Question about KONFTEL 100 Audio Conference
ENGINE RUNS BUT NO POWER
KT 100 YAMAHA ENGINE RUNS PERFECTLY WHEN KART IS OFF THE GROUND (ON ITS STAND),BUT YOU CAN STOP THE ENGINE BY GRABBING THE REAR WHEEL WITH YOUR HAND.AND IF YOU PUT THE RUNNING KART ON THE GROUND (ENGINE CONKS OUT) I HAVE PUT IN A COMPLETE NEW GUSKET SET IN THE CURB BUT DOES NOT HELP (PLEASE HELP)
IT COULD BE MORE THAN ONE THING,,, FIRST CHECK COMPRESSION, IF IT HAS LESS THAT 80 lbs THAT IT,,, PUT IN NEW RIGS,, IF IT HAS COMPRESSION, THE TAIL PIPE COULD BE STOPED UP,, IF NOT,,, 2 STROKE ENGINE'S HAVR REEVE PLATES, THEY COULD BE BAD,, REPLACE THEM,,, THE CARBERATOR COULD BE IT IF ALL THE OTHER THINGS ARE GOOD, MY BEST GUSS IS,,,,,,IT NEEDS RINGS,, LARRYFRANKUM6780@SBCGLOBAL.NET LET ME KNOW,,,
Posted on Feb 20, 2009
    Problem Solver:
  • 10 Answers
I think it may be the rigs need replacing or you need to rebuald the bottem end of the motor because it has worn out bearings
Posted on Feb 16, 2009
Yamaha TDM 850 engine dies when clutch lever is released
Hi, Marcus the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Stalls When Release The Clutch Lever
The 1299 Engine dies when pulling the clutch lever in
Yamaha TDM850 1996 Service Manual
OEM parts for Yamaha
YAMAHA TDM850 Owner Manual
Aug 18, 2017 | 1994 Yamaha TDM 850
Yamaha outboard troubleshooting
can you check that the fuel tank breather is not blocked.
Jul 17, 2017 | Boating
2002 yamaha v star 650 wiring diagram
The starter button is supplied with voltage from the engine stop switch internally in the right hand handlebar switch. Dissassemble the switch and verify that you have voltage to and from the stop switch. You will see the jumper wire to the starter button circuit board verify that it is hot when key and stop switches are on then verify if voltage passes through when button pushed. If not dirty or melted contacts in the button switch could be the cause. If voltage passes it goes to the solenoid next Via a side stand relay. This relay obtains a ground from the side stand switch. You can jump across the side stand switch to test it. From there the side stand relay must be checked or replaced. Keep following the voltage path untill you find where it stops and repair or replace as necessary. Good luck!
Dec 30, 2012 | Yamaha Motorcycles
2001 YAMAHA ROADSTAR will only start if kickstand is UP not DOWN and clutch handle pulled in for some reason it thinks bike is in gear but it is not. The neutral light is on bike drives good and shifts...
Hi, Layton_dille the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Re only start neutral dilemma Road Star Forum Yamaha Road Star
neutral light wont come on when in neutral and wont start with kick stand...
Yamaha XV1700PCRC Service Manual
Yamaha XV1700PCR Road Star Warrior Owner Manual
May 07, 2012 | Yamaha Road Star Motorcycles
Yamaha Radian stalling
Hi, Anonymous the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
Re dies when put in gear Road Star Forum Yamaha Road Star
Bike dies when put it in gear plz help
Yamaha YX600 Service Manual
http://www.badrad600.com/Radian%20Manuals%20-%20Complete%20-%20Printable/Radian%20Owner's%20Manual%20Clean%20Complete%20Final.pdf
Mar 25, 2012 | 1987 Yamaha YX 600 Radian
Electrical problems with ignition on 1989 virago xv1100
Hi, Rj0203 the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
1989 virago xv1100 wiring diagram Google Search
Yamaha Motorcycle Wiring Diagrams
http://service.tanga-moteurs.ro/data/yamaha_virago_535_700_1100.pdf
Yamaha Virago XV1100L Owner Manual
Jun 26, 2010 | Yamaha Motorcycles
Starting a yamaha kt 100 go kart engine
just bought this go kart , the guy said it was a yamaha kt 100 2t 2 stoke but i have no clue about this motor , is it a good one
May 27, 2009 | KONFTEL 100 Audio Conference
Carbie tuning
Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Don't be chincy with the spray. You probably have a varnish buildup that is stubborn to remove. Remove the two screws on the outside throat of the carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two screws down. Only screw these in until they LIGHTLY seat. Now turn each screw one and one half turns outward. Put the rest of the carb back together, clean the air filter and install the carb. Be sure the bolts are tight. Let the float bowl fill then start the engine. Set the idle speed with the idle screw. This process should get you back on the road.
Please rate this solution. Thanks!
Mar 29, 2009 | 2003 Yamaha YZ 125
Yamaha kt100 kart
I've never seen a KT100 before, but i've worked with similar engines.
The fuel isn't gravity fed. It uses a pulse pump system using diaphragms in the carburettor to sort of "**** and blow" the fuel using pressure impulses and valves to stop the fuel going backwards.
The first place you should look is if there is a short pipe from the crankcase to the carb so that the pressure pulses from the case can move the diaphragms. You should be able to see this from some pics on google images. If thats all ok, you should check if the carb is perfectly clean. If its still giving you problems, change the diaphragms in the carb. You should be able to get a replacement rebuild kit from a dealer.
Jun 09, 2008 | KONFTEL 100 Audio Conference
KONFTEL 100 Audio Conference Logo
321 people viewed this question
Top KONFTEL Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a KONFTEL Lands Phone Expert? Answer questions, earn points and help others
