Question about Apple iPod nano
Ipod nano flashes apple logo and doesnt do anything?
Also when ipod is unplugged from computer doesnt do anything
  • 8,596 Answers
The 5 R's for Apple iPods – www.apple.com/support
These are for Nano, but they apply to all iPods:
Reset, Retry, Restart, Reinstall, Restore
Remember these five basic suggestions if you have a problem with your iPod Nano. If one of the following doesn’t help, read on for solutions to specific problems.
- Reset your iPod Nano. See “General Suggestions,” below.
- Retry with a different USB port if you cannot see iPod Nano in iTunes.
- Restart your computer and make sure you have the latest software updates installed.
- Reinstall iPod and iTunes software from the latest versions on the web.
- Restore your iPod Nano. See “Updating and Restoring iPod Software” on page whatever.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
Apple firmware removed from ipod nano
If you can, go to My computer and format the iPod drive letter then restore it using iTunes. I hope it works for you.
Feb 23, 2012 | Apple iPod nano
Tip
IPod Nano/Video/Touch Resetting
One day your using your iPod and all of a sudden, boom. It turns off and refuses to work or read by your computer.
You might get the apple logo, but thats where it ends. In this case, theres a few things that can probably bring you device back and kicking.
iPod Nano/Video(Classic)
6th Gen Nano
Press and hold the Sleep/Wake button and Volume Down button simultaneously for at least eight seconds or until the Apple logo appears. You may need to repeat this step.
If the above step did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep. Try resetting the iPod while it is connected to power.
4th and 5th Gen Nano/Classic/Video (CLICK WHEEL VERSION)
1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
2. Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step.
In case the reset does not work, the alternative is to connect the device in disk mode and restoring it.
  1. Before placing the iPod into disk mode, you should verify that it is charged.
  2. Toggle the Hold switch on and off. (Set it to Hold, then turn it off again.)
  3. Press and hold the Menu and Select buttons for at least 6 seconds until the Apple logo appears.
  4. When the Apple logo appears, release the Menu and Select buttons and immediately press and hold the Select and the Play/Pause buttons until the Disk Mode screen appears. zero77cool.jpg
  5. Connect the iPod to your computer; the screen on the iPod will change and say "Do not disconnect"
This will enable a black/white display. Restore it using iTunes.
If the above doesnt work, then Im afraid its time to repair your device.
Note: images and part of help copyright © 2011 Apple Inc. All rights reserved
on Mar 13, 2011 | Electronics - Others
My iPod's center button doesnt work and it is frozen. its stuck on the now playing screen and i can't do anything to it, please help
You just need to reset it, hold down the middle button and the "Menu" button for about 7-10 seconds, or until you see the Apple logo.
Hope this helps!
Sep 03, 2009 | Apple iPod nano
I pod is frozen
call apple store they can get you going over the phone in 10 minutes. It would take too long to type it all out
Nov 22, 2008 | Apple iPod nano
My ipod suddenly wont mount!
The first thing you can try is unplug the Ipod from the computer. Hold down the center button while pressing down on the menu button. You should see an Apple logo appear on the screen. Your Ipod has been reset. Plug it back into ITunes.
If that doesn't work after plugging it in. You may have to restore the software in your IPod from Itunes. Make sure your songs in your IPod are on your hard drive because this will restore all of the settings back to default and empty out the memory of the IPod as well.
This system restore can be done through ITunes or by selecting the system software option from the IPod menu in the computer if you have it installed.
Option 1 should work.
Jun 09, 2008 | Apple iPod nano
My ipod nano wont do anything
By pressing the center button and the menu button the same time and holding it for around 6-10 seconds, your device should turn on. You then should be able to access your files and charge your ipod.
May 14, 2008 | Apple iPod nano
Ipod nano won't work for us
try pressing the reset button with a toothpick on the nano if this doesnt work then read the manual on how to do a hard reset.
good luck.
smeags.
Dec 31, 2007 | Apple Ipod Nano Second Gen. Green (4 GB)...
Flashing apple!
the battery might have lost all its charge .Most probably there is a problem in the USB jack of the ipod .Try to change the jack and the problem will be solved
Apr 08, 2007 | Apple iPod nano
Apple iPod nano Logo
144 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
