How to connect RECOTON S-VIDEO SWITCH SVS1000 to TV and VIDEO. How to make other set ups.
What is the remote code for this model?
Codes are stored in the remote. A Recoton remote should be able to control your Recoton TV directly. If you are trying to use a universal remote, it should have a code search feature you can use to search for a suitable code.
Jun 17, 2015 | Recoton Advent Advent Q2035A 20" TV
Advent tv codes How do I set up the remote to recieve the code? Do I hold down the set or TV button?
0038,0031,0033,0036. Try these codes. If you wish to get more codes and other details. It has setup code list, and setup procedure to many popular brand remote controls.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Dec 31, 2013 | Recoton Advent Advent ADR-560 Remote...
Advent universal remote codes for hitachi tv
Set up codes for Hitachi TV are: 0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Jul 29, 2012 | Recoton Advent Advent ADR-560 Remote...
Advent tv displays green
If you are saying no red: The model indicated here Recoton Advent Advent Q1435A TV is a 14 inch set.
first it may be cheaper to replace than repair--That said if no red look to the small circuit board at end of picture tube (it plugs onto the tube).
It will have either individual output transistors or a single IC.
What (if only one color missing) I would look at is the bottom side which faces to the rear---a circle of solder connections--possible one is broken--there will be one for each red, green, and blue--not always easy to see but if any of the solder connections look cracked or even broken loose-----
Mar 28, 2012 | Recoton Advent Advent Q1435A TV
Advent tv indoor antenna hook up
If the antenna has a cable like cable wire--hook it direct to the cable fitting on the set.
If the antenna uses the flat type wire (called 300 ohm twin wire) use an adapter that will connect to the end and have screws for the flat wires and a cable slide on the other side to slide onto the cable fitting on the rear of the TV
Mar 28, 2012 | Recoton Advent Advent DV1418A 14 in....
Need info on a Recoton Antenna -need to know DC imput amt etc.
that coaxial cable with male end has to be connected to '' tv antenna in '' connector of your tv ....... to find whether any ac adaptor is required for your indoor antenna just observe all sides of that antenna ....... if any male or female connector is there means definitely it requires adaptor ( size will be smaller then coaxial cable's male end connector ) .... click 1 st link to see whether your antenna is like that ..... if no means check 2nd link ............ once your antenna's model no is identified it will be easy to clear all doubts ....... it may require 9 volts or 12 volts adaptor ..... Recoton's universal adaptor is available ( check 3rd link ) ...... so check these links & tell us .... then we can find exact details of your antenna .......... if possible take picture of your antenna (all sides) & email to me (sathyavijayasarathibabu@ymail.com ) ....
http://www.orbitcommunications.com/cyberstore/product.asp?PID=TV-800
http://www.google.co.in/search?tbm=isch&hl=en&source=hp&biw=1024&bih=527&q=recoton+tv+indoor+antenna&btnG=Search+images&gbv=2&oq=recoton+tv+indoor+antenna&aq=f&aqi=&gs_upl=0l0l0l3719l0l0l0l0l0l0l0l0ll0l0&sout=0&sa=X&ei=Ze-2Tq7BIM7HrQf4vbjcAw&ved=0CDYQxxQ
http://www.futureshop.ca/en-CA/product/recoton-universal-ac-adapter-ad500-500ma/80730005.aspx
Nov 06, 2011 | Televison & Video
Can i get a s video on my dv1418a tv/dvd combo???
In the back of TV\DVD next to RCA jacks & plugs is the S-video
Feb 15, 2011 | Recoton Advent Advent DV1418A 14 in....
No picture on my xtrons d708
Its an installation issue to prevent you watching while driving.The default install requires a wire to be connected to the switch on the handbrake which activates the warning light, this works by supplying an earth when the handbrake is applied if you earth this wire the display will be activated.
Mar 25, 2010 | Recoton Advent XTRON TTL 12" XTRON MONITOR
Cant connect wireless internet connection
pls configure first WAN setting WI FI AREA NETWORK,IP address connection from the router wi fi,subnet, and protocol.
May 10, 2009 | Recoton Advent Advent Q2035A 20" TV
Need to switch internet function on advent 4489
prees the funtion key ( blue Fn, bottom left ) and F11.
you may have to do this every time you turn on your netbook.
Jan 04, 2009 | Recoton Advent Advent Q2035A 20" TV
Televison & Video Logo
370 people viewed this question
Top Televison & Video Experts
