Question about Toshiba 36A40 36" TV
Toshiba 36" picture compressed to single line in middle of screen
Sound okay.
  • zimmyfan Feb 20, 2009
    I have a toshiba 32a40 TV and also get a thin line in the middle of the TV. If I hit the side or top, it comes back, but it is happening more frequently. Did you ever get yours repaired? what did it cost?
Thanks for the help. will have to get to authorized
dealer to see if it works.
Posted on Dec 11, 2008
  • 60 Answers
There is a problem with vertical baleiage on your screen and need one ic changed but you cant do that yourself need to go in authorized service
Posted on Dec 10, 2008
Toshiba TV picture has become single horizontal line in middle
this problem is caused by a faulty ir of cap's . First is c408 on the board it is a 100uf @ 35v i replaced with same uf and @ 50v , Second is a 2.2uf @250v and is c410 on the board replace both and your off to the races.
BEWARE OF HIGH VOLTAGE EVEN IF UNPLUGGED
BROUGHT TO YOU BY WWW.JCEWASTE.COM
Jul 22, 2010 | Toshiba 27AF43 27" TV
No picture.Just a single line in middle of screen.
No, your picture tube is fine. This is a problem in the vertical circuit that deflects the beam up and down. This repair is fairly typical across most television brands and should not cost too much to fix. I don't want to quote another shops pricing but from us this would run about $150.00 to fix.
Oct 07, 2009 | Toshiba CF36G40 36" TV
Toshiba TV (about 7 years old)
You had parts in the vertical deflection circuit failing, most common are the vertical output IC and possibly several capacitors also in the same circuit.
Sep 11, 2009 | Toshiba 36A50 36" TV
Toshiba 36A50 sound, light line horizonally on black screen
It is my guess that you have some intermitent solder connections in the Vertical output circuit.
Hope this helps,
Skyassoc
Jun 23, 2009 | Toshiba 36A40 36" TV
Picture only in middle of screen
Sounds like vertical problems on your circuit board. Unless you have some electronics experience you'd better take it in for repair.
The inside of a tube TV contains high voltages even when off and unplugged.
GL
Oct 04, 2008 | Toshiba 36A50 36" TV
Tv trouble
Sorry, I can't help you with the computer password issue but I can help you with the TV.
The problem you are having is a vertical deflection problem. The screen is being compressed to a thin white line. It's probably a defective vertical output module or transistor. This part is not too expensive. Less likely would be a vertical deflection coil, which would be more expensive because its usually glued to the picture tube and harder to replace. You'll need to take your set to service center to have it serviced.
Good Luck!
- Jim
Feb 08, 2008 | Toshiba 36A61 36" TV
Toshiba 36A50 Horizontal Line in the middle
  • the problem is most common & simple to repair at your home only at minimum cost by skilled technician.
  • as per problem is concern it is due to electrolytic capacitor failure in vertical output stage.
  • hope this will help
  • good luck.
Oct 21, 2007 | Toshiba 36A50 36" TV
Toshiba 36AF43 36" just has white line in the center
vertical output IC has loose solder joints.if you continue to let it operate this way it will etch a burn line across the face of the tube so discontinue use.
Aug 22, 2007 | Toshiba 36AF43 36" TV
Toshiba 36A40 36" TV Logo
394 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
