Question about Hotpoint WMA32 Front Load Washer
Hot point washing machine WMA 32
The washing machine trips the RCCB on the consumer unit when on full load. Any ideas how to solve it My guess is that the motor on full load has a earth fault or drawing excess current Does this mean I have to change the motor, if so is it straight forward I am pretty good with tools. Thanks for you help Tony
  • 247 Answers
It's unusual for a household RCD to go out on excess current from an appliance - the fuse in the plug top and circuit fuse/MCB in the consumer unit should provide closer protection. This leaves you with an earth fault. Earth faults aren't usually related to motor load. Watch carefully what phase of the cycle the trip happens. Does it correlate with the start of water heating? A very frequent cause of low current earth faults is water ingress into the heating element. If you can trip the RCD reliably on every cycle, running the same cycle with the element disconnected would confirm whether or not this is the cause. A.
Posted on Feb 28, 2007
Hi, i go into the test mode and it starts on 18 and when it gets to 14 the house electricity power trips off.Any idea what part do i need to replace?
How can I figure out why my washing machine is tripping the ...
diy.stackexchange.com/.../how-can-i-figure-out-why-my-washing-machi...
Aug 17, 2012 - 110.24872300) washing machine which up to this point has been ...Note what is happening when it trips (is it starting to spin, starting to drain, filling, etc.).... If the outlet trips when the washing machine isn't running and isn't ...
Washing machine tripping RCD « Singletrack Forum
singletrackworld.com/forum/topic/washing-machine-tripping-rcd
Switching on the plug socket that the washing machine's plugged into caused no problems, but switching the machine itself on trips the RCD. ... then its possibly the water fill solenoid as most cycles start with a water fill. ... I've always guessed it is theelectricity/water combo somewhere in the machine so err on the side of ...
Nov 29, 2015 | Washing Machines
Samsung WF-R1061 washing machine repeatedly trips
does it show an error code ? when it trips what is the washer doing filling water or spinning etc ? does it work on other settings like spin and drain with out tripping. ?
May 27, 2017 | Washing Machines
Light of a red tap
This is indicating a problem with the water supply, check the inlet hose/s for a restriction or kink in the hose/s.
Make sure the tap/s are fully turned on, and that there is a good water prerssure.
May 27, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA 32 washing m/c noisy drum
is poss bearings or something stuck between the inner and outer drum
Jan 03, 2010 | Washing Machines
Beko eco care WMA 10W: The washing is always very
eko eco care wma10w is making loud noise when on full spin, have looked at belt seems to be fine
Nov 19, 2009 | Washing Machines
Hotpoint fault?
Check the drain and circulation hoses for partial blockages as usually this causes such problems. Also make sure you using program with full speed spin cycle (solid spiral sign just before the dot pointing the end of chosen programme)
Mar 01, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint WMA 32 broken wires on Motor?
This has to be the pick up for the fast spin as any other would disable the motor.
Dec 20, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Kenmore oasis top-loader problem
You might try using the clean washer cycle, works on mine. I use the full amount of bleach allowed. No more smell...now if I can just get that pesky beeping noise to stop...
Dec 05, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Hotpoint WMA32 Front Load Washer Logo
262 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
