My Goodman Heater the red light keeps flashing steadily ,I put new mother board on it anit is still doing it. something twinnig wires , whats does tht mean
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Just reverse the power wires and the ground wire going to the unit (black / white wire going to the unit. or just reverse the power wires (black white wires going to the thermostat.. t y v much!
Posted on Dec 12, 2008
Goodman 100-4 Furnace with a Constant flashing light
so you have counted the flashes and the code says swap the wires??? I'm leaning towards another bad board because swapping wires isn't going to change anything and if it was wrong in the first place in doubting it would ever work.
Oct 08, 2017 | Heating & Cooling
Blower MoterElectrialDiagram for a 40,000Furnaces to a Ton1/2 Air conditioner
You will put the red wire from the blower on the terminal marked "heat" on the control board. Black= high speed Red= low speed Yellow/Blue = med low/ med high Hope this helps!
Nov 14, 2012 | Goodman GMS90703BXA Heater
Goodman heater red light blinks 5 times is a blower heater, it says is the sennsor flame, i keep changing it but it keeps burning it over and over doesnt work
Interpret five LED flashes to mean your furnace senses a flame without a call for heat. This could be from a gas valve closing slowly or a burner flame lingering
Nov 05, 2011 | Goodman GMS90703BXA Heater
Gas dose not come on
The blinking light is giving you a trouble code for the unit. It should have a label or something inside the unit or in your owners manual to let you know what the code means. Count the number of blinks. It should repeat over and over.
Jun 06, 2010 | Goodman GMS90703BXA Heater
I HAVE A 45000 BTU GOODMAN FURNACE RED LIGHT
There may not be a call for heat being registered by the control board. Take the R and W terminals on the control board and put a jumper between the two. If the heater starts, you have either a broken thermostat wire or a bad thermostat or connection.
Jan 25, 2010 | Goodman Heating & Cooling
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
Goodman GMP050-3
If you do not have two furnaces hooked together, you have a bad circuit board or an improper ground or neutral wire.
Dec 09, 2008 | Goodman GMS90703BXA Heater
Electronic ignition is not working on my goodman heater
it means the high limit switch is staying open , it is there to keep the unit from over heating. it have went bad , it is the small square peice with two wires going to it on the heat exchanger could be black or brown
Nov 11, 2008 | Goodman GMS90703BXA Heater
AIR or Heat wont come on/ goodman GMP075-3
If there is no blinking light, then the unit is not seeing a call for heat or cool. My guess is a lose or broken wire in the thermostat circuit. Try and putting a jumper across the red and white heat terminals inside the furnace and manually closing the door switch. If you get heat, it's telling you there is a wiring issue. If you get nothing, it's a bad circuit board.
Jun 08, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
113 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
