I cannot get any TV channels on my Sony TV
I have a (10 yrs old - and not used for 3 years) Sony 29" TV, which seems perfectly fine, except that I cannot seem to tune the TV channels either manually or automatically. The TV works perfectly as a monitor for my DVD player.
But I cannot seem to receive any of the free to air channels that I used to be able to get. (In Australia at this stage we have 5 free to air channels broadcasting in Analog UHF/VHF - though I think we go fully digital in 2010).
I have connected an old rabbit ears antenna (which works on my other smaller TV, so that seems OK). But no real signal shows up on the larger screen - just a vague black and white signal from only one station.
I am at a complete loss to understand why this is loss of signal is happening. All I have been able to come up with is that I suspect that the removalists who took the TV out of storage may have slightly knocked the aerial (coaxial?) input slightly, as it no longer seems exactly perpendicular to the set. The connection is not mangled or anything, just slightly off centre.
Could that cause this problem? Could some wiring internal to the aerial plug have been dislodged, and therefore the signal is not getting to the automatic tuner?
    Problem Solver:
  • 9 Answers
It sounds like you have identified the the correct problem, as the Coax connector has probably been knocked loose from the circuit board inside the TV. If you have any knowledge on this sort of thing you can take it apart and re solder the connections. If not I suggest you take it to be serviced by a professional.
Posted on Dec 10, 2008
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's...
A poor solder connection on B+ is the line, Horizontal drive transformer or at the base of Horizontal Output transistor can caused that. Re-soldering these section can fix it..
Oct 23, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My Sony trinitron tube Tv 36" seems to be going (its 10 years old
no ....the tube will end up after 20 yrs in 10 yr old sony...
it is worth if u fix it. randomly going black means...horizontal driver trans former is the problem..or any loose contact with the 110 volt supply to that transformer,,or any loose contact with line o/p transformer.. (horizontal driver transformer may be gone
then tv behaves like this) if any other parts gone tv wont come back.... there may be a loose contact call a service pro..
Apr 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
I have a Sony 32'' Trinitron that blinks off and on when turned on
I have a Sony Trinitron 32 color tv KV 2168MTJ (quite old - 10 yrs old), and the standby light blinks exactly 200 times (just over 3 mins) before it turns on. Once it is on, it works perfectly. What's wrong with it and how can i fix it?
Feb 07, 2010 | Sony Televison & Video
I have a new rca receiver and have it hooked up to my dvd player which works fine. I have it hooked into my tv and Im not getting sesurround through my tv how can I connect to the tv to make it work my tv...
Take a clue from the 10-year old vintage of the TV and the two analog audio cables. It's Dolby Pro Logic Surround at best, not Dolby Surround in the modern, digital, multi-channel sense.
TV's are not the source nor the end of a multi-channel audio chain. Feed this thing a 2-channel source from a Cable Box (into the "TV" jacks), DVD, Video Tape or CD with proper Dolby Surround encoding and will seem to open up the sound field a bit and kick in a little surround effect. It can also simulate a Hall effect and Dolby 3 stereo.
http://en.wikipedia.org/wiki/Dolby_Pro_Logic
Jan 27, 2010 | RCA RT2400R Receiver
3 horizontal lines through screen and distortion
Yes this thing start happening to my tv too about 4weeks ago and this goes away in about 15 minutes. TV is only 18 month old and I donot have extende warranty. Please post the solution if someone has got it repaired. Thanks
Dec 28, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
I have an old NEC TV, NEC MTS dbx Stereo reciever/monitor, from the 1980's. It has not be used in over five years and now I want to use it. Everything seems to work fine except I only get the first 14...
If there is no cable switch anywhere (make sure you check the back where the cable screws on) you will have to have a converter box to change channels with. When using a converter you put the TV on channel 3 or 4 and switch channels on the converter. Thanks
Oct 22, 2009 | Televison & Video
Sony c450 will not work with new 46" Samsung TV using compodent 3
are you sure that the channel your tv is on matches the name on the inputs where you plugged the component cables in? Channel surf-maybe start at 2 and go down and that is where those input channels should be.
Sep 01, 2009 | Sony DAV-C450 System
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
Sony TV Trinitron
I think you have K5 model, if so, replace the all the control switches under the tube, inside the flap.There are three columns of two switches.
Nov 09, 2006 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Televison & Video Logo
240 people viewed this question
Top Televison & Video Experts
