Question about E-Machines E17T 17" Flat Panel LCD Monitor
No power My E17T4 doesn't power up; no lights or anything. I opened up the unit to examine the internal power supply PCB. If the fuse is the little black cylindrical component labeled F101, it has continuity. On the PCB, 3 of the 470uf 25V capacitors are swollen at the top, as are two of the 220uf 25V capacitors, all clustered in the same area. There is an 'electrical smell' from that area, and not from others. I have a basic multitester and soldering equipment. Should I replace these capacitors and see what happens, or might there be another cause, and I'm seeing the effect?
  • John Anderson Mar 03, 2007
    First, my apologies for hitting the wrong key on my PDA, rating your answer as irrelevant when I intended Good, the choiced below it. Let me know how to correct.
    I found another fuse & it's OK. Can't find burned spot.
    I had the unit apart & plugged in. For a moment, the 'On' button lit up when I was turning PCB. I could not duplicate this, no matter how I twisted & wiggled everything to find a loose connection.
    Where this 'power & light' PCB connects to the 'drawing logic' board, there are some voltages at the pins. I found 12v, 5v, and 1v. So the power is gettin into the board.
    What's next?
  • robles74 Jul 17, 2008
    My situation is very simple, I living in El Paso Tx, I need to know where can I buy a new power supply for my e-machines monitor. Any help will be appreciated.
    Thanks.
    Novelist:
  • 198 Answers
Hello again, I've posted this answer from my second account by mistake (we use it for beta testing the live chat). Don't rate it to that account because I use it mostly as a boot. This is my primary account. Therefore if you have any more question, I will answer from this.
Posted on Feb 28, 2007
  • Motoi  Bogdan
    Motoi Bogdan Mar 03, 2007
    Power will get in but however the logic mainboard must give the power circuitry a signal to power on. When you've noticed that the led turned on, this signal was in some way delivred. It is hard to me to say for shure where the Power On signal is emitted from as I don't have the schematics of this monitor, and they can't be found on the internet for simple reasons of company secrets. You could try to find this by trial and error, by continuing the twisting and things like that, but there is the danger you may damage the logical board. You should try a repair at a service center as they will have it back and running in a day or so. I had a similar situation with a westing house 17 inch widescreen monitor and the problem as I found was a burned out transistor that didn't appear to have nothing rong with it. I've replaced it with another one from a video card and everything was ok. But the risks are hight if you don't know exactly what you're doing. I had nothing to loose then, no service in my area was able to do something.
Hello. It is good that you have some knoledge of electronics. We will be able to get on further. First thing, there isn't just one fuse. F101 is the main fuse, that's right but it isn't the only one. The LCD monitor powers on throught a tiristor or relay (depends on the model) and those are controlled by the logical units (chips and black stufs with lots of connectors). However these are also protected by fuses. Smaller ones, that doesn't look like regular fuses. Check the power suply area for more fuses (labeled with F also). In some case and for some models they are some green, resistor-like components. Check them all for continuity. If there aren't any more "F's" they are noted with another code, but that is pretty rare. The swollen capacitors aren't broken. They swell over time and they dry, loosing some of their capacity but they are most probably still ok. Your first thing to do would be the fuse check-up. Also, check the logical unit area for burned out components eventualy by using a magnifying glass.If some of those chips or transistors or anything are broken,burned or anything else, you will require a service center to have it fix. They burn out because something else has failed or was damaged before them, resulting in some sort of chain reaction. So, first thing. Check fuses and for broken components. :) Also, feel free to ask further questions and always remember to rate any answer received from this site :).
SOURCE:
Have a PVi8B mixer that has stopped working suddenly. Doesn't do anything when you flip the switch to "ON" are there fuses that could be the problem?
Does the blue power light come on when you switch it on? There is a 5amp fuse in the supply cable.Open the wall socket plug of the supply cable (unplugged of coarse) and check fuse and connections.With a multimeter check continuity of the three wires from the plug to the other end of the cable.If this is all good then you have an internal fault.There are fuses internally as well but this should be refered to a qualified technician.
May 10, 2013 | Food Mixers
Samsung LN40C610N1F. When plugged in, the red standby light comes on, but when I hit the power button the unit will not power on. The light doesn't blink or anything.
I see so many here with no sound/nopicture issues:
ISSUES:
1. IF sound main fuse/s are good.
2. If no power or standby check main fuse, standby power supply and any signsof damage you can see---burnt parts etc.
3. almost all these sets the troubleshooting involves checking voltages on the main power board to narrow down theproblem.
4. Be safe and if you do not know what you are doing don't open the set.
Answers to issues:
1. RE:fuses---if a blown fuse is found get a good replacement(not the genericones like Radio Shack). Many fuses are special even aside from amperage--Don'tput a higher rated amperage fuse in the set for any reason.
2. RE: power supply in set: if total dead aside from main fuse the set uses astandby power supply that runs 7/24 and a main supply (some are combined andsome not.
Here aside from checking fuses you want to examine all the filter caps on thepower/standby to see if any are puffed up or buldged up in some fashion--Iattach a photo of a good one---top should be silver metal and PERFECTLY flatand have no brown material coming out on top or bottom.
What happens in the standby area is they use caps with too low a voltage rating(saves money) which causes them to fail in a year or two---the standby runs7/24 and the heat dries out the caps and they fail.
3. Trouble shooting consists of the above and then at some point you have tobuy and try a board to see if it fixes it or not.
4. Safety first--no TV set is worth getting injured or even killed over.4_19_2012_3_53_26_pm.jpg
if set opened look for puffed up caps like these on the power board.
Apr 18, 2012 | Samsung 40 LN40C610 LCD TV
Monitor will not power on
Hi ,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope it may help you.
Thanks for using fixya.
Feb 11, 2011 | Sceptre x22wg Gamer Monitor
Will not turn on
Hi kfulcher247,
Here are some DIY steps that may help you fixing the problem.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is quite technical.
Feb 10, 2011 | Panasonic CT-32HC14 32" TV
Was watching tv and it just went off. Won't turn back on. No red standby light or anything. LG50PG20
Hi Sharon,
Here are some solution that may help you fixing the problem. You might need a help from guys that can perform steps below.
I'm assuming that your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the link http://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
JDVillanueva
Feb 10, 2011 | LG 50PG20 50 in. Plasma HDTV
Help my tv has stoped working
Hi ,
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is quite technical and fatal.
Feb 10, 2011 | Toshiba Televison & Video
I have no power after my power flicker during a snow storm. I stheir a fuse or reset? What might be wrong no pwer at all
Hi Gloria,
The problem in your unit is internal, Ive advice you to find friends that can perform the FF:
Feb 07, 2011 | X2Gen MV37R 37 in. LCD TV
NO POWER ON
Hi ,
You can also look for availability of power supply at .ebay.com and shopjimmy.com if you want to replace the entire unit.
Give a thumbs up if you find it useful.
Feb 07, 2011 | Magnavox 19MD359B F7 19 in. HDTV
Nad amp failure
Check fuses mounted near transformer . If blown check output transistor. Also check transistor transistors on small heat sink . they will cause fuse to blow.
Mar 10, 2008 | NAD C350 2-Channel Amplifier
E-Machines E17T 17" Flat Panel LCD Monitor Logo
275 people viewed this question
Top E-Machines Computers & Internet Experts
Thomas F. Schneider
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
