Question about Maytag PYE2300AY Electric Dryer
I have a may tag dryer about 2 years old and it shuts off
After a min or so it just shuts off can you please help Thanks
  • 148 Answers
Does it make any noises ? Does it heat in that minute or so? Is the dryer gas or electric?
Posted on Dec 31, 2008
I have a May tag Neptune Nat gas. It starts and lights the flame but after 11/2 to 2 min the flame shuts off Checked the temp sensor and has continuity. What could be shutting the gas off? Thanks
The air passage may be blocked, and it's shutting the flame down to keep from burning your house down. Check the lint trap and the exhaust hose/exterior fitting for blockage.
Jul 09, 2015 | Dryers
Tip
I have an electric whirlpool dryer about 4 years old..here are my issues and any...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on Nov 30, 2009 | Kenmore 62602 Electric Dryer
Dryer keeps shutting off while drying. Even if holding the push to start knob it will shut down. Is this a sensor problem or a 8 year old dryer problem
Hello;
My name is peter. I am a retired field service appliance technician.
You did not provide a model number which is on a metal tag on the face of the dryer after you open the door, so I can only be general.
A dryer should last your 15-20 years or more. You are probably plugged up with lint and have poor air flow witch will shut you down, or you may have a bad high temperature thermal switch.
Jun 04, 2015 | Dryers
I have a maytag elet dryer. M#Medb800vq0. I have proper voltage going to the dryer. The min display will not go to min setting when the slector switch is moved. The dryer will not do any thing. All...
There should be a technical data sheet inside the operator console that explains your error code and offers some troubleshooting advice. To access, you need to loosen the screws in the back of the operator console and lift up. If you need to view some diagrams to help you with assembly and/or parts locations, here's a link that you can use:
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MEDB800VQ0/3048/0151200?searchedModel=MEDB800VQ&blt=06
If you have any questions, please post back and let me know. I hope this helps you.
Apr 28, 2011 | Maytag MEDB800VQ Dryer
The microwave keeps shutting off
I would suspect the internal cooling fan is not running, or the vents are blocked.
This would cause the magnetron to overheat, then the magnetron's thermostat on the magnetron opens, interrupting all power until it cools down.
This is to protect the magnetron from being destroyed.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Microwave Oven Control Panel Repair Nationwide
May 03, 2010 | Magic Microwave Ovens
Just purchased a used Whirlpool Duet dryer(2 to 3 yrs. old). I hooked it up and placed it on a normal automatic cycle. The unit started up a little noisey but quitened down in approx. one min. Shortly...
try replacing the power cord, and make sure that you have a "dedicated" power sorce for the plug. The system board will shut the dryer down if a power supply issue is detected. This feature is to prevent fire hazards. Make sure your electric box is grounded and up to code.
Jun 26, 2009 | Whirlpool GEW9250 Electric Dryer
TAG Heuer Carrera Calibre 16
Hi
This is a warranty issue, the watch should not lose time like this. Take it back to the supplier ASAP
Cheers
Dave
Jun 21, 2009 | Tag Heuer Link Automatic Chronometer...
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
70 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
