Question about Mitsubishi WS-55859 55" Rear Projection Television
WS 55859 Sound no picture
I Have
  • 1 more comment
  • josie36 Dec 10, 2008
    Well I was reading around and I found out that if you hold the Device and Menu button then it will give you an error code. The error code that I am getting is 1,2. From what I read that means there is nothing wrong with the tv. Whenever I turn it on sometimes it will let me access the menu and when it does that the projecters are blinking as if they aren 't getting enough juice to power them. Do you think that this might just be the DM Module needing to be replaced, or something else? Please any help is appreciated the TV was free so I am willing to try anything to get it to wrk. Or email me at calferman@hotmail.com
  • josie36 Dec 13, 2008
    Well why would I rate your solution good when you just told me what I already knew. All you told me is something is failing, thanks alot I thought the tv was working just fine thats why I am asking for help...
  • tymnet Jan 25, 2009
    I have sort of the same problem except I can get a picture through DTV and ANT A, ANT B but not through any other video sources. even if I deslect progressive or no progressive.
  • 899 Answers
There are some components failing and it will need some testing and research to fix the video problem
Posted on Dec 10, 2008
  • jason Dec 10, 2008
    that rating you gave me really hurts our score , and only a fixya helps ,
  • jason Dec 11, 2008
    so , you are not showing any appreciation by rating me like that and then asking me for more info , as that rating is insulting
SOURCE: Green Screen
Did you find out anything? Mu 60" is doingthe same thing.
Posted on Jul 30, 2008
frcs68
  • 1605 Answers
SOURCE: Mitsubishi ws-55859 parts
time to get a new one.
even you get the main board, you might have other problem that has not show up yet.
Posted on Oct 14, 2008
SD Tech
  • 14553 Answers
SOURCE: Mitsubishi WS-55859 rear projection TV with a convergence problem
This set uses a single STK-393-110 CONVERGENCE IC---I will tell you what is needed and what is involved in this repair.
The chip can purchased on Ebay for about 14 dollars plus shipping--On Ebay select search, then advanced search, and then search by seller--look for: sewsales55 (the company is called Suburban Electronics and is in Maryland--I buy a lot of parts from them.)
Info is coming and let me know if you have any questions here or there.
I do this here for free so if this has helped you give me a vote here.
SD TECH
Posted on Sep 20, 2009
Testimonial: "Exactly what I needed and wanted to fix my issue! Thanks!!!"
SD Tech
  • 14553 Answers
SOURCE: mitsubishi model ws-55859 tv is red and red
If it is WS-55859 and you go into the customer menu and find red or blue are skewed and will not adjust---you have a convergence problem.
This model uses a single STK-393-110 convergence chip--it and any of the protect resistors around it that are bad will need to be replaced and the set adjusted.
The chip can be purchased on Ebay for about 12 dollars plus shipping--total parts cost should be under 30 dollars!
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS MODEL.
They tell you everything you will need and how to do the repair---If you or someone you know can do it I can post or get the instructions to you.
If you cannot do it shop around your area--most shops are going to get 300 or MORE for this kind of repair and many will not do in in your home--Any good tech can do it in your home in about 1 hour--I know as I have done hundreds of them.
If you have questions or need help let me know--I am here to help people.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Posted on Nov 11, 2009
  • 470 Answers
SOURCE: mitsubishi WS-55859 no picture have sound,flashing
Change DM caps
Posted on Nov 25, 2009
When I turn on the tv the green light blinks continuously. No picture no sound
This is a common problem with some parts failing in the DM module. You can get parts and repair instrucutions from www.TvRepairKit.com
Sep 23, 2010 | Mitsubishi WS-55859 55" Rear Projection...
I have a Mitsubishi WS- 55859 projection screen tv and the screen/lamp flashes on and off a couple of times then lamp go off but you can still hear static.The TV is on but not picture is getting to the...
The WS-55859 does not have a "Lamp" it is a 2001 rear projection set with three picture tubes.
Have (if this is the correct model) you tried the self check this set has?
Also do you have this problem on all inputs--tuner, and various rear inputs?
The more you tell me the better I can help you.
Got a IM?
SD TECH
Feb 23, 2010 | Mitsubishi WS-55859 55" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Tv does not turn on the green light blinks
bad DM board or capacitors. let me know if you want to attempt yourself, otherwise $200-400 repair..
Feb 02, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Sound ok on my WS-55859, but picture is only in BW
The problem is in the Video Circuit board. Chances are that an IC has failed or there is a cold solder joint on the board somewhere. Don't attempt to repair this problem unless you know exactly what you are doing. I suggest that you get an estimate before you have any repairs done and then do a cost of repair vs. replacement comparison.
Hope this helps you out.
Jan 03, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Oct 05, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Green Screen
Jul 26, 2008 | Mitsubishi WS-55859 55" Rear Projection...
TV needs to warm-up
Check the power setting in the menu. If it's set to low power, switch to standard.
Nov 11, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
