I have only used my camera once or twice and put it away because i always said i would fix it later. Can this be fixed or should i get a new camera?
SOURCE: samsung sc-D363
I had the same problem. The batteries do not last. When the battery becomes weak it can not run the tape so it tells you to eject it.
Buy a new bigger battery. I bought a 160 for ~$30.
SOURCE: Samsung SC-D363 Mini DV digital camcorder
sir if your camcorder is new then it has a warranty. we should send it first for their service because they have a spare parts for replacement and info. if your going to fix it by yourself then the warranty of that will be void. by the way the place for the service center for camcorder samsung in the philippines is in makati i think. i got a problem with my samsung just like your model and they told me that it is located at makati. hope that helps!
CHARCOIS
SOURCE: Samsung mini DV sc-D366 always displays eject
I believe your problem is in the drum motor assembly part No is AD97-10579A. Samsung they know that problem it require a Technician to replace this part because you must adjust electronic and sometime mechnism as well. Depend which country you are it might cover under warranty even your CAM is out of warranty just check with Samsung in your area
SOURCE: how do i clean the video head without a cleaning
I'd strongly suggest getting a cleaning tape recommended by the manufacturer or taking it to be professionally cleaned. It's very easy to cause expensive damage to the tiny parts.
This is usually caused by an oxidized or defective Audio/Video drum. Try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
i have the same eject D and power issue ? does anyone know any solutions ?
