FixYa.com
Tags:
Music Hall Maverick CD Player
I'm having trouble writing a complete disc, can yo...
By Powe33 - usenet poster
I'm having trouble writing a complete disc, can yo help?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 08, 2005
Not Rated (0)
kioner
kioner - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
(This is for failures other than buffer underruns. For those, see section (4-1) and perhaps section (4-4).)
If it's failing right as the disc is being finalized, and you're recording in track-at-once mode, try recording in disc-at-once mode instead. It has been suggested that some recorder+media combinations have trouble reading the PMA (Program Memory Area, where a copy of the TOC is kept until the disc is finalized) at the end of a write. With disc-at-once mode the TOC is written early, so it doesn't have to get read out of the PMA. See section (2-19) for the low-down on disc finalization.
When in doubt, check your ASPI layer. See section (4-44).
One user with an ATAPI recorder found that disabling DMA (from the Win98 peripheral properties) made things better.
Try letting the drive cool down (leave the machine off for a couple of hours if you have an internal drive). Power up the machine and immediately record the disc. Sometimes heat buildup can cause problems, though this is less common with recent drives.
This was happening frequently with the HP4020i running off an AdvanSys SCSI card under Win311 (i.e. WfWG). The solution here was to remove IFSHLP.SYS from the CONFIG.SYS. (IFSHLP.SYS is somehow involved with 32-bit file access and network support, so you may have to disable both of these before disabling IFSHLP. You may have better luck under Win95.)
Another user with the same setup found that doing power-up diagnostics and device reset right before burning the CD helped.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: GE 7-5295 Undercounter DC /Radio Combo - WHITE CD Player Kenwood CD-204 CD Player Kenwood CD-423M 200-Disc CD Player Kenwood KDC-C662 6-Disc CD Changer Sony MegaStorage CDP-CX355 300-Disc CD Changer Sony (0762034) CD Player Sony 400-Disc MegaStorage CD Changer with CD-R/RW and MP3-CD Compatibility
Can you Help with these CD Players problems?
CD Players
Sansui vrdvd40001a
continuously freezes in middle... Answer This...
CD Players
cds all skipping.
i spent £100 to have my cd... Answer This...
CD Players
FWM587
I have a FWM587. I use it quite... Answer This...
CD Players
cd player fisher dac 199
the laser ray dont read. The... Answer This...
cd player won't play cd's
i just got a cd player [used]... Answer This...
Repair Service
Find CD Player Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
