Question about Photography
Nikon F3 w/MD4 motor drive...Not working!
Hi...I just won (at a local auction) a well cared for Nikon F3 w/ Md4 motor drive...I just replaced all the batteries...camera and drive ( and yes they are in correctly).. When I turn the power switch on, I get a reading of...m 80; but I can't advance the film manually or with the drive? Any help would be greatly appreciated...Tony PS... I also can't get the shutter to trip...
  • cardellina Dec 10, 2008
    Hi
    spotatohead Thanks for your help....If I manually pull the manual shutter release down, the shutter will trip and advance the film...if I hold it down it will take multible pictures; but I still can't advance the film advance by my thumb? Any more advice will be thankfull....Tony
    Scholar:
  • 95 Answers
Check to see if the manual shutter release (the one that is to the left of the lens when you look at the camera head on) is not cocked and ready. It should have its lever resting against the lens collar. Since this is the manual release of 1/80 second, this can sometimes be the cause of the problem. Also, make sure the shutter speed dial is set to something other than the 80 speed.
Since you can get a reading on the light meter, its likely not a power issue, plus the F3 is capabale of pulling power either from the drive or from the battery compartment.
Sometimes the electronic F3 shutter button can seize due to lack of exercise. The curtains won't need placing unless they are worn, but the switch may need replacing.
Posted on Dec 10, 2008
Nikon f3 jamming
As you haven't given any specific details regarding exactly how your camera is jamming then the only answer is that your camera needs a professional strip down and clean.
If you're lucky then the jam is simply due to the camera being old and gummed-up due to dried-out lubricant films, but it could also be due to parts failing due to wear and tear.
The F3 is definitely not suited to DIY repairs, and a freshly-serviced and functional F3 should be good for many more years of service. There are also plenty of them about, so repairers are familiar with them and will usually have a stock of new and used spare parts.
The only thing you can try is to see whether the jamming occurs with just one particular lens. If so then it's the lens which needs servicing/replacement rather than the camera, but a preventative CLA (Clean, Lubricate, Adjust) service on the F3 would still be advisable as they were intended to be regularly serviced. If the camera has its original foam light seals and mirror buffer then they will also be either decayed into sticky corrosive black goo by now or have gone further and dried-out and crumbled away. A routine CLA will usually include seal and buffer replacement as a one-off additional cost and as modern materials do not decay it should never need doing again.
Sep 24, 2011 | Nikon Photography
I've got Nikon F65. I cannot load film. The motor which load up the film doesn't move at all. Please help!
I don't know this model but you can try this.Drop the film canister in and pull the film strip out and place on the film advance sprocket.Rotate the sprocket by hand/thumb until film is seated (1 turn). If the auto feed is working you will be OK. 2 other things ,1 of course load film in dark area, 2 check the batteries on the camera first, if they are week your film advance wont work ,Good Luck.
Jul 29, 2011 | Nikon Photography
I have a Nikon F601 and I put a 400 iso film recently and I sort of didnt know how to load it on properly so I pressed the shutter release button as I loaded it twice when youre only suppose to press it...
Remove the lense, or the film if you're willing to waste it, and check to be sure the shutter blades aren't damaged. It'll be fairly evident if they are. If they are, the camera is pretty much now a paperweight. I hate to tell you that - but shutter replacements are VERY expensive and parts for most of these models no longer available from Nikon.
If that is not the issue, set the mode dial to M and try to take a shot. If that also doesn't work, either the batteries are exhausted or there is an internal issue in the camera. At this point, try new batteries. If that also gets you nowhere, you'll need to seek a reputable service tech, either through Nikon directly, locally if you can find one, or online/mail-order. If you have to go mail-order/online I'd recommend KEH Camera out of Atlanta, GA. They are very reasonable, have decent turn around, and do good work - but expect at least 1 month without your camera.
In M(anual) mode, be sure the lense is also set to M, via the switch on the front of the camera near the lense mount. You're not worrying about the quality of the image, only if the camera will take one. In manual mode, the light meter and other functions will have NO bearing on anything the camera does or doesn't do. At this point the meter reads out only for your information for you to set the settings yourself. The batteries do everything else - firing the shutter, driving the motor, etc.
Jul 21, 2011 | Nikon Photography
Nikkormat 35mm SLR light meter not working!
1) Clean the battery contacts and put fresh battery.
2) Open the top cover and clean the meter switch ( located and the wind cam )
3) Meter needle maybe stuck at the rest position. Remove the stopper and replace or clean.
4) If none of these help, check the meter cells and resistor band under the shutter dial behind the lens mount ( hard to do.)
Jun 14, 2010 | Nikon Photography
Nikon MD12 Operation intermittent through lack of use
This could be the lubrication dried up in your MD12. Fighting the dried lubrication would make it sluggish and continued fighting would make the motor eventually die. A good source for parts or replacement MD12 is Ebay.
A camera repair shop could replace the lubricant, replace any stripped gears or the dead motor and test it for you.
Nov 10, 2009 | Photography
Locating operating manual for nikon zoomtouch 500
Hi i need a free manual for Nikon Zoom Touch 500 does any one no where i can get one.
Thank you very much my e-mail is mooseman4848@otmail.com
May 23, 2009 | Nikon Photography
Nikon F3 rewind knob
nikon usa still provides parts for Nikon f3 cameras. You can order by phone at : 310-414-8107. They are very helpful and take great care of Nikon owners,
Aug 28, 2008 | Photography
Nikon 2000
Mary, Sorry for your loss. The camera and lens are maybe worth 50-60 dollars. eBay would be the best place to sell. craigslist.org is also another place to sell, and they are free. High school and college students are usually looking for older film cameras too
Mar 06, 2008 | Photography
Manual for Nikon 6006
Download the manual from http://www.butkus.org/chinon/nikon.htm and send the guy a contribution.
Oct 01, 2007 | Photography
Photography Logo
275 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
