Question about Kitchen Appliances - Others
Smell Coming From Intertherm Furnace
This started yesterday. When the furnace comes on there is a ''fumes'' like smell going throughout the entire house. Any idea what could be causing this?
  • 334 Answers
It could be several things.
The most alarming being a cracked heat exchanger allowing the exhaust fumes to enter the living space.
Exhaust fumes that contain carbon monoxide.
I HIGHLY RECCOMEND that you purchase carbon monoxide detectors, and/or check the batteries in any you might already have.
Carbon monoxide can be deadly at high concentrations.
It could be burning wires, but would smell like burnt rubber.
It could be mold/mildew but would smell musty like dirty socks.
It could be a build up of dust oil etc on the heat exchanger, but that is usually only smelled when it is started up for the first time in months.
Make sure the filters are clean. Dirty filters can cause overheating of the heat exchanger and sometimes cause smells.
This is one of those times I will recommend you have a professional look at your unit.
Specifically the heat exchanger to look for cracks.
A pro will know where to look, where the usual stress points are etc.
Posted on Dec 10, 2008
I had a Dettson oil furnace Model # AMP112SDMB just installed this year. I have fumes? (smell) coming from the venting. The company has been back ... but do not think I have a problem.
It depends on what silicone they have used it might not be the correct one for use on venting hence the smell, As you know being a tech heated silicone does smell .
Dec 16, 2016 | Heating & Cooling
I took my blend air 11 Coleman stuff off my furnace now furnace smells bad and filters are black with is wrong
Not clear on what you took off ? The black could be soot the smell could be fumes !!
Sep 15, 2016 | Heating & Cooling
I have in Intertherm gas furnace. The system runs, hot air comes out of the vents, but it smells like burnt plastic, and the red light on the circuit board is lit up...
There is a short circuit developing in an electrical circuit in the furnace. Do not turn it back on and call a service technician to examine it.
Jan 10, 2015 | Intertherm Heating & Cooling
Smell fumes like exhaust when furnace comes on
You really, really need to get your furnace checked by an HVAC (Heating, Ventilation and Air Conditioning) expert. Your furnace has a section where the fire heats tubes that air is blown across then out to your home to heat it. The air in your home and the air from the combustion process should never mix. If you smell exhaust, it's possible there is a breakdown in this part of the furnace and exhaust, which can include carbon monoxide, could be pulled into the air stream and be circulated in your home. Carbon monoxide can and will make you go to sleep and not wake up! Do not use the furnace until you get it checked.
Feb 08, 2013 | Goodman Furnace Draft Inducer Blower ...
This will be our third winter in our home, and for some reason this years when we run the heater it smells. The smell is similar to a stinky bathroom odor (that's the best way I can describe it). I...
Contact your Gas company tell them you have a foul smell coming in when you turn on the heater. They typically wont charge for a technician to come out and inspect the heater for you.
Nov 15, 2010 | Heating & Cooling
It sounds like the Furnace is making my mobile home knock in different places throughout my home. It is not the furnace itself, but the ducting coming off the furnace I believe. It only does it in a few...
If you are continuing to hear the sounds after the system has shut down completely, you might want to consider a pest control problem. Unless your ductwork is sheetmetal throughout it's entire length, Vermin can (and will) cut their way through ductboard and Flex Ducts. This is especially a problem during the winter months as they are trying to find heat. All of your ductwork needs to be inspected and repaired as necessary. During the inspection of the duct, you need to observe for any signs of vermin (urine stains, droppings, etc).
Having a vermin problem is something that is very common; hence why there are so many companies in business to help people deal with the problem.
I hope you found this advice helpful. Good Luck! :-)
Mar 07, 2010 | Intertherm P3RA-048K Air Conditioner
Furnace shuts off once the flame comes on.
You are having problems with your air/fuel mixture. It would be best to call a tech that knows how to work with propane. This type of problem is fairly common when using propane.
Aug 19, 2009 | Intertherm P3RA-048K Air Conditioner
Odor coming from furnace when running a/c
Sounds like your heating elements are coming on with the A/C This can be from an improperly wire thermostat or furnace.
May 30, 2009 | Goodman CKL24AR24 Air Conditioner
We have a Intertherm MAC 1378 gas furnace in out mobile home and it has shut off on us. There is still gas coming in, we checked the meter outside to be sure. But when we try to reignite the pilot light it...
Check to make sure the roof vent is not covered over with snow.
Very deep snow can block the intake to the furnace. You may need a ladder and a broom (or shovel) to clear the snow.
Hope this helps.
Jan 03, 2009 | Heating & Cooling
Intertherm furnace..not working right
if i understand your problem description correctly when power is on but the furnace is not running you can smell burning dust and feel heat? first thing i can think of is possible a heater relay has gone bad keeping the heater on all the time but no fan...
Dec 12, 2007 | Heating & Cooling
Kitchen Appliances - Others Logo
450 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
