Tech guys only.. Remove rare,side,top covers, rare metal sheet cover, you can see the Low vol power supply, check input 220V/110V(depends power standards) fuse. If fuse burnt check primary section is there any component failed? replace same rated fuse the try it.. if successful no issue, if fuse burnt repeats replace "Power Supply".
If fuse burnt after fuser drive starts, replace another fuser then try it. (faulty fuser also one of the cause to fuse burnt)
