Question about Miele Cooktops
I am installing a Miele KM5773 induction cooktop
Please can you advise me on the power comsumption of the unit we need to work out the size of electrical cable to run
REPLACE IGNITOR FOR MIELE KM 412
Posted on Oct 19, 2010
YOUR ANSWER WAS VAGUE. DOES THIS MEAN I CAN STILL KEEP USING IT?
dont keep using it
if that Miele Cooktop induction type or other types
is NOT working the way the user manual says its should with the correct pots and pans
Sep 16, 2016 | Miele Cooktops
I turned my power off and when I turned it back on my Miele 5733 is beeping and giving me a 30 error code. How do I make it stop?
No handbook? Go online to the main Miele importer HQ or go to Miele in Germany website and usually there are handbooks to download. If not message Miele service centre and they will help.
May 20, 2014 | Miele Induction Cooktop
Wiring for Kenmore Elite Induction Cooktop
The white one may just form an earth loop,, I recently had a ceramic plate needing cleaned so we did the whole lot, I think most hobs have 4 wires and they are numbered rather than colour coded..hope this helps
Nov 10, 2013 | Kenmore 30" Induction Cooktop Stainless...
Replacement glass top miele KM5773 36
THERE ARE SEVERAL WEBSITES SELLING MIELE
parts: Search them and contact them:
Technical Service
Miele Parts Partmaster
Find Miele Spares and Accessories
Accessories
Expanda your search with google, use terms
MIELE PARTS
Apr 10, 2013 | Miele "KM5773 36"" Ceran Glass Induction...
Miele Fault Code FE 30
I have the same FE 30 problem on my KM5733 Induction cooktop whenever it's circuit breaker/isolation switch (in my house's fuse box) has been turned off and then on again. I have turned in back on after waiting a day or longer (figuring it needed to reset itself?) and the results have been hit and miss and I have had no idea why it would work sometimes and not others. Needless to say, I've trolled the net looking for answers and Miele online support is useless (unless you're ok with shelling out loads of cash to have a technician come by) and I still haven't heard back from them after lodging an enquiry.
What I have discovered from this and other forums is that these units do not like being attached to a power source which has a voltage significantly above the amount stipulated in its specifications (for my unit it's 230 Volts). After reading this I used a voltage meter to measure the voltage in one of the power outlets in my house (I have a really cheap meter I'd bought a while ago at an electronics retailer). Sure enough it was above 260 Volts which is totally beyond the range it's supposed to be for where I'm living.
The thing is, I know the unit works just fine provided it has been turned on and it doesn't get the initial FE 30 error (it's almost like you have to get past an initial voltage check and then once it's going everything is ok). If the voltage is at an "acceptable" (whatever that may be) level when it's turned on, it will turn on and then stay on even if the voltage goes up afterwards (which it obviously has done during the time from when it was last switched on until recently).
How did I get it to work this time? well I thought of ways to reduce the voltage to the unit and came across all sorts of stuff on the net including powerbox voltage reducers, optimisers, blah, blah... I thought this is total rubbish and I'm going to ring the power company and complain about the voltage being so high when it's not supposed to be. I then thought back to my old high school physics days and remembered that there's a relationship between voltage, current and resistance. I then thought the voltage to the induction cooktop (as well as to all the other power outlets/circuits in the house) is likely to drop if I plug in and turned on a lot of high resistance electrical appliances.
Sure enough, when I turned on the kettle, toaster, clothes dryer, computers, televisions, electric oil heaters, lights and dishwasher, the voltage in the power outlet I'd been measuring went down from 260 to 235 volts.
I then turned on the power to the induction top back on and it turned on and with no FE 30 error!
I boiled some water to make sure everything was working ok (it was) and then I turned off the induction top and all of the other devices I'd switched on.
Still no FE 30 error! Great.
I double checked the unit by turning it back on and boiling water again and it did it with no problems. I then turned the unit off and measured the voltage in the power outlet again and sure enough it was back at 260 Volts. Hurray!
I'm now going to ring the power company and make a complaint...
Mar 22, 2013 | Cooktops
My miele induction schott ceran is being locked, and I can not open it to cook??
If you have an illuminated red key symbol on the cooktop, press down where the illuminated red key is, for about 5 seconds. This method works on many Schott Ceran / Miele cooktops including the KM443 listed above.
If this doesn't work, please let me know the correct model number.
Hope this helps.
Regards,
BElectric
Apr 25, 2011 | Miele 30 in. KM443 Electric Cooktop
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Induction cook tops
good day,
hope this link below will solve your problem.
kitchen appliances
Sep 14, 2008 | Dacor Millennia ETT304 Electric Cooktop
Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Mar 01, 2008 | Cooktops
Cooktops Logo
457 people viewed this question
Top Miele Cooktops Experts
mpservices
Are you a Miele Cooktop Expert? Answer questions, earn points and help others
