My Philips Plasma 42/PF 9945-12 will not switch on. The standby light flashes on and off and there is a click from the relays- i presume on the switching panel.Any advice would be very welcome!
  • 3 more comments
  • Hvemved Jan 02, 2009
    I have the same problem. Did you fix it?, and how ?
  • Anonymous May 18, 2009
    i have the same problem too, did you find a solution?
  • baldyntag May 18, 2009
    my tv wont turn on, just getting a red light and clicking noise?
  • pek_aik_soon May 11, 2010
    Dear wedel_dk Do you know the exact resistance for the 2 resistors and the capacitance of the capicitor for the repair kit sold on ebay? regards aiksoon
    Problem Solver:
  • 6 Answers
There may be a problem with the Small Signal Board Assembly
Posted on Dec 10, 2008
This kit solves the problem. REPAIR KIT FOR SAMSUNG LJ44-00049A POWER SUPPLY MODELS USED IN: PHILIPS 42PF9945 PHILIPS 42FD9925/01 FAULTS REPAIR KIT COVERS: * relay clicking red standby light only or standby light flashing * stuck in standby or going into standby after swicthing on kit contents: x2 resistors x1 cap http://www.andyselectronicstuff.co.uk/plasma_board_repair_kits.html Sales on e-bay ... Bought and installed it. Works fine... Anders DK
Posted on Jun 15, 2009
I have the same problem, did you get a solution?
Posted on May 18, 2009
Philips 42 pf 5592/32s ftv 1,9 -de aa
is the light blinking in a particular pattern?
Jan 31, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Sony 42 inch plasma tv standby light just flashes tv
You might have a bad B board. What's worse is that the power switch is connected to the Q board which works in conjunction with the B board. Replace B board, You can send your B board for repair to a company called modus link pts. They are the largest part supplier of after market parts and repair.
Feb 24, 2010 | Sony WEGA KE-42TS2 42 in. HD-Ready Plasma...
Flashing green ligt----------intermittent
Many problems with philips can be solved by doing a software update which is done with a flash drive in the USB port. The only problem is your model number dosen't show up on philips web site. You may want to try to email them from their site to ask why your's dosent exist.
http://www.p4c.philips.com/cgi-bin/dcbint/cpproduct_selector.pl?slg=AEN&scy=US
Mar 13, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Tv stuck on standby
Power supply probably needs to be replaced if you don't even hear the relay click after the power is switched on.
Jan 08, 2009 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
My philips 42 inch plasma model # 42PF9966/37 wont turn on. Red standby light is not on
Hi. Try, in back yours tv on left side of the power corde connector have on hole, inside of this hole have one main switch, using one insulated stick and sheck if this switch is off ( may be not ) but try. If you heva esperience take out the back cover and check the fuse on power board. Good lock
Jan 03, 2009 | Philips 42FD9932 42 in. Plasma Television
42FD9954 philips plasma TV flashing LED it wont come on
The problem is in the standby power supply. the standby power supply generates the 9 volts and the 5 volts requird by the tv. If you measure the 9 volts source, with only the red light on, the correct voltage is 9 volts. However if the 9 volt measures 6.5 to 7 volts it is too low and the startup relays cannot operate. My set is a model 42FR9954/17S. In this set if capicator, 2603, is heated the voltage climbs to 9 volts and the relays work. If cold air is applied to the capicator the relays fail to operate. Replace capacitor 2503 and the problen is fixed. This capicator is: 47 Ufd, rated @ 450 volts, and is 20%.
Nov 08, 2008 | Philips 42FD9954 42 in. Plasma HDTV
Panasonic th-42pa20 plasma 42 inch tv
Try to replace the Main Power Supply board first.
Dec 29, 2007 | Panasonic TH-42PA20U/P 42 in. Plasma EDTV
Televison & Video Logo
3,185 people viewed this question
Top Televison & Video Experts
