Question about Sony DRU-820A DVD RW Dual Layer Burner
Primary and Secondary IDE Channels
With reference to my problem of slow burning dvds, someone has suggested that I uninstall both the primary and secondary IDE channels. When you reboot it is supposed to reset everything. Did some searching on the internet regarding it and the pros and cons seem to be equal. Any opinions on doing that? It seems kind of scary to me.
    Sergeant:
  • 310 Answers
You could do it, dont think it will make any difference to you though, if you have a slow pc it can affect copy speed, adding more ram can also improve time if you have less than 256mb, also the program i use is have nero installed but use a program called DVD Shrink which is a free program if you search on google.com. and maybe try burning using faster dvd discs, usually about 15-20 mins to burn a dvd but depends on the speed of drive and discs. hope it helps John
Posted on Feb 28, 2007
Today I installed SATA HDD at red SATA port 1 . But in BIOS, it shows Primary IDE master not detected....Primary IDE slave not detected....Third IDE master detected..I wanna know why my HDD is not detected...
there is no diffrence between primary & third ide hdd ,if you install nay booteble hdd in master so system try to from that frist . boot sequence of motherboard is try to boot from primary master first then Primary slave then secondary master and then master secondary ..................,
Jun 12, 2011 | ASUS P5GC-MX/1333 Motherboard
Primary IDE port does not work on intel d865GVHZ motherboard
we are repiar the mother board and 100% warrnty contect for more detetil : www.compudesk.in E-mail: support@compudesk.in
Oct 12, 2009 | Intel D865GVHZ Motherboard
HP dvd740b does not detect blank CDs and DVDs
i think you,ve hit the nail-on-the-head.
The laser has to power up highrer to write a DVD, or ocassionally have a dual laser. 1 for read/write CD. And 1 For Read/Write DVD.
Certain cd roms, only use CD- media. it,s probably worth checking which media is supported by the drive.
Also check the drives aren,t conflicting, on the same ide channel, sometimes swapping channels, ide primary/secondary can help, or swiitching Master/Slave/cable select jumpers on the drives Themselves.
Mike @ Compurepair.
Sep 04, 2009 | HP dvd740i DVD±RW Dual Layer Burner
Quickplay on laptop plays everything slow motion and no sound, no sound for games most of time.
Are you running xp or Vista?
In XP go to device manager and expand list of IDE ATA ATAPI controllers. Right click on primary IDE controller and select properties. In advanced screen check primary IDE mode - that should be DMA.
IF that is in PIO mode - that is your problem.
Just click on driver tab in the same window and click uninstall.
REstart computer twice and problem should be solved.
Please leave your feedback if issue is solved
May 28, 2009 | Computers & Internet
Dru-190a sony it takes 50-60 min to write
Just right click on my computer, go to properties> hardware> device manager> IDE ATA/ATAPI Controllers. there u will find several primary and secondary IDE Channels. Right click on first IDE channel and goto properties> Advanced settings, change transfer mode to "DMA if Available". Repeat it with all the channels. If problem still persists then uninstall the channel containing ur DVD Writer and restart your computer. It will detect new hardware as DVD Writer. Now if it is showing the transfer mode "DMA if Available" by default then your problem is solved.
Dec 27, 2008 | Sony 20x Dvd Rw +And -Dru-190a Burner
My dvd writer DRU-190A takes 50-60 minutes for each dvd writing.
DVD REWRITER NOT BURNING DISCS
okie ...
do one thing ... go to device manager and than uninstalled the cd/dvd drive and than uninstall the secondary and primary channels and make sure u delete them in the same sequence you will find it under the ide/ata/atapi tell me whats the result
there are other steps also
Nov 05, 2008 | Computers & Internet
I can't burn on dvd-rw disc anymore
i am sorry but i am just getting the half of ur issue ... all i understand the drive is not reading while burning .. but in normal scenarios does it read cd's or dvd's ?
anyways try this
go to device manager > uninstall the dvd/cd drives
delete ede/ata/atapi channels ... both primary and secondary delete the secondary first coz 90% the hard drive is connected in the primary channel and if u uninstall the primary first the system will hang and than restart the system and than try it out and if that doesnt work reply back... we will try some other things
Oct 30, 2008 | Microsoft Windows XP Media Center Edition...
Dvd-rw
try this out
go to device manager > uninstall the options under the dvd /cd drives
uninstall the options under ide ata/atapi uninstall the secondary channel and than uninstall the primary channel and than restart the system and than try to burn
Setting up a Computer to install Windows XP Professional.
Pedro -
I'll assume each of these is an IDE device, meaning each has a wide connector versus a narrow SATA connector commonly found on newer hard drives.
Your motherboard should have two IDE channels, labeled IDE 1 and IDE 2, Primary IDE and Secondary IDE, or something similar. Each IDE channel can support two devices.
For best performance between the drives, you will want to have the Hard Drive connected as Master(Drive 0) on the Primary IDE channel; The CDROM should be connected as Slave(Drive 1) on the Primary IDE channel. Connect the DVDROM as Master(Drive 0) on the Secondary IDE channel, and the ZIP Drive as Slave on the Secondary IDE channel.
When connecting the drives, make sure you set the jumpers correctly; Both the Hard Drive and the DVDROM should have their jumpers set to Master, the CDROM and Zip drives should have their jumpers set to Slave. An alternative is to set the jumpers for every drive to Cable Select(CS), allowing the physical connection of each drive to determine whether its a Master or Slave device.
*Note*
If your Hard Drive is a SATA device, connect it to the '0' or '1' SATA connector on the motherboard. Have the DVDROM set up by itsself as Master on the primary IDE channel, the CDROM as Master on the Secondary IDE channel, and the ZIP as Slave on the Secondary IDE channel.
Hope this helps!
-thinstatic
Jun 11, 2008 | ASUS P4S8X-MX Motherboard
Sony DRU-820A DVD RW Dual Layer Burner Logo
57 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
