Question about Samsung Digimax D53 Digital Camera
I didn't have sim card in the camera when i took photos now
Can't save pictures imt sim card. do you know a way to help me save my photos to my sim card
Just make sure the sd card you put into the camera is empty then turn it on go to menu and it should let you copy to the sd card if not..... that sh*t's weak lol.
Posted on Jun 02, 2009
All you have to do is make sure your sim card is inserted properly then click the menu/ok button then scroll to the left where you will see an icon the resembles a sim card and an arrow. Then you will see the option for saving photos to sim. Scroll to yes and hit ok. If that option does not show up on your menu when the Camera is set to "Auto" setting, make sure your camera setting is set to Manual.
Posted on Jan 06, 2009
  • 3 Answers
I recently noticed a mini SD memory card in my cellphone and even though there was data on the chip which I had put there using the SD adapter and my laptop none of the data was viewable on the cellph screen. I went ahead with the Format command on the cellph. It erases my data but I believe I will now be able to store multimedia to the SIM as the Good Lord intended.
Posted on Dec 10, 2008
My Olympus c-740 tells me there are no photos, although the memory is full. It says it is full in the camera and in the computer. I need the photos, no the memory. Thanks!
There is memory built into the camera and additional memory card! Depends how the camera is set to save the photos either to the smaller built in memory or the larger memory card!
Oct 04, 2014 | Olympus 512MB XD Picture Card
Memory card size
i think those photos save in your camera built in memory. took the card out and turn on the camera . NOw press the play button and see the photos appeared in screen or not. If yes then you have to make the default storage location as your memory card.
Aug 07, 2012 | Nikon Coolpix 2000 Digital Camera
Hi, My canon PowerShot A540 camera gives an error " Card locked" Memory card error. I tried switching off the lock, but it didn't help. The card does not get recognized while inserting it in...
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
You also mention recovering photos saved on the card. If you actually did take pictures with this card (assuming it's a 2GB or less standard SD card, as 4GB SDHC was not designed for your camera), you may be able to recover the photos using recovery software. See this other link.
Jun 10, 2011 | Canon PowerShot A540 Digital Camera
Memory card filled and I took more pictures. Seemed to put those on the internal memory. What happened too or how can I recover the memory card pictures?
Probably one of two solutions.
First, the memory card should have all the pictures intact. If you are using the camera to review, you may need to just keep going back until the memory card photos show.
Another possibility is that the internal memory supersedes viewing the card memories. You may have to run a USB cable to your computer, download the internal memory photos, and then you can possibly see (on the camera) the memory card photos. It might be a good idea to download those photos to your computer too, if the computer has a memory card slot. Otherwise you will have to go through them and download via the USB again. Once you know the photos are saved, you can either change cards with a new one , or clear the old card and start again.
Good Luck
Mar 04, 2011 | Nikon COOLPIX L18 Digital Camera
Can't get photo's out of camera
You can't, they are not actually saved because without a memory card you are in DEMO MODE
Mar 11, 2010 | Nikon COOLPIX P90 Digital Camera
Camera: Panasonic Lumix DMC-FT1 Problem: Camera is not saving photos Hi, my camera started responding very slugglishly yesterday. I took a few pictures, and some of them wouldn't save. If I tried to switch...
Are you formatting the card in the camera as you're supposed to? Have you tried going into the menu and finding "reset" and followed the on-screen instructions? Do you have photos on the internal memory? If so, remove your card and format the camera to erase the memory.
Mar 03, 2010 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
How do I transfer pictures onto the memory card?
Go to the camera's "setup menu" and scroll down to the last option, "move images to card" That should put the images onto the memory card.
Apr 06, 2008 | HP Photosmart M415 Digital Camera
Olympus Camedia D-540
Try photo recovery software to rescue the lost photos, here are some you may rely on.
Photo Recovery Software (for Windows)
Mac Photo Recovery Software (for Mac OS X)
Be careful: Before your pictures are recovered, do not attempt to save more files to the memory card in case the original files(your pictures) are overwritten.
Dec 27, 2007 | Olympus Camedia D-540 Zoom Digital Camera
Samsung Digimax D53 Digital Camera Logo
106 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
