Question about Microsoft Xbox 360 Console
Xbox turns on but i have no green lights
My xbox comes on but i have no green lights and my contrlr wont come on
  • 12 more comments
  • TcAmPbElL121 Dec 29, 2008
    i have the same problem and i've tried everything what cani do
    no theis no green light on the power button either
  • jaeger04 Dec 31, 2008
    I have the same problem as well - no green light on the power button and the wireless units won't sync.
  • msconbio Jan 20, 2009
    XBox 360 turns on but the green lights on the front of the system do not turn on and the wireless controlers do not sync, wirelessly or wired through USB. I can navigate with the remote control but I cannot use the wireless controllers.
  • Anonymous Feb 15, 2009
    I have the same problem. It still works just fine if you plug a regular controller in. But who whats that?
  • izzythegreat Feb 21, 2009
    after not using my 360 in a few days i went to turn it on and it turned on but there was no light no green no red nothing and the controllers would not be located by the system...have no idea what the problem is .any help anyone??
  • willmedrano8 Mar 24, 2009
    Xbox comes on works good, controller comes on works good, I have no green lights on the xbox and I can t sync the controller. I have tried my controller on another xbox and it works good. anyone have a solution?
  • feeneymom6 Mar 31, 2009
    My problem is that the green power button in the middle remains on, but the outside green rim shuts off after a few seconds and remains unlit.
    Any suggestion. Also, the controllers won't sync with the console
  • origilad Apr 17, 2009
    feeneymom6 i have the same problem like you describe
    can you tell me how did you solve this ?
  • AtariPro Apr 26, 2009
    Xbox runs like normal except controllers will not sync to console. Have
    tried usb charge kit, unplugging power, removing harddrive, playing
    without HDMI. Controllers will even start Xbox. Its deffinetly not the
    controllers because they work on my Elite Xbox. Could it just be a
    hardware problem with the pro console only? I noticed allot of people
    with the same problem posting help request' around the same date. If
    anybody has any ideas help would be appreciated...this has been driving
    me nuts for days.
    (When both sync buttons are pressed the quadrant lights spin around
    briefly and stop together like they work, except no quadrant lights are
    designated and/or remain lit)
  • nene69candyk
    nene69candyk Nov 13, 2012
    mine is doing the same exact thing. did u ever find a solution??
  • nene69candyk
    mine did the same thing. did u ever find a solution??
  • nene69candyk
  • lewis Jan 20, 2014
    try dusting it that happened to mine and then it started to work
What appears to be the problem in my case is that the RF module board in which the power button and the controller sync lies has been damaged. If aboslutely no lights come on when you power on your xbox 360, but it loads like normal, something has fried on the module and needs to be replaced. You can ether contact microsoft about this, or buy one off of ebay and install it yourself or have someone who knows how install it for you. Doing so would void your warrenty of course though.
Posted on Dec 11, 2009
    Problem Solver:
  • 10 Answers
Do you have the green light under the power symbol... looks like a 1 and 0 stack on top of each other? (right in the middle of the power button)...
When you hit the Xbox button on the controller does the controller lights blink?
If all of the above is YES then I bet you need to resync your controller to your system...
Try this turn on the console and press the small button next to the memory card ports and as quickly as you can turn on the controller and press the same little button on the front (top) of the controller... repeat for each controller
Posted on Dec 12, 2008
  • 767 Answers
It sound like a problem with the R.F. module same on with the
ring of lights on it . If you open the case pop off the white cover
on the power button ,remove three screws in will easley pull off
toward you, . goto Rich's PSX and buy a ring of lights replacment
moduel , cost 30.00 and plug and play . That's it.
if you need more info ask
Posted on Dec 18, 2009
  • 4 more comments
  • Rod Sims
    Rod Sims Oct 31, 2010
    I have 100's of the ring of lights P.C. boards aka RF board.
    I would have been more than happy to ship one to you for cheap.
    5.00 and was willing to give you support if needed . but you
    thought it better to leave negative feed back oh well Your lose.
  • ejcjmj Feb 11, 2011
    If you see my issue that I posted and think I may have the same problem, I would be interested in taking advantage of your generosity and help with replacing my RF board. I need help!
  • fnkype40 Mar 08, 2011
    if you still have any of the rf boards how do I get a hold of you to get one
  • jack_sponge Aug 20, 2011
    will you be able to ship one to me please that would be awesome if you could just give me a way to get a hold of you
    will you be able to ship one ring light replacement moduel for 5$ to me please that would be awesome and if you could can you just give me your email and maybe we can get a hold
    thank you
    i would love one for 5$ if you can just give me your email and we can get a hold
Guys I have a problem in my Xbox can you help me? My Xbox turns on properly and looks like no damage but after it turns on the green lights will turn off .and my controller won't blink
Posted on May 14, 2015
Hey my screen is blank so all you can see is a black screen no sound and my comtrollers wont sync and I dont want to do somrthing that would be expensive. It was working the day before then after that I turn it on and nothing, I could really use the help guys
Posted on Oct 29, 2012
My green light dont turn on so its fried or buy a new 1???
Posted on Aug 28, 2012
Ill go head and admit , i voided warranty and opened the lid to fix the ring of death , now i have the same problem as yall do . the first problem i ran into was the RROD then after fixing i got on Live , constantly lagging out of rooms and freezing (worked fine offline) .
the next problem was when i restarted the Xbox (which btw its a regular 360) it would freeze on startup . origanally i thought it was a BIOS problem then when it let me on , i foundout that my profile on the HDD was corrupt , i checked the HDD and the only corrupt data was my profile , not the other 15GB of stuff . when i tryed to create a new profile , it said that the "Xbox live sign in was currently un-avaliable" and that led me to believe i was banned for a mod ( it reconizes the penny trick as a mod) .
im not sure if i am banned or not but when i restarted again , i had 1 red ring . it was the 4th player ring . so i reconected the controler which landed me where yall are , the power button is on , but no rings are lit , red or green , andthe controller wont connect , the xbox wont even start .
i dont even know if it is fixable but if yall figure somthin out lemme know , ill do the same .
  • Walnut House Dec 18, 2009
    ok , i think my systems completly gone but i have a site that will Hopefully help most of yall , visit here first , it has detailed tutorals on takin apart and fixin the RROD as well as most others . i am posting the link to the error code page , Hope it helps .
    http://www.llamma.com/xbox360/repair/Xbo...
2 Suggested Answers
lostinfamily
  • 149 Answers
SOURCE: xbox turns on but i have no green lights
it sounds like that the controller will not pick up the signal.  I would try a wired controller first to make sure that all connections are good as far as operation.  If that turns out good then I would get a friends controller and try to connect it with the remote buttons.  remember to press the button on the xbox first then press the search button on the back of the controller second.  If the wired works and the wireless does not then you have a problem with the receiver in the xbox itself.
Posted on May 28, 2009
My xbox 360 will turn on but the lil green circle wont light up and controller wont connect?
Your xbox 360 may not actually be on if there's no green light and your controller won't connect. If pressing the power button doesn't turn on the console/green light doesn't come on then your motherboard may be bad.
Jan 14, 2013 | Microsoft Xbox 360 Console
My xbox cuts on abut wont connect
I'm thinking bad AV cable or bad port on your TV. I assume the Xbox dash board won't come up, if so the "no signal" message is a TV error message not an Xbox error message.
Try a different port on the TV and/or a different TV; also try a different AV cable.
Good luck. Please rate, thanks.
Mar 05, 2010 | Microsoft Xbox 360 Console
My xbox page wont come up just black screen. i have a middle green light but no diaganal green light.
If you are using an hdmi cable make sure it is pushed firmly into the console and the tv.
Thumbs up if this helps.
Feb 05, 2010 | Microsoft Xbox 360 Console
What can i do to fix this
it does that sometimes just unplug the system and it should be working just fine
Jul 29, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont turn on
try a new power cord to see if thats the problem, then buy a new one.
May 30, 2009 | Microsoft Xbox 360 Arcade
May 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 wont come on but the plug wont lights up green
Hello so you say your Xbox 360 wont come on will it well here are some tips that might help you
1) Check that your T.V is on.
2) Check that all the cables are in tightly.
3) If all of the above fail take it back to a repair shop or call up Microsoft and tell them about it.
Hope this works Full Str Pka
Dec 31, 2008 | Microsoft Xbox 360 Console
My elit comes on and the light is on but it wont start.
check your dic is there a ring on it if so contact me:dracohackess@yahoo.com
Dec 26, 2008 | Microsoft Xbox 360 Elite Console
Xbox 360 wont go on!?
If the controllers light up then the system is turning on. Does the green light come on under the power button on the Xbox console? If so then I bet your system is working... Did you use the video cable that came with the system? If so then check to see if you have the switch on the cable set to HDTV or Analog depending on TV...
Dec 12, 2008 | Microsoft Xbox 360 Console
Flashing red and green light in xbox
You have a major failure on the motherboard. If it was your hard drive the system will boot up, but freeze on the main screen and you will hear clicking coming out of the hard drive. Red and Green flashing lights means there is a problem on the motherboard. Sometimes you can fix the problem by reflashing the Bios on the main motherboard.
Nov 11, 2007 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
18,493 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
