an integer: f = 10 to power d
    Example:
    f = 10 power 2 = 100
  4. Multiply and divide the decimal number x by the factor f: x * f / f = y / f
    Example:
    2.56 * 100 / 100 = 256 / 100
  5. Find the greatest common divisor (gcd) of the fraction. Example:
    gcd(256,100) = 4
  6. Reduce the fraction by dividing the numerator and denominator by the gcd value: Example:
    256 / 100 = (256/4) / (100/4) = 64/25
Example One percent is equal to one hundredth:
1% = 1/100
So in order to convert percent to fraction, divide the percent by 100% and reduce the fraction.
For example 56% is equal to 56/100 with gcd=4 is equal to 14/25:
56% = 56/100 = 14/25
Sep 07, 2014 | Office Equipment & Supplies
Greatest common factors
Please the reformulate the problem(?) with more care. Capital P is a different entity than p. Are you trying to factor out the polynomial (an algebra problem where the Greatest Common Factors have no meaning), or are you trying to find the GCF of certain positive integers (an arithmetic problem)?
Feb 19, 2014 | Computers & Internet
956.40 & 988.40 as a ratio
There is not much that can be done to figure out how to write 0.9676244435451234 as a fraction, except to literally use what the decimal portion of your number, the .9676244435451234, means.
Since there are 16 digits in 9676244435451234, the very last digit is the "10000000000000000th" decimal place.
So we can just say that .9676244435451234 is the same as 9676244435451234/10000000000000000.
We can reduce this fraction to lowest
terms by dividing both the numerator and denominator by -2.14748e+09.
Why divide by -2.14748e+09? -2.14748e+09 is the Greatest Common Divisor (GCD)
or Greatest Common Factor (GCF) of the numbers 9.67624e+15 and 1e+16.
So, this fraction reduced to lowest terms isegif.cgi?mag=2&fg=12&bg=15&equ=+++4505852+%2c+%2d+%2d%2d%2d%2d%2d%2d%2d%2d%2c+++%2d4656612%2c
Jul 27, 2011 | Office Equipment & Supplies
Where is the GCF/GCD button on my TI-85 Plus Silver Edition
There are no such buttons, You'll find the lcm (least common multiple) and gcd (greatest common divisor) functions in the MATH NUM menu. Press MATH, right-arrow, and select the desired function.
Jul 07, 2011 | Texas Instruments TI-84 Plus Silver...
What is the method to write fractions into their lowest forms....for eg.... 10/15?
By fraction I understand that the numerator and denominator are both integers. The way to simplify it by hand is to look for the greatest common divisor of the numerator and denominator and simplify by it.
For example 15/27=(3x5)/(3x9). The greatest common divisor of 15 and 27 is 3. Simplifying by 3, you get 5/9
May 22, 2011 | Office Equipment & Supplies
How do you graph a greatest integer problem
To graph a greatest integer function, follow these steps:
1.) Press Y= 2.) Press MATH, then scroll to the right one column and select "int(" 3.) Enter your function inside of the parentheses, and make sure to put a closing parentheses at the end of the function you are inputting. 4.) After you have closed the parentheses to the "int(" command, add 1 to the end of the equation. This is because the "int(" command tells the calculator to take the lowest integer of the value inside of it. If you add one, then instead of .68 becoming 0, it becomes 1, and 1.724 becomes 2, etc.
Feb 27, 2011 | Texas Instruments TI-83 Plus Calculator
Need help in Special Formatting Number
Here is one solution. You might consider adding more robust error handling.
if the decimal numbers passed to the div function are multiples i will be a non-zero number of that multiple otherwise i will be zero.
Dim i As Integer
i = div(12, 0)
If i = 0 Then
'not multiple
' do this
Else
' is multiple
' do something else
End If
Function div(ByVal numerator As Object, ByVal denominator As Object) As Integer
dim n , d decimal
Dim result As Decimal
Dim remainder As Decimal
If IsNumber(numerator) Is True _
And IsNumber(denominator) Is True Then
If numerator <> 0 Then
n = numerator
d = denominator
Else
GoTo error1
End If
Else
GoTo error1
End If
result = Decimal.divide(n, d)
remainder = Decimal.remainder(n, d)
If remainder = 0 Then
div = result
Else
div = 0
End If
Exit Function
error1:
msgbox("Numbers must be non-zero numerics", , "Multiple check error")
div = 0
End Function
End Function
Aug 06, 2008 | Computers & Internet
The Greatest Integer Function (int)
The greatest integer function (also called a step function) is actually a piecewise defined function with a special definition. The function has the notation f(x)=||x|| or f(x)=[[x]] when it is written, but the TI-83 and the TI-84 designate this function by using f(x)=int(x) and is found in the MATH NUM menu. This function is the greatest integer less than or equal to x. So, f(1)=1 and f(1.4)=1. Since this is a piece-wise function you should use DOT mode.
Mar 21, 2008 | Texas Instruments TI-84 Plus Calculator
Computers & Internet Logo
83 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
