Question about GE Profile Prodigy WPSE4200A
Washing machine My washer runs right until it is ready to spin. It spins but when it first starts it is loud and slow. Then when it kicks into what I guess is high, sometimes it spins correctly and sometimes it dosen't spin at all, yet I can still hear the water drainig out. I don't even know how to open this thing up to look at it, to try and fix it. I am grateful for any assistance you can provide.
Same thing is happening to mine. If you read the front of the maching you will not that it has an autobalance feature. I have removed the botton of the maching and can see this feature. It is a large counter weight attached to some sort of mechanism which I assume extends the weight to balance the load prior to the "real" spin. I am guessing that during the preliminary autobalance phase, the mechanism is attemting to extend the weight but has become frozen. I beleieve the loud noise occurs when the mechanism is attempting to extend the counter weight. Normally this would occur quickly and be done with but since the load is not ballancing, the machine attempts again and again then finally moves on to the "real" part of the spin phase. My maching spins a little for the real phase then attempts to balance the load again and the loud noise occurs. I realize this is not a solution. If I find one, I'll come back and post. Till then good luck.
Posted on Apr 16, 2007
  • Bill Duhig Apr 21, 2007
    Boy was I wrong in my first response. The real problem is the motor. I took mine completely apart, did more research on other blogs, ordered a new motor (from RepairClinic.com $162 + shipping) and installed it today. The machine works fine now. Seems weird that it would be the motor, since the motor works fine during other parts of the cycle, but it is. The replacement motor has a new wire harness so you will have to cut the old wires and attach the new harness with crimp connectors. There is also an added relay and capacitor. The relay is attached to new harness, but the capacitor has to be connected. The kit comes with all the required parts for the install and detailed instructions. It's not too bad, but a novice might struggle with the installation. The front of the washer lifts off after you release two clips by pushing a putty knife into the gap between the top and the front panel. The clips are about 4+ inches in from each side. It takes a fair amount of force to release. If you take off the four screw on the top of the control panel, the control panel can be pulled forward. Inside, there should be a piece of paper explaining how to dissaseble the machine. It also explains the diagnostic mode that can be used to test each washer function. You only need to remove the front panel to replace the motor. Good Luck.
    President:
  • 1,294 Answers
Certainly you could find some screws to unscrew to view the tub. Is this a front loading one?Check the shock absorbers or springs & see they are in place. You hv to open it up or more damage will occur. Plug off the wall please.
Posted on Apr 12, 2007
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Maytag washer mavt546eww..will not get up to full speed
Hi, this is transmission failure. the clutch has been damaged. I recommend replacing the transmission and agitator assembly as well.
Jun 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
High pitched noise when spinning or slowing down(cat screaming)
Sounds like you have bad bearings. I suggest you get it fixed before it creates further issues.
Feb 26, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Loud noise in slow down spin mode.
when it is in high spin then you stop the washer it makes a thumping noise until the basket stops sort of like a flat tire sounds to me like you need a drive block
Dec 18, 2008 | Kenmore 24032\24036 Top Load Washer
Rattling noise during spin cycle
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Admiral mod#lnc6760b71
Water runs out, but does not spin, nor dry the clothes. Motor is good.
Dec 08, 2007 | Admiral AW22 Top Load Washer
Loud screaming sound during spin cycle
The screaming noise is probably from a dry bearing in the motor, it will probably come and go and shouldnt cause to much problem, they are supposed to be self lubricating but sometime they run dry.
Oct 18, 2007 | GE Spacemaker WSLP1100D Top Load Washer
GE Spacemaker No Spin
the washer has carbon brushes on the motor if these are low the drum will not spin it needs these carbons to make contact with the motor
Aug 12, 2007 | GE WSKS2060WWH Top Load Washer
Washing Machines Logo
297 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Sal De
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
