Question about Dell Inspiron B120 Notebook
Adapter going bad
I want to know why my second adapter (replacement) is going bad. It keeps coming out of the charger slot. When I touched it to see if it was bent, it was hot. This is the second time this has happened, and it's why I replaced the original adapter. The battery is barely charged. The tip is not bent, nor is the little polar tip in the slot. My computer is overheating too. It's almost like the tip is being melted and bent. Any solutions?
    Problem Solver:
  • 12 Answers
Http://atips4pc.blogspot.com/2012/02/how-to-solve-idm-fake-key-serial-number.html
Posted on May 05, 2012
  • 192 Answers
Get a computer fan from your local computer or electronics store
Posted on Jan 02, 2009
How do i fix an Acer aspire 4730z that will not charge the battery and has the charge light no longer comes on, is the motherboard bad?
Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
Sep 09, 2012 | Acer Aspire Computers & Internet
Will only charge for about 5 seconds
Try another battery if possible in the laptop. If it charges up the battery the whole way then that means your original battery is bad. If you still can't charge another battery for more then 5 seconds then that means the adapter is bad. If you get another adapter and still can't charge, then the motherboard is starting to go bad at that point.
May 14, 2011 | Lifetime Toshiba Satellite A205S5000...
Sometimes the Adapter Charges other times Doesnot, and now finally out, cant charge!
Possible cuase:
1 AC adapter failure
2 Power jack failure
First replace it with another working charger, see if the problem gone. If not, there may be strong possibility that the power jack was broken.
Here below are some common symptoms of a bad charger.
-The laptop only runs when you keep the power cord in a certain direction.
- The laptop only runs on battery power.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently.
- The unit suddenly shuts off
- Sparks come out of the back of the laptop.
Reference: Dell Latitude D620 Charger
Jan 20, 2011 | Dell Latitude D620...
My dell inspirion ac charger will keep computer running but will not charge my battery. A pop up will inform me that the system doesnt recognize the charger.
it could be a couple things: Are you using the standard 90 Watt ac adapter, or the Travel auto/Air adapter. The travel adapter is only 65 watts can will charge the battery
If using the standard ac adapter, see if you can try another Dell D series adapter and see if you get the same error.
If same with another adapter, the issue is the charging circuit. If another adapter works, then replace the adapter.
If the charging circuit is bad, it will be the chargerboard or if intergrated, the motherboard
Sep 25, 2010 | Dell Inspiron 1545 Notebook
I have a Dell XPS400 and can not connect to the internet because the machine does not have any installed network adapters. I have always had internet access...where do I find this adapter if I can't get...
This is onr example of a Network adapter, or also know as an Ethernet Adapter Card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
This is Dell Support >XPS 400 desktop computer > Service Manual,
http://support.dell.com/support/edocs/systems/xps400/sm/index.htm
1) Work on a table. Computer off, and unplugged from power, open the computer case.
(Removing the Computer Cover, in the list)
2) Follow Anti-Static precautions.
[Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components, inside a computer.
To relieve your body of Static, TOUCH the metal frame of the open computer case.
Should you leave your computer in the middle of working on it, upon your return be sure to Touch the metal frame again ]
3) View the motherboard inside your computer.
(The motherboard is also referred to as the Mainboard, {Proper speak}, and System Board)
Technical Overview > System Board Components,
http://support.dell.com/support/edocs/systems/xps400/sm/techov.htm#wp1053398
Viewing the illustration of the motherboard, the Ethernet Adapter Card example I gave above, would go in either one of the PCI expansion slots.
These are white in color, and in the illustration are labeled - PCI Card Connectors.
If there is already an adapter card installed in both PCI expansion slots, then see if the PCI Express x1 expansion slot is open.
In reality, PCI Express is a better technology than PCI.
Shown on the motherboard as PCI Express x1 Card Connector.
This is an example of an Ethernet Card, (Ethernet Adapter Card), that uses the PCI Express x1 expansion slot,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4675156&CatId=200
The reason I have suggested buying, and installing an Ethernet Adapter Card is threefold.
1) You may have your Ethernet cable plugged into the Ethernet port of the computer,
http://support.dell.com/support/edocs/systems/xps400/sm/about.htm#wp1053567
[Number 3 - Network Connector],
and the built-in Ethernet is no good.
Reinstalling drivers May help, but the above is a sure thing.
2) You have an Ethernet Adapter Card plugged into one of the PCI slots, or the PCI Express x1 slot, and the Ethernet adapter card is no good.
They do go bad, and are economical to replace.
3) There was an Ethernet Adapter Card installed previously, but taken out before you received the computer.
Jul 02, 2010 | Dell XPS 400 PC Desktop
My toshiba r10 laptop wont turn on the green power light to the front is on but the yellow battery light only comes onn when i plug in the power cord to it and it only stays about 2 seconds
Ok here's what you will do
1) Unplug the notebook from the ac adapter (charger power cord)
2) Take off the battery pack on the notebook
3) Once the ac adapter and battery is off the notebook, hold down the power button for 15 seconds
4) After 15 seconds, let go of the power button
5) Now plug in the AC ADAPTER (OR CHARGER POWER CORD) ONLY (DO NOT PUT BACK THE BATTERY PACK)
6) Now press the power button once.
7) If the unit boots, the unit suffered a slight surge
8) If the unit does not boot and remains dead, the unit suffered a severe surge and may be burned out and needs replacing
I hope this helps and let me know how it goes afterwards
May 03, 2010 | Tablets & eReaders
I keep the ac adaper in but the charger doesnt
you can see the problem if the battery in not charging or not loading some current. you can do this by unplugging the adapter on the outlet. if the unit turned off then the battery is defective. replace it. now if the problem is the adapter, you can see by removing the battery then plug the adapter to the unit and in the outlet. if the unit didn't turn on, the the adapter is defective. replace it.
Apr 10, 2010 | Acer Aspire 6930-6771 Laptop
It turns on for a few seconds then shuts off
Since you have already replaced the ac adapter. The problem is still there. the most likely cause of the failure is bad motherboard. Remove the battery from the laptop and disconnect the ac adapter . Press the power button for 10 seconds. Reconnect the ac adapter and try powering on the system. If the same doesnot work
Try the steps in the link
http://tinyurl.com/yd842up
Thanks for using Fixya
proton
Mar 15, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Orange light for a second then nothing
Possibly a bad charger? Try getting a new one.
Jan 27, 2010 | Nintendo DS Lite Console
Laptop died suddenly and is not charging
Take the battery out and discharge the capacitors by holding down the power button for 15 seconds. plug in the charger without the battery in to see if you get a charge light. If you do, replace battery and plug in charger and power on laptop. If this does not work, you may have to pull the cmos battery for 15 minutes and try it again.
Oct 03, 2009 | Computers & Internet
Dell Inspiron B120 Notebook Logo
56 people viewed this question
Alun Cox
