Question about Maxtor 6Y080P0 80GB Ultra ATA133 7200rpm 8MB Hard Drive (HDMX80A7P)
The noise on hard disck
Dear... my hard disk is 80gb maxtor type and was worked until today. now, during copy of large files, such as 1gb, it makes bad noises. this voice is like to interaction between two metallic things, like this: "chick... chick. chick...chick...? this problem only occurs during copying large files. i run the check disk program on all derives but the problem not solve. i check all cables and ports related to hard, too. at the end i thank you for your help.
    Scholar:
  • 119 Answers
The drive is starting to fail. back up your data & star getting prices on a replacement drive. you can go to maxtor.com & download a promram called powermax. it is a dos based program that is made by maxtor to test there drives. it usually needs a floppy disk. there is no repair for this type of fault in a drive. but powermax may give you a little more info. on you drive. good luck
Posted on Feb 28, 2007
I get error code 1802 on ibm thinkpad r40
THE SOLUTIONThe solution to this error is to make sure that there is sufficient disk space to hold the files that Windows Installer has to copy to the hard drive. Removal of unnecessary files in the hard drive until the free space is large enough to hold the files being copied is the remedy for this problem. you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
Jan 22, 2011 | Computers & Internet
Windows -Delayed write failed. Windows was unable to save all the data for the file D:\$MFT
You've got a "hardware" problem with the disk-drive. Windows cannot write an updated 'MFT' ("Master File Table") to reflect files that you have added/deleted/updated on the Maxtor.
Copy all the files from the Maxtor, e.g., onto another external drive, or "burning" to DVD disks, and then replace the Maxtor disk-drive.
Dec 31, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I am afraid of losing my pictures on it. I have always been able to get into them and now it is asking me to format. Won't that lose my files Maxtor Personal Storage 3100 7200 RPM 80GB USB 2.0 When ever...
Try this:
1. Plug Maxtor External Hard Drive into your computer
2. Go To Computer
3. Right click on the Drive
4. Click Properties
5. Go To Tools
6. Run an Error Check.
That should help, if not let me know so we can proceed with something else
Aug 11, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
My laptop no longer recognizes my external hard drive. Device Manager gives me an error code 10.
Connect the Maxtor to a different computer, to see if the device works in some other computer.
If the warranty is still valid, exercise the warranty to get a replacement.
If the warranty has expired, disassemble the casing, and disconnect the USB-to-disk-drive interface from the disk-drive.
Connect the disk-drive as a "slave" disk-drive in some other computer, to see if the USB-to-disk-drive interface is the part that failed.
If all else fails, search online for commercial "data recovery services" -- for a large amount of money, they will disassemble the disk-drive, repair it, just long-enough to copy your files.
Aug 09, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor DiamondMax Plus 9 80GB 6Y080L YAR41BW0 internal hard drive not working think it might be the PCB Board not working.
It's possible that you're correct.
However, finding a Maxtor drive with an identical PCB is not going to be easy. Once you do, you can disconnect the "spinning" part of the disk-drive away from the PCB, and then swap PCB, and see if you can then QUICKLY(!) copy all 80GB to a "new" disk-drive.
Dec 05, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
How to format maxtor 80gb hard drive
Insert the drive into the bay and connect power and ribbon cable.
Go to Start > Control Panel > Administrative Tools >
Computer Management > Storage > Disk Management
Right click on the drive, click Mark Partition as Active then Format.
In this day and age, it's always best to format to NTFS file system.
Nov 06, 2009 | Maxtor Hard Drive
Maxtor mini one touch 4
When you were in device manager did you notice if it was enabled? Did you try to force install the hardware somewhere else, or did you try to change what driver was used?
Ryan Frame
Creative Energy Associates Technical Center
Aug 24, 2009 | Seagate 80GB One Touch 4 Mini-maxtor USB...
IO Device Error
My Maxtor died like this. The disk was OK, it was the electronics that blew. I bought a new empty disk drive box and fitted the disk drive and fixed it. Years later the disk still works in the replacement box and power supply. I got my files and data back with the disk drive in the new box. The size of that disk looks small today. It may be Parallel (PATA) and you need a PATA box, that is harder to find as obsolete. You need to try the disk first in another drive holder.
So PATA and SATA??? Look here and read up about it with pictures too:
https://askleo.com/whats_the_difference_between_sata_and_pata_and_ide/
An external disk unit has three main parts.
1. The disk drive.
2. The electronics box.
3. The power supply.
Sep 08, 2017 | Maxtor One Touch (RBAY080B0USR) Hard Drive
Hard drive
hi dear
use a cd booting
in command prompt c:\
type c:\fdisk /mbr
to fix your master boot record\
fdisk
and make your partiiton active.
after that installing your windows XP
oke
cropp
Mar 15, 2008 | Maxtor Hard Drive
My local hard disk (c: drive) become not accessible
If it's an IDE you can slave it into a working system & hopefully see it & copy the data off. If it's a seiral ATA SATA I/II, you'll need to add it to a working system. (All SATA's are masters). Again if seen, try to copy your data off. In both types it's a shot worth taking. Luck!
Maxtor's support page.
http://www.maxtorsolutions.com/en/Main/support.shtml
Feb 11, 2008 | Maxtor Hard Drive
Maxtor 6Y080P0 80GB Ultra ATA133 7200rpm 8MB Hard Drive (HDMX80A7P) Logo
162 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
