Question about Kitchen Appliances - Others
Garage door stops and reverses either way-up or down-
Have to continue pressing control and eventually it closes or opens. Sometimes just one press will work other times several are needed. have to keep pushing button to get door to close.
  • Anonymous Jan 06, 2009
    garage door stops and reverses either way-up or down-
  • Danny Clark
    Danny Clark May 11, 2010
    Is this only with the remote or the wall switch as well?
    Have you replaced the batteries in the remote?
  • 75 Answers
If the light on the opener flashes when this happens, count the flashes (which indicate the type of problem) and consult your owners manual.  If you don't have the owners manual, you can find a digital copy online at the manufacturer's website. Also, check your manual for an adjustment that tells the opener how much resistance you want it to tolerate before reversing.
Posted on Dec 22, 2008
Good Morning My name is Raj. I have a CRAFTSMAN Garage Door Opener 1/2 HP, model# 139.53635SRA (OR) T as the last letter. Issues: I cannot CLOSE Garage Door either with remotes or with key pad by...
If the main light flashes 10 times when the door reverses to the open position it is your door sensors. Make sure the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have bad sensors.
Sep 30, 2011 | Sears Craftsman LiftMaster Chamberlain...
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
When I try to close my garage door --4100 model-- the door travels part way down, then reverses and goes to the up position. I can force it closed by keeping the garage door wall switch continually...
Check your door sensors. Make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little. If you cannot get both lights to come on you have a bad sensor.
Dec 30, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftsman 1/2 Hp garage door opener doesn't stop going down despite (quite forcefully!) applying pressure in the opposite direction. It would buckle (and did) if I don't let it continue unhindered...do...
YOU NEED TO ADJUST THE DOWN FORCE.
YOU WANT TO TURN IT COUNTER CLOCKWISE TO THE STOP (THIS ADJUSTMENT IS ONLY ABOUT 3/4 TURN FROM MIN. TO MAX.). THEN TRY THE DOOR IF IT REVERSES TURN IT ABOUT 1/16TH TURN CLOCKWISE. CONTINUE THIS VERY MINOR INCRAMENT ADJUSTMENT UNTIL THE DOOR CLOSES WITHOUT REVERSING. THEN GO 1/16TH TURN FURTHER.
YOU SHOULD BE ABLE TO STOP THE DOOR AND REVERSE IT BY GRABBING THE BOTTOM OF THE DOOR AS IT GOES DOWN AND LIFTING SLIGHTLY. IF YOU CAN'T GET THE DOOR TO BOTH CLOSE AND REVERSE WITH MODERATE PRESSURE YOU MAY NEED ADJUSTMENT TO THE DOOR / SPRING / ETC.
- I DO NOT RECOMMEND ADJUSTING THE DOOR YOURSELF - CALL IN A PRO FOR THAT.
IF THE ADJUSTMENT IS SUCCESFUL ADJUST THE OPEN SENSITIVITY / FORCE IN THE SAME MANNER.
HOPE THIS HELPS
Jun 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
Can open with remote, or wall-mounted button, but cannot use remote to close, and have to hold wall button down continuously (unit blinks when button is pressed and released, and stops closing until button...
If the main light is flashing 10 times when the door reverses you have a door sensor problem. Make sure they are pointed at each other and the small light on each one is lit and not flickering. Tweak them if necessary. If you cannot get the small lights to both come on you have bad sensors.
Feb 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener will not continue to open garage door.
You say your door won't open and then you say your door won't close. Anyway you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you tweak them and the lights don't come on then you have either a wiring problem or a bad logic board.
Jul 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door hard to close have starts to close stops and starts to open again have to keep stopping and reversing door mult times to get closed
There should be two small white adjustment knobs on the side of the unit that you turn with a small flathead screwdriver. These are the load / limit adjusters.
What it happening is it think there is something stuck under the door (like a car hood, etc)
These adjustments are VERY sensitive, so be patient while adjusting them.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
SEARS/CRAFTSMAN 53628SRT Not Closing properly
sounds like the safety door sensors are at fault,also did you reprogram the remotes by pressing the smart button on the logic board,when the safety sensors are bad the door will reverse to open state.you can pully the rip cord to manualy close the door untill you solve the problem.
Sep 04, 2007 | Sears Craftsman LiftMaster Chamberlain...
Kitchen Appliances - Others Logo
383 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
