Question about Frigidaire PLHS267ZA Side by Side Refrigerator
Broken water dispenser arm
The plastic paddle arm that I depress in order for water to be dispensed has broken off. There is just enough of the arm left that I can press it to work, but it is not convenient. Is there a way to replace that arm?
I just fixed this today. 01/2/08
First, I got some super glue from Lowes especially designed for plastics.
I first glued some metal strips to the back or the broken off lever, so it will have extra support once glued back. I then applied glue to the broken surface of the lever arm and the support arms I glued earlier.
Super glue it awesome, just had to hold it in place for 1 minute, then let it cure for a few hours... working good as new.
I'm glad this worked for me, as I did not want to have to search for the part and then worry about taking the refrigerator apart.
After repair, I had to educate my wife on how to slam a cup into the arm HEHE.
Posted on Jan 02, 2009
How do you remove the panel covering the water and ice dispensers in an older Kitchen Aid 48 Superba side by side refrigerator freezer? I need to replace the water microswitch.
On the bottom of the bezel around the dispenser you will find 2 very thin slots. You push in a flat blade pocket screw driver and pry it up then lift the bezel up and off. Now look at the switch. It should have one mounting screw and a plastic pin sticking through the other mounting hole in the switch body. I'll bet that pin is broken and the switch is not making contact with the dispenser paddle. If it is broken you'll have to order that back plate . there may be nothing wrong with the switch. If the plastic pin is there, then the switch is indeed bad.
Aug 14, 2016 | Refrigerators
Model # RF4287HARS/XAA
No it's a whole assembly the plastic clip is broken. Give me a model number I'll track down the part for you.
Oct 05, 2015 | Samsung French Door Refrigerator Right...
Samsung model rf4287hars only dispenses water when ice lever depressed
3b662ccb-018c-4390-ab7a-74a2025960df.jpg 3d562c7f-18a6-4fa7-9993-373c8c5d3c7f.jpg 763378c4-5f13-435a-aac3-b67d9041b031.jpg
First photo shows paddle assembly that can be purchased you need to got to Sears web site to find part # other wise you will have to buy the whole circuit board assembly hundreds more than the paddle assembly. The circuit board and paddle assembly is removed buy removing screw on inside of door and pulling it out be careful it seems strange but it just pops out. The paddle assembly slides on to the circuit board assembly look close and take your time to slide it off I thought I was going to break mine but did not and save me big money.
Second photo shows tab for water dispensing still there.
Third photo show ice dispensing tab broken and missing.
If you leave the assembly plugged in press the micro switch for the ice dispenser and see if it works most likely the tab has broken and is what hits the switch telling the door to open and ice dispensing screw to push ice to the door. Hope this helps
Mar 04, 2014 | Samsung RF4287HARS - 28 cu. ft. French...
Water dispenser for gsh25JSTA BROKE can I fix
All of you guys are wrong. What that person is saying is that the physical paddle used when you place your glass in the dispenser bay and press against the paddle....That's what's broken the paddle......
Jan 05, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
My Samsung Model: RF4287HARS refrigerator stopped DISPENSING ice. It makes it, but only water comes out of both push levers now. I get ZERO help from samsung customer service. There is nothing in
The problem is actually in the dispenser lever. The paddle that you press to dispense ice has a plastic lever/arm that extends behind it (you can't see it, it's up high in the assembly.) This plastic lever presses upwards when you push the paddle and presses into a switch. The switch actuates the ice. This little lever is also the ONLY thing that stops the paddle from continuing to press into the water paddle. So when the lever breaks, it creates your two symptoms - no ice and if you press further, you press the water switch and get water.
You need part# DA97-08519A. This is the lever assembly with the switches. You pry the control panel assembly (the whole digital display above the water/ice dispenser) out by inserting a slim pry bar (I used a pocket knife and didn't damage the finish) on one side and working my way around. The assembly is held in place by five plastic tabs (two on each side and one on the top.) When this is removed, the part# above will be obvious.
Sep 08, 2012 | Refrigerators
Ice and water dispenser stopped working
Welcome to the computer world. When depressed, the paddle actuates a switch attached to the bracket above. The switch sends a low voltage signal to a small circuit board mouted right behind the display. A computer chip on that small board communicates with another chip on the main control board mounted in the rear wall. Your situation could be a bad actuator switch, a broken paddle tab, possibly a bad door switch (the fresh food doors must be closed to dispense), or a bad electronic control.
Jun 05, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
The arm on the ice cube maker is broken.
how to replace water dispensing paddle on a side by side
Apr 06, 2009 | Refrigerators
Water dispenser lever on door broken off.
Yes, the levers are easily ordered and replaced.
get manual, obtain part number, order part, replace part. use these websites for help http://www.retrevo.com/samples/Frigidaire-manuals.html#Refrigerator
https://www.appliancezone.com/
Oct 15, 2008 | Frigidaire FRS26R4A Side by Side...
Water will not dispense from door. ice machine works. it is a gold edition
listen closely when depressing the arm can you hear a switch being activated?? does the light come on when arm is depressed, if no to eitherr sounds like a faulty microswitch behind the dispenser if you do hear hte switch adn the light does come on then go to the back of unit and disconnect the plastic tubing leading to the dispenser the larger of the 2 plastichoses, place a cup under hte valve and depress the arm now(this way we eleminate the frozen of clogged hose. if still no water id say you have abad water valve( whoile back there you can also disconnect the wire leading to the water valve solenoid and check that for proper 110v when depressed.) if you got voltage andstill no water you def have a bad valve
Mar 16, 2008 | Refrigerators
Frigidaire PLHS267ZA Side by Side Refrigerator Logo
411 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
