I had a 50hm66 toshibia given to me
When you plug the TV in the light engine fan comes on and a short while later it goes back off the guy said it was the light engine is it worth it to fix and were would you suggest getting the parts
  • Joey Mintz Dec 10, 2008
    The bulb looks to be ok Thank you for trying I am ready for the next step
    Problem Solver:
  • 6 Answers
Have you tried physically inspecting the halogen lamp? The lamp can be accessed through a door at the side of the set. You need to unscrew the lock on the door and loosen two screws on the bottom of the halogen lamp housing. After loosening the screws you can pull out the lamp housing through its handle. Check if the bulb inside the housing is broken. Look for powdery deposits on the glass or lamp reflector. This are indications of a defective halogen lamp.
Posted on Dec 10, 2008
The TV was turned off; and when it was turn on later, the green light blinked (while with only black screen w/no sound, or bulb illumination front/back of unit); and shortly afterwards the status ligh
Lamp is possible----
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jul 17, 2012 | Televison & Video
My 50hm66 will turn on,picture comes on for about 10 seconds and then the tv turns off.After it turns off flashing red led on front of tv. What would cause this?thanks jim
I had similar problem with my 50HM66 , except it would stay on for at least a few minutes. I cleaned and vaccuumed (with lamp removed) as best I could, I think it's an over heating issue. My TV is 3 yrs old, have replaced lamp once, it did it with either lamp. When I put a fan to the right of the TV so it's blowing behind it, my TV doesn't shut off. Something to try...
Sep 22, 2010 | Toshiba 50HM66 52" Television
I have a Toshiba 50HM66 DLP TV. I turn it on and after a minute or two the screen goes black but the volume is still present most of the time. The picture may come back a few minutes later but go again.The...
I hope our expert would have provided you helpful info in chat session, if you still need further help, let me know the steps taken so far to solve the problem of your tv.
Sep 18, 2010 | Toshiba 50HM66 52" Television
I just replaced the lamp in my tv, it will work fine for 10-15 minutes, after that the picture will start to flicker and then just go out completley and th lamp light will blink on the tv set, what could...
My 50HM66 did the same thing. Try putting a fan to the side of the tv so it blows cool air around the back. I also removed lamp and vaccuumed as best I could. I think this is an overheating issue with the tv.
Sep 03, 2010 | Toshiba 50HM66 52" Television
I have a Toshibal 50HM66 DLP TV. I purchased it about 4 yrs ago. It worked well for 4 months and the bulb popped, since then I've had to replace the bulb 3 times at a about $150 per bulb. The last bulb...
I have had the same problem and after several trips to the shop I realised it was caused by humidity. The shop was air conditioned so the problem never happens there. A dehumidifier or air conditioner "solved" the problem.
Dec 27, 2009 | Toshiba 50HM66 52" Television
Adjust convergence on toshiba 50hm66 projection tv
can't adjust convergence on this set most likely bad light engine very expensive repair.
Aug 07, 2009 | Toshiba 50HM66 52" Television
Tv comes on just the sound about three seconds later tv shuts off
I have the same issue with mine and have a solution that sometimes works. I had a repair guy come to check it out and he powered off the TV so that the red light was no longer blinking, then he unplugged the TV for about 30 seconds or so and then plugged it back in. He then turned on the TV and it worked. He said it would cost about $400 to fix the issue (some circuit or something). I have since expeerienced the on/off problem (due to power outage) and now I cannot get the TV to work. But at least give this solution a try and please post to let me know if it worked or not. Good luck!
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Plaid Screen
The problem is likely with your seine board or another video board. It will have distorted video/colors and you will see copies of the image in random sizes/places around the screen. If the toshiba menu is distorted it is in later stages of video, if not then earlier. More info will narrow down exacly which board. You can try reseating the LVDS cable, the computer looking one in the middle of the tv. It goes from the video board to the light engine. Unplug the tv and take off the back. The cable is usually white and has a D-type computer like connector with buttons or screws to unlock.
Dec 06, 2008 | Toshiba 50HM66 52" Television
No pic
alright guys...blew a bulb....fixed that. still didint work...found out it was ballast...replaced that. tv worked for a month..all the sudden hdmi input didint work id plug in my playstation and screen would turn green and say "hdmi color has been corrupted" im thinking wtf? so a week later it works fine then just turns off in middle of watching espn... comes back on an hour later...only to turn off just turns black for ten seconds then just turns off and the red and green lights blink at intervals of one second....replaced a bulb..not that, same problems.......when the tv comes on for the ten minutes before it quits working the pic and sound are great i just dnt get it shorting out? color wheel bad? a fan?
May 24, 2008 | Toshiba 52HM95 52" HDTV Projection...
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
