Question about Bosch WFMC 3200 Front Load Washer
I need a replacement rubber seal for my Boch front laod washer Model# wfmc3200uc/01. I also need the plastic peice that holds this seal in place. I have only had this washer for a little under 1 year is there some type of factory warranty that would cover this.
  • yerkesa Mar 30, 2009
    RUBBER ON MY FRONT LOADING BOSCH IS LEAKING. I HAVE HAD THE WASHER FOR ABOUT 5 YEARS WITH NO COMPLAINTS. SHOULD THIS BE LEAKING AFTER THIS MUCH USE.
  • 70 Answers
It all come in one kit: plastic front cover and boot gasket.
Part # 246270.
Manufacture warranty for Bosch washer 1 year from day of purchase.
For assistance with your Bosch home appliance
or to order spare parts
1-800-944-2904
MON - FRI ~ 5AM - 8PM PST
Also you can buy from here:
http://www.marcone.com/
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Posted on Dec 10, 2008
NEXXT 300 FRONT LOAD WASHER SHOWS CODE E-01. DOOR WILL NOT OPEN AND THE HOW TO VIDEOS ARE ALL FOR MACHINES WITH COMPLETELY ROUND DOORS, THIS MACHINE DOOR HAS LARGE PORT HOLE IN A SORT OF THUMB SHAPED DOOR....
Have you tried powering off/disconnecting the power cord to the wall? Then try plugging it in and turning it on - it may revert to the default "unlocked door" state.
If the door is still locked there is generally a manual release that is accessed from a panel that you need to remove below the door lock mechanism. On my model I had to prop up the front of the washer to access the screws - the panel runs the full width of the washer in my case. Once the panel is removed you should find a plastic rod hanging down from the lock that you pull down on - and then open the door at the same time.
My door lock mechanism went bad on my Bosch washer and I had to replace it - but it did give me a warning (though I wasn't sure what was going on at first). My washer makes a loud noise when locking/unlocking the door - that's the solenoid engaging/dis-engaging. In my case it started making that noise more than just once - first a couple of times, then 3 or 4, then finally about 8 times before it gave up the ghost a week or so later.
There are a bunch of videos online that are generic in nature about how to replace that door locks on front load washers... but essentially you need to remove the retaining spring/wire that is holding the rubber seal onto the washer opening, then peel the rubber seal away from the washer to allow access to the door lock mechanism. Replace and reverse the process.
Feb 22, 2015 | Bosch Washing Machines
Can't get retaining rings back on boot gasket on Bosch 3200uc
You can google for them or look on this site Fixya for spares.
Mar 19, 2013 | Bosch WFMC 3200 Front Load Washer
How do I remove door seal from wfmc3200uc/01
Bosch wfmc3200 uc/01 Front load washer how to change door seal.
This video will show you how to change a door seal on this Bosch front loader washing machine.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 17, 2012 | Bosch Washing Machines
Need instructions for moving -- have four bolts!
Hi.
Here the full set of instructions for the model Bosch WFMC 3200 posted in title:
WFMC3200UC/01 Manual 1
WFMC3200UC/01 Manual 2
Here repair manual available for $9.95.
Regards.
Ginko
Jun 07, 2011 | Bosch WFMC 3200 Front Load Washer
Villeroy & boch flush mechenism needs to be replaced
This problem is either two things:
1/ The water inlet valve is letting by and going down the overflow pipe. (Connected to the main centre column). You can check this by taking off the lid off.
2/ Centre column seal at the base is letting by. You can unclick the centre column by pushing the two paddles either side.
Then lift out the centre column and check the grey washer at the base. You can turn this washer around and see if this solves - if not the column has probably has a part snap off.
You can get spares here:
http://bathroomstudio.co.uk/villeroy-boch-spares/cat_131.html
May 27, 2009 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
Water leaking from white plastic peice under washer
If this piece had 2 hoses attached and slides onto the motor, then it is the pump. you will need to replace it. Part # 3363394 available both new (27.99) and used (9.99) from timerking.com Hope this helps!
Jan 07, 2009 | Roper RAS6233KQ Top Load Washer
Replacing door seal rubber boot
Hi its just a peice of wire with a spring tensioner just pull the door seal free" towards side of machine not forward" it will come .....then you will see wire ! you will kick yourself when you see.... it i did lol
Tommy-B-
Oct 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Front Door Seal
Call the Customer Service number located in your manual. Discribe to them what you have said here and they will send one to you for FREE! This is a problem that should NOT happen.
Moving forward, once you get it spray it down with Lysol Mold and Mildew Prevention and let it dry a couple of days before you install it.
May 13, 2008 | Washing Machines
BOSCH WFMC3200UC WASHER
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Apr 28, 2008 | Bosch WFMC 3200 Front Load Washer
Bosch WFMC 3200 Front Load Washer Logo
637 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
