Question about Sharp AR-C270 Color Copier
Continual misfeeds and also L4-06 codes
Please help! Need it fixed TODAY! I have the manual and know how to fix a lot of problems on this machine (we have for 7 years), but can't get it to stop misfeeding and giving L4-06 codes over and over today and I have a huge job on it that is due TODAY. Call me 706-344-8520 or email me at kate@gagraphics.com Thank you!
  • StewartD Nov 12, 2008
    I have a Sharp MX-4501N and just today it has started misfeeding with the same codes L4-06. What do we do?
  • 62 Answers
The transfer belt bushing are going bad you use oil on theme to get you buy.the are black.
Posted on Oct 11, 2007
    Problem Solver:
  • 5 Answers
Do you find the service manunal and you test the sim 22.6
Posted on Mar 09, 2007
  • thein tunoo May 21, 2007
    i think you replace the process unit and motor test
SOURCE:
MISFEED INDICATOR BLINKING
DEAR SIR WHERE YOU REMOVE THE PAPER IN THE MACHINE THAT SECTION THERE IS PAPER PATH SENSOR ,THAT SENSOR POSITION IS ABNORMAL PLEASE CHECK THE SENSOR OF THAT SECTION WHERE YOU REMOVED THE PAPER
Hope this may help;
Regards,
VOTIT
Aug 29, 2008 | Sharp AL 800 Copier
I have a Sharp Al-2040cs when I turn it on the misfeed indicator is blinking. I checked it there no misfeed paper or piece of paper inside. How can I fix this problem?
The MISFEED Indicator blinks when a MISFEED has occurred. Remove the misfed paper referring to the the description of MISFEED REMOVAL beginning on page 65 of the pdf Manual at:
http://files.sharpusa.com/Downloads/ForHome/HomeOffice/PrintersFaxMachines/Manuals/cop_man_AL2030_AL2040CS.pdf
When the MISFEED Indicator is blinking you should look closer at the paper feed area (see page 66 of the PDF). You may need to remove the paper tray to find any remnants of paper. If after closing the side cover the light does not stop blinking you will need to follow through as per the illustrated instructions.
Remember after removing jammed paper, you need to press the clear key to clear the MISFEED error.
If after doing all this the error signal has not cleared, power down the printer; unplug from the power supply; let rest 5 - 10 minutes; plug back i to power supply; turn printer on and see if this resolves issue.
Trust this is helpful. Please vote. :)
Dec 12, 2010 | Sharp AL2040CS Digital Laser Copier,...
We have a problem Konica Minolta Bizhub C352 error code C-0204, our machine work properly for months years, we don't have work yesterday, but when we open our machine today the error affairs. we try to...
Check out the user guides for this printer.
CLICK HERE!
There has to be something about a Hard reset that might could fix your problem.
Hope that helps, give thumbs up please!
Aug 23, 2010 | Office Equipment & Supplies
Hello, I have a Brother Fax 560 (Plain Paper Fax). I am having difficulty receiving faxes. It is not transmitting on the receiving end. What is the problem?
Hi Despite the increase in texting, email, Facebook and Twitter, we still hang on to our fax machines. They are perfect for sending copies of original documents despite document jams, buying ink or special paper, maintaining a phone line--we love 'em. Basic problems like paper misfeeds can be troubleshooted through the use of some basic steps.
Check the Message
  • Check the messages on the display of your Brother fax machinemag-glass_10x10.gif. The messages will be pretty self-explanatory such as "Insert Doc, Again" or "Please Supply Paper." "Insert Doc. Again" means that that the documents weren't placed on the feeder correctly; just follow the instructions and try again. A message like "Please Supply Paper" will simply mean you need to replenish the paper. "Memory Overflow" is probably the most cryptic. It just means that the memory capacity was exceeded and it has stopped recording. Press "Enter" to register the documents in memory and to complete the operation.
  • Misfeeds
  • Clearing an original's misfeed by pushing down on the release lever to open the front panel. Remove the failed original and close the panel. To clear recording paper that's gotten jammed in the paperfeed, open the turn guide and remove the paper. To clear paper from the transport unit, which is in the top, open the cover, remove the drum and toner. Lift the guide and remove the paper by pulling upwards. Paper can get stuck in what is called the Fixing Unit. Open the top cover. Again, remove the drum and toner. Open the Fixing Unit cover and remove the paper by pulling it back.
  • Aug 02, 2010 | Brother IntelliFAX 560 Plain Paper Fax
    Brother MFC 5840CN "Unable to Clean" Message
    I have the same problem, and it just started today, how do I fix this problem?
    Sep 02, 2008 | Brother MFC-5840CN All-In-One InkJet...
    Error codes
    Online at Frigidaire .com you can find the manual.
    With an error code the only way to find and to repair this is,
    First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
    If it corrects the problem GREAT!!! WE WIN!
    If not only a trained laundry tech can make the electronic diagnoses.
    Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
    How old is the appliance?
    If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
    New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
    Water,Electric and detergent! And put money back in your pocket!
    The new appliance will pay for itself in only a few years!
    You will be fine
    Bless You ngafm
    PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF!!!!!!!!!!!!!!!!!
    Aug 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
    Paper jam/misfeed constantly
    creo que el sc 547 es el termostato del fusor de la maquina fijate reiniciandola en el modo "sp"
    Jun 14, 2008 | Ricoh Aficio 1085 Laser Printer
    How do I clear misfeed.
    In most cases where the machine says there is a jam, and there is no paper in the paper path, it's because the paper never got out of the paper drawer and didn't reach the 1st jam sensor. If you can open the machine and it resets, then chances are the paper feed roller is either slipping or in some cases not turning at all. If you can't clear the jam by turning off the machine, and back on, then you have a bad jam setect sensor or perhaps a small piece of paper lodged on the jam sensor. This will take some additional troubleshooting on your part. Need to know if the jam indicator goes away when you restart the machine. Let me know and I'll try to guide you from that point. Aloha, Bill Monroe
    Sep 17, 2007 | Ricoh Aficio 1018D Copier
    Sharp AR-C270 Color Copier Logo
    460 people viewed this question
    Top Sharp Office Equipment & Supplies Experts
    Anthony Karuku
    k24674
    Adorjani Laszlo
    Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
