Question about Casio Exilim EX-S600 Digital Camera
Nothing shows on viewing screen
Hi.My problem is that I let my 19 year old daughter borrow my camera & now it doesn't work. When I turn it on after charging it, the green light goes on, the lens comes out but then nothing else happens. Nothing appears on the viewing screen(?), it is totally blank. Or should I say black. My daughter says that she did not drop it yet it doesn't work. Please help me if you can. Thank you
  • Anonymous Feb 07, 2009
    i have the same problem
Nothing shows in the viewing screen of my Casio EX-S60, evreything is dark/black, and when trying to capture image, it appears underexposure... and when im tried the video, all i can hear is the sound..
Posted on Feb 07, 2009
I have a casio exilim for just under 2 years. It goes blank when I am
using the camera. The play back is still working. The zoom feature
is also working.
Posted on Jan 20, 2009
Casio EX-S600 will not take pictures it tells me No Files Found.... Help
Posted on Jan 03, 2009
  • 3 Answers
I had something like this occur with a minot mini video camera only it locked up in the "On" setting, meaning I could see a display on the screen but could not turn it off. I suggest you look very closely for a reset hole at the bottom somewhere, a place where a safety pin or the straightened end of a paper clip could be inserted. If no Reset can be found, then try holding in the Power On/Off for as long as 90 seconds. This may clear the problem. I would also suspect no power due to low charge or no charge on the battery, battery installed incorrectly, or battery not charged up.
Posted on Dec 10, 2008
Tips for charging new batteries in Jazzy Select Traveller
Check the charger output to verify whether or not you have a bad charger using a voltmeter. These smaller batteries are notorious for having a short shelf life and poor quality control from the manufacturer. Load test the batteries after you verify you have a working charger that will bring the batteries up to the proper voltage first.
Feb 24, 2014 | Electric Mobility Pronto M41 Power Chair...
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even...
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Aug 18, 2011 | Samsung SL102 Digital Camera
I have an Olympus e510 that I bought new 2 years ago. The other day I got it out to use it and it will not turn on. I purchased a new battery, charged it, and it still will not work. When I removed the...
Hi, as per your information your camera 2 years old but not used much. You buy a new battery 1st time when you charged you see the gree light. But camera not working. When you try to charge the battery again you seen the red light. Its mean your charger have a problem. So what you do now? Ok try these.
Remove the power connection of the charger. then fixed the battery there slowly & properly. After that plug on the charger again. If the same thing happens then unplug the charger & plug in in different point. Then see what showing. If again red light then wait 1 hours and waiting for green signal. If there is no green signal showing then visit a service center with your charger. Tell them your problem. They will fixed the charger for you. Don't worry your camera is ok.
Your new battery or your charger one of then damaged. Thanks & waiting for your feedback.
Feb 15, 2010 | Olympus Evolt E-510 Digital Camera
I have the ex-s600 camera and am very happy with the camera but I just tried to recharge it and it never charges. The red light blinks continuously and never turns green.
Remove the battery and make sure the contacts are clean. It might even be sufficient (for a while) to just remove the battery and put it back in. If that works, you should clean the contacts.
The next step is to try another battery. If you can borrow one from a friend with the same model, do so. If that charges, your battery is bad. If it doesn't charge, ask your friend to try charging your battery in the other camera. If it charges, then try borrowing the AC adapter. That will help isolate the problem without spending money. If it goes this far, post a response on your results.
Dec 09, 2009 | Casio Exilim Card EX-S600 Digital Camera
Camera immediatly shuts off and lense goes back in.
Sounds to me that ist is more of a charger issue. Try to borrow another charger and see if that works or not.
Jun 11, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera won't charge
Hi!
It's a problem with the battery. It already reached it's life cycle. I had the same problem with my 15 month old casio camera a year ago - flashing red light on docking station. I even tried borrowing a docking station/charger to see if something else is wrong with it.
The only solution for this is to have the battery replace.
I hope that helps.
Good luck and have a nice day!
Nov 26, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Fuji F650 camera 1yr old. Worked great till the other day I went to turn it on the green light came on but nothing else happened. I recharged the battery but it still does not work. The green light will...
the battery is not holding charge anylonger.need to buy new one (aprox $9 on ebay) or try to have it rplaced atthe store you bought the camera from (it should last more than 1 year for sure)
Oct 02, 2008 | Cameras
DS lite, power is on but nothing happens
Ditto... except my daughter is 10. Both screens remain black, are fully charged and green light stays on for more than 4 minutes.
Sep 14, 2008 | Nintendo DS Lite Console
Power turns off
I was having the same problem... I put the camera in the cradle with it plugged into usb and then pushed play mode... the camera went to play mode and then i pushed and held the camera mode button while i was removing it from the cradle... it ended up turning on!!! i have no clue.. very weird
Mar 01, 2007 | Casio Exilim EX-Z500 Digital Camera
Casio Exilim EX-S600 Digital Camera Logo
305 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
