Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Printer saying refilled bci3e is empty, when it is actually full
Hi. ive got a dilema, my printer has decided that my refilled, full bci3e black is empty, and refuses to print, now, there is no electronics attached to this cartridge style, the light refraction prism inside the ink reservoir is totally submerged (cartridge is full) and im smacking my forehead against a brick wall because after 2 years of refilling, its decided to play nasty, works fine with a brand new cartridge installed, this is this refills first refill.
any thoughts greatly appreciated
  • myersa81 Dec 10, 2008
    thanks gremlin11, not too sure on that eprom chip thingy, i print a lot, so in desperation, refilled an old cartirdge i had knocking round and hey presto, im printing again, took the trouble cartridge down to my dad's, he got the same printer model, and it worked there, thinking maybe my printer just had a moment of rebelion, thanks again.....
    Scholar:
  • 78 Answers
This is a very common issue with refilled ink cartridges. The fact is that you have a MP730. The cartridges have an eprom chip loaded into the cartridge which blows once the cartridge is empty. Refilling it as a general rule does not work. The best and only solution to your problem is to pop out to your stationery supplier and purchase a genuine canon cartridge.
As a side not, the ink inside the cartridge is covered by a patent held by canon. it means that no other supplier can use this particular grade of ink. The use on non genuine ink will destroy your printhead and make future use of your unit much less than its normal life expectancy.
Gremlin 11
Posted on Dec 10, 2008
Add black toner but still empty
Is it a genuine Ricoh Toner or a equivalent refill, if it is the latter then my machine would say empty when actually full. Just keep on using the machine, and have another toner on stand by.
If its a genuine Ricoh toner suggest the machine needs a clean around where the built in (toner) chip is located.
Jun 03, 2014 | Ricoh Aficio SP C820DN Laser Printer
I replaced my black ink cartridge with a refilled from office max and it will not print in black. Why?
Most HP cartridges have what's called an ACCUM chip, which doesn't care about the actual ink level, it counts how many milliliters (or droplets) have gone through the head to determine when it's "empty" and therefore refilling doesn't do anything, the accum still says the cartridge is empty.
Mar 05, 2011 | HP Photosmart 2610 All-In-One InkJet...
Hp black cartiedge is low on immediately
When you refill a cartridge, the printer will keep warning you that it is empty- a message pops out that says "low ink". That is because the printer sees the cartridge by it's serial number. The printer can't know that you have refilled the cartridge, so it keeps saying that it is empty. Once you put in a new cartridge, it will display the cartridge as full again.
May 02, 2010 | HP Easy Refill Kit for (HP) Black Inkjet...
Refilled ink cartridge but it says cartridge is empty how do i reset my printer?
No
Actually each original cartridge has a sensor that reports back to the printer information like ink level and others.
Once the cartridge gets empty, there is no way to reset it, even though you just refill it.
Please don't forget to rate this answer if it helps.
Nov 09, 2009 | Lexmark X2500 All-In-One Printer
I know the colours and black crtridge is not empty RX420 Epson
thats true because the capacity of ink of cardiges small refill it it will print. trust me.
Jun 04, 2009 | Epson Stylus C66 Inkjet Printer
I refilled my empty ink cartrage, but the printer still says its empty and to replace the black. how do i reset it to say full?
without make or model number, cant do anything. Check to see if there is a chip somewhere on the ink cartridge. If so...your screwed. Some printer have a 'is this a new cartridge', follow the instructions.
Apr 25, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Jan 01, 2009 | Epson Stylus C62 InkJet Printer
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Lexmark Black cartridge 28
You cannot refill a 28 that has been through a refill program. Look at the box dose it say refill program cartrage ?? then you can't refill it, it will always say empty.
You can however refill a 28A.
May 13, 2008 | Lexmark X2500 All-In-One Printer
Lexmark z845 ink refill problem
i need adisk to install z645 printer towindows vista couputer
May 08, 2008 | Lexmark Z645 InkJet Photo Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
149 people viewed this question
old marine
old marine
Corne Viljoen
