Question about Desa International (R165DT) Utility Heater
165 heater is making alot of smoke
I have been using my heater for 2 weeks and it is only on the second tankful of fuel. It is producing a lot of smoke when it is running, which it did not do on the first tank of fuel. I am using #2 diesel fuel.
    Problem Solver:
  • 7 Answers
Smoke is an indication of an improper air/fuel mixture, partially blocked nozzle or blocked air passages.
Kerosene must be atomized and mixed with the right amount of air to burn without smoke and odor.
You should consult your manual to have a guide to resolving the issue.
1. Make sure pump pressure is set accurate (5.6 p.s.i.). The pump controls the air/fuel mixture.
2. remove nozzle and clean with brush and compressed air. Also inspect rear of combustion chamber where air flows into and around the chamber to ensure proper air flow. Any materials that may be bent should be replaced. If not formed properly, the air flow through the heater changes as a result.
Posted on Mar 29, 2009
  • David Hagans
    David Hagans Mar 29, 2009
    diesel will make a noticeable change vs. kerosene, but should not produce smoke unless the fuel is contaminated. Remove the fuel pick-up tube from the tank, place into a clean one quart far of k1 kerosene sitting next to the tank. see if the burn is cleaner with new fuel
When the heater is turned up to a higher btu , it cuts off after a short time
What size tank? when it's really cold a small tank will not produce enough vapor fast enough. It could be a weak valve in the tank snap'n shut If the fuel comes out to fast. Could also be high temp switch on back of burner going bad. That happens alot.
Feb 19, 2015 | Reddy Heater-30-55,000 BTU Variable
Mower will start but blows lots of white smoke and dies when throttle is moved to full
sounds like to much oil but you say the oil level is fine. you may want to check the compression on the head to see if the head gasket is blown. if there is a lot of smoke or oil blowing out the oil tube, that is a sign of blown head gasket.
Nov 27, 2017 | Ariens Garden
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
FUEL FILTER
(For 40/55/60/70/110/115/155/165 Models
Only)
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Unit fires and flame seems to skip seems to go out for a half second then pops and burns again untill next skip. flam continus to burn and will heat popping is anoning. when first lights will smoke and...
Sounds like there might be some water in the fuel?
Take a strong flashlight, and shine it into the tank-- does it look dirty?-- can you see water on the bottom? Try draining and cleaning the tank, and make sure the suction filter is clean-- and in tact.
And yo are using kerosene-- not diesel fuel, right?
Mack B
Jan 19, 2011 | Reddy R115DT Oil Filled Utility Heater
100,000 btu reddy heater runs but smokes alot and you can smell raw fuel what's wrong
It sounds like the fuel is contaminated,if it is not k 1 kerosene ,or grade A diesel fuel,this could be the problem,clean the tank,and start with a k 1 kerosene,and see if it clears up,then go back to the grade A diesel fuel,if this does not work,replace the filter in the tank,and check the intake air filter,make sure it is not cloded up,or behind the filter,last thing ,only after checking and doing all of this,the pump pressure may need adjusting,but do not try this with out a pressure gauge,and a manual .You can break the pump easy.I have a manual for the ready heater,just let me no if you need it,please rate,thank yopu,> roniecon@gmail.com
Jan 05, 2011 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
I have a master 150000 btu kerosene direct fire heater that runs for 5 minutes then shuts down and blows white smoke. what is the problem?
The white smoke is the kerosene fuel hitting the hot combustion chamber. Your flame has went out. The cause for this could be many. The first thing you need to do is check your fuel. Remove your fuel cap and look at the bottom of the tank for trash or water. Use a good flash light. It will all settle to the bottom. If so, drain and clean out your tank. Add fresh kerosene. Check your fuel filter. Replace if dirty. Test again. If problem continues, It is possible that your photo eye could be deffective or just dirty. It is located next to the ignitor or spark plug. It sees the flame. If the flame goes out, the unit shuts down. The flame has to be smooth (not sputtering). Water in the fuel will make it sputter and the unit will shut down. When the water/moisture in tank settles to the bottom, your suction fuel line is just off the bottom which results in it picking up the water instead of good fuel. Always disgard the old fuel from previous year and start with fresh fuel. This will cut down alot of your problems in the future.
Dec 07, 2010 | Master Heaters B155DST
What is the gas and fuel mixture for a homelite st-185 weed eater
If it's not been started for that long, ensure that any remaining crud in the tank and fuel lines is cleaned out before even attempting to start it.
Put in a NEW plug, then mix up some 50:1 mix of unleaded and good synthetic 2-stroke oil (Sthil or similar). This will produce an almost smoke-free exhaust, and won't foul the plug.
If it does start, be prepared for LOTS of smoke initially, as all the old oil from inside the engine burns off.
May 12, 2010 | Homelite Mighty Lite Lawn Trimmer
Gas line broke at top of gas tank fuel filter loose in gas tank
You may find these helpful. Typical fuel system:
5114cbb.gif No model provided; may not have primer.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
HTH
Lou
Dec 20, 2009 | Husqvarna Garden
Clicks but wont fire
make sure the high voltage lead to the sparkplug isn't touching anything metal on its way to the plug. the clicking may be the high voltage discharging to a metal part, not the plug. those wires age during use.
Dec 01, 2007 | Reddy R70ET Utility Heater
Desa International (R165DT) Utility Heater Logo
241 people viewed this question
Top Desa International Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Desa International Heating and Cooling Expert? Answer questions, earn points and help others
