Question about Panasonic Panafax UF-885 Plain Paper Laser Fax
Panasonic UF-885 Fax Machine
Dear Sir/Madam I hope that you are well. is there away to connect the above fax machine to my PC? Please let me know. Thanking you for your kind efforts and cooperation B Regs zaza
    Scholar:
  • 135 Answers
Here is a link to the owner's manual: http://service.us.panasonic.com/OPERMANPDF/UF885.PDF It appears that there is an optional parallel port interface that can be added to the unit (see p. 173), which will make it behave as a printer and scanner. The implication would be that you could not use it as a fax in this way. It is very likely that you would be better off buying a modern, inexpensive "all-in-one" unit for connecting to your PC. Basic units are in the $100 range. Personally, I love my HP OfficeJet 5610.
Posted on Feb 28, 2007
I would like to forward my faxes to another fax machine. the fax machine that i am using is panafax uf-885. how do i do that
Try entering *72########### where #=fax # that you want to forward to. To end forwarding, enter *73. This depends on if your carrier supports call forwarding.
Jun 10, 2011 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 flashing UF-885 (AU) message
yes there is a batt on the board it will need to replaced i have seen this many times
Nov 18, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
I want to delete the memory from my panafax uf 885 fax machine.
Press
Function
7
monitor key slowly 4 times
* star key
6
scroll down to SHIPMENT SET
set
wait for machine to reboot
Nov 10, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF 885 replace battery
Turn the machine off for 10 seconds.
If the display shows 00% there is nothing in memory.
Apr 20, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Fax machine error code 021
If a new toner cartridge doesn't take care of it, replace the fuser.
Apr 07, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Panafax UF-885 - Error Code 055
Error 055 is a laser error. the laser is not spinning at the proper speed and may need replacement. There is another solution, where some ferrite cores are added around three cables to reduce electronic interference. Best call a local technician for further diagnosis.
Mar 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
Error code 634
Check your phone line by plugging a regular phone in.
Feb 25, 2009 | Panasonic Panafax UF-885 Plain Paper Laser...
UF-885 Panafax
Unplug the power cord in the rear of the machine
Open the document feeder by pulling it straight up
hold down the pointed switch by the scanner glass while plugging the machine back in until you hear a beep
close the document feeder
press SET or START
press 2
wait for the machine to reboot.
Dec 30, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF - 885 unable to send faxes direct
Hi BrendaAsh,
Thank you for the above information.
Please ask rlandriani to access the user parameters on the fax machine and turn the Quick Memory XMT to "Off" or "Invalid".
This should set the machine for direct manual sending without memory intervention.
Regards
Gavin.
Oct 17, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic copier/fax UF 885
It sounds like you are stuck in the boot-up mode.
Try this:
Open the toner door and remove the cartridge
Open the document feeder by pulling straight up
While turning the machine back on, hold down the pointed switch actuator closest to the small glass
Close the document feeder..display should read "RAM INITIALIZE"
Scroll down to "SHIPMENT SET"
Press "SET"
Press "2" for "NO"
Wait for the machine to reboot (could take 5 mins)
Some times a bad toner cartridge will cause this.
If this does not work, you have a bad Main PC Board. Uneconomical to repair.
Sep 19, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Panasonic Panafax UF-885 Plain Paper Laser Fax Logo
104 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
