Question about Dell PowerEdge 2300 Server
Monitor and keyboard will not respond
I have a Dell Poweredge 2300 and it's been off and unplugged for a while, around a month maybe, can't remember. Anyway, when I turn it on, the monitor acts like nothing happened and no lights come on the keyboard. The server turns off and on just fine, but whenever I turn it on everything just sits there. I've had this happen a couple of times with this server and usually I have to leave it on for a couple of days before it starts to work again, but this time I've had it on for about 4 days now. Is this normal with these servers, or any other server, and is there anything I can do to get it to work?
  • bobisguilty Dec 12, 2008
    I put a pci video card into the server and still no response from the monitor or the keyboard. I'm going to see if I can find a replacement motherboard for it, thanks for the suggestion.
    Problem Solver:
  • 18 Answers
It only happens with your keyboard and mouse? or does it include your monitor too? if it does include you monitor then it is the video card. It is built in to your system and is causing the problem. I got the same issue before. My mouse doesn't work, keyboard won't respond, monitor is blank. I know its the video card. It is not typical for a server to respond that way but you need to replace the system or replace the video card...
Posted on Dec 11, 2008
  • Mark Dec 12, 2008
    if you replace the motherboard then just replace the whole server itself. Unless you replace it with a refubirshed same specs motherboard then why not. But still its not worth keeping!
4 Suggested Answers
  • 9 Answers
SOURCE: dell poweredge 2300 server
so what is the question?
Posted on Aug 18, 2008
  • 13433 Answers
SOURCE: Poweredge 1800 server
Hey,
I looked over the spesifications for the poweredge 1800 servers, go ahead, it will work perfectly but there is one problem in the windows XP setup, you will need to insert / load SCSI or SATA drivers for the hard drive With a floppy disk, or if you don't have a floppy drive your going to need to create a custom windows xp setup cd and add the drivers into it so it can start the SCSI or SATA hard drive and finish the install. without the drivers it might not find the hard drive.
Aside from that I don't see any other problems. You should be able to get the drivers, and everything ese from dell site
http://support.dell.com/support/downloads/
Actually I looked over the dell downloads, I see only windows 2000 on the list with windows server 2003, and 2008 and linux distributions.
This could be a 2nd problem, drivers might not be avaialble, or work with xp, but we might be able to get it to work.
So two problems, SCSI or SATA drivers in windows xp / windows 2000 setup
2nd problem is in windows xp drivers, you could try windows 2003's drivers and 2000's and see if they work, if not, then we would have to look for drivers ourselfs from the internet.
So xp might cause headache but we might get it working, windows 2000 seems to be supported perfectly.
Let me know how the project goes
Thanks,
Ekse
Posted on Jun 03, 2009
JaxPlanet
  • 922 Answers
SOURCE: Dell PowerEdge 2300 - Monitor, keyboard and mouse will not respond
It sounds like the power supply is failing.
Failing power supplies will sometimes deliver just enough power to make the fans spin but not enough for the motherboard and drives to start.
I hope this helps.
Posted on Jul 23, 2009
A power outage cause dell server 1600sc to shut down & no display on the monitor
Hello here is the homepage.
http://www.dell.com/support/drivers/us/en/ussoho1/Product/poweredge-1600sc
There should at least be a message on the monitor indicating there is no signal coming to the monitor. The first thought that comes to mind if all is connected would be that the power supply has failed.
And maybe the graphic card.
Call also the DELL support in your country they will be glad to help
and they probably know the fault.
Contact Us 1-877-671-3355
Good luck
Nov 16, 2012 | Dell PowerEdge 1600SC Server
Installing Dell PowerEdge R710 DVR Server
  1. VIA a serial cable (looks like monitor cable is not). You have use something like telnet. Old school and very technical.
  2. Just connect a monitor, keyboard, and mouse and treat like a regular PC. Can't go wrong.
Aug 21, 2012 | Dell POWEREDGE R710 E5520 226G 2P 4GB...
We have a Dell Poweredge 4400 & a Dell Poweredge 2300. Both have amber lights blinking - hard-disk failure indicators. They are using RAID. What do I need to do?
Go into the RAID setup during bootup (not always in the BIOS), but will post somewhere on startup (should say SCSI/SAS Controller card press CTRL + M to enter setup) or similar.
When in the raid setup check to see the status of the drive(s).
Was the machine running and it's just happened etc or are these machines you have obtained and are plain not working?
Sep 07, 2010 | Dell PowerEdge 2300 Server
Dell poweredge 2300 server have a contant beeping. i change the battery but still beep.
It probably is trying to tell you that it is overheating.
Check that the fan(s) on top of the CPU(s) is/are working.
Jul 30, 2010 | Dell PowerEdge 2300 Server
I hope this helps.
May 28, 2009 | Dell PowerEdge 2300 Server
Dell PowerEdege 1600SC not recognizing IO devices
Just go into the bios and insert the correct parameters. you shut it off before it could save the settings. Or hit fi on boot and it should take you into the bios and you cand sort it out in there. If you want an easy way, just do a system restore. Start,Programs, accesorys, system tools, system restore, just go back a day or two before you had that issue, and you should be good to go, good luck
Apr 12, 2009 | Dell PowerEdge 1600SC Server
Dell poweredge 2300
Servers usually don't come with sound cards. If you really need one, you must install one. If it is truly a server, I would recommend against it.
Apr 11, 2009 | Dell PowerEdge 2300 Server
Poweredge 2300 - Ubuntu OS - belkin usb PCI card - not recognized
Check lsusb and see the list if u can find the root in the list
Apr 08, 2009 | Dell PowerEdge 2300 Server
Poweredge 2300 Configuration Help Appriciated :)
I have a older poweredge 2300 i get the following message run program setup.
Mar 26, 2008 | Dell PowerEdge 2300 Server
Dell PowerEdge 2300 Server Logo
369 people viewed this question
Alun Cox
