Question about HP Photosmart C3180 All-In-One InkJet Printer
MY PRINTERIS HP D 1360. NO PAPER PRINT.I HAVE NO KNOWLEDGE OF TROBLESHOOTING. message no toner. but new cartidge.
    President:
  • 2,110 Answers
Black line coming while printing on hp m5025mfp
the problem is in fuser or in toner cartidge.
print a page when the printer start to pull the paper more than a half page stop the printing by open the door
remove the toner and look the paper
if you see the line the problem is from toner replace toner cartidge if you see the image ok means the problem begins when the paper go into the fuser so replace fuser.
Feb 20, 2014 | HP LaserJet M5025 MFP Printer
Lines across paper when printing after changing to a new printer toner cartridge
ensure that u r using a hp cartidges
dis problem persists when u r nt using hp cartidges or u have rifilled the cartides
also sometimes when the printhead of the cartideges is defective u face same problem
Jan 05, 2011 | HP LaserJet 2420d Printer
I have a streak running up and down the entire page on every page. at first it was not as noticable but now it is very dark. what do i do?
If it is up and down, then you have contamination of the paper path. The paper path needs to be thouroughly cleaned.
In addition, check the rollers and little wheels that keep the paper flat where the printheads cross. On some printers, the carrier for the shaft of these can come loose and allow the paper to buldge up slightly to hit the print head and smear a vertical stripe.
Aug 05, 2009 | Epson ACULASER CX11NF All-In-One Printer
HP Colour Laserjet 2840 - all toner spread out when printing
Replace the toner cart. immediately
Take printer outside and blast with air from small low-pressure compressor.
Toner is very messy, but harmless
Mar 27, 2009 | HP LaserJet 2840 Printer
Check paper tray check cartidge.
I have the 1350 all in one, and when I changed my cartridges I screwed up and replaced both at the same time, that was a no no as I found out. I kept getting the test printer and print example too. so what I had to do was Uninstall the printer and drivers, then reinstall them again, that worked.
Oct 28, 2008 | HP LaserJet 3015 All-In-One Printer
Printer problem
The average yield for a Q2612A cartridge is 2,000 standard pages.
Based on these statistics
Current I don't see a higher yield cartridge available for your printer. The company I work for only carries 2,000 yield as well.
Did you swap toner cartridges into this new printer?
If this is a new printer make sure all the packing material is out of the cartridge slot such as any tape, seals, or string.
Your printer should have come with instructions telling you where the packing material is.
Jul 18, 2008 | HP LaserJet 3050 All-In-One Printer
TONER EMPTY MSG
1-remove power from fax.
2-clean contact points in toner cartidge and the contact in fax which it make contact together.
3-knock above toner cartidge many times.
4-move it in horizontal direction from left to right many times.
Feb 25, 2008 | Samsung SF-5100 Plain Paper Laser Fax
HP Photosmart C3180 All-In-One InkJet Printer Logo
44 people viewed this question
Seeker5211
Seeker5211
