Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Lg dishwasher LD-12aw2
The letters ie appear on the display indicating no water. I have checked the inlet soleniod and it works ok. There is continuity in the wiring with a check done by the multimeter. There is no power to the inlet soleniod with the diswasher turned on. Does this mean the problem is in the computer panel. Do I replace it?
  • 1 more comment
  • Rowey Feb 25, 2008
    My dishwasher shows IE after a short while of operating.. Its clear that no water comes in, and I checked the inlet solenoid? - When this should have power it doesn't, but the problem is intermittant - Any tips?>
  • nicol333 Dec 29, 2008
    the same thing keeps occurrung with my LG LD-12AW2. it starts n then within a minute or 2 its alarming with the IE code on the display. unfortunately the dishwasher was already my house when i bought it, an so i dont have a manual to consult
  • rodjocumsen Feb 25, 2009
    I have a similar problem. Solution #1 suggests a sensor on the salt container but even though I have the service manual, I can't find any salt container. The fault suggests a water level sensor as it pumps out first and then stops.I changed the pressure switch with no success. My fault started as an intermittent fault. I found opening and closing the door overcome it. I opened the machine and checked all connections and it appeared to fix it, however it has finally failed and these workarounds don't have any effect. Does anyone know where the salt container sensor is on an LD-12AW2?? Thanks, Rod.
    Problem Solver:
  • 8 Answers
IE is a INLET ERROR. Possible causes ¥ The Water Tap not opened.
¥ The Inlet Hose is kinked.
¥ The Filter of inlet valve clogged by
impure water.
¥ The Inlet Water Valve is normal ?
¥ The water pressure is very low.
( below 0.3 kgf/ )
Possible solutions ¥ Open the Water Tap.
¥ Repair the Inlet Hose.
¥ a) Close the Water Tap.
b) Unscrew the Inlet Hose (Inlet
Valve side)
c) Clean the Filter of Inlet Valve.
¥ Replace or repair the Inlet Valve.
Posted on Jul 20, 2009
Dishwasher LD-12AW2 starts then stops after a couple of mintues with error code HE???? Please help
Posted on May 24, 2011
From reading around the net I have found there is support available to replace the PCB board that controls the dishwashers functions. Apparently they have failed so many there is a tech bulletin out for them and LG will replace them for free on this model in Australia.
I have just sent off my request so see how that goes.
Posted on Dec 27, 2009
On the salt container , there is a sensor (small black) this sensor checks the water level clean out the container by removing it from the bottom with cold running water replace sensor .this should solve your problem
Posted on Apr 18, 2007
Hi Guys, This is one of the many solutions for that E1 but if you say intermittend then this is probably your solution. The drain pipe is ending 2 low. It shoul have about 30cm clearance from the ground otherwise your water will drain out while it is filling. Do this test. Put your drain pipe at the same hight and catch the water in a bucket. You will notice that the water never stops draining especially if there is water left in the pipes from the previous wash. (Your machine is causing a fault by draining when it shouldn't. Think about the method you use to take Gasoline out of your cars tank with a pipe.) Good luck and happy dish washing.
Posted on Jan 21, 2009
SOURCE:
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Model LD 12AW2 not drawing water displaying 1E error
Hi afarugia,
The IE error you are seeing means Inlet Error, this shows because your dishwasher is not getting enough water through in a specific time frame - Please check the following:
- Is the Inlet hose kinked in any way? (This could lead to low water pressure to the solenoid) Straighten it.
- Is the Inlet hose filter (Found when unscrewing the hose form the inlet on the machine) dirty? Clean it.
- Is the tap completely open? (Low pressure)
- Has your home gone under any plumbing alterations? (This could have also caused low water pressure - Too little water)
If all of these come back OK, and it still gives the same problem, I'd suggest replacing the inlet valve (Found on the opposite side of the inlet pipe - inside your Dishwasher), could also be a pressure switch (Found at the bottom of your Dishwasher - accessible from the bottom).
This should solve any problems.
Kind Regards :-)
Jedemeyer1
* If you found this solution helpful - please rate it
Jul 10, 2011 | LG Dishwashers
Model No. LD-12AW2: control panel flashin PE and not allowing machine to be set or start
The PE error code indicates that the machine has a water pressure sensing error.
Check and clean the filters on both sides of the inlet water line.
Mar 28, 2011 | LG Dishwashers
1 F in dispaly window
well,i have the same problem.the solenoid doesn't open for the water to flow in.... but still working on the problem....
Feb 28, 2009 | LG 24 in. LD-12BS6 Stainless Steel...
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG ld-14aw2 dishwasher
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
Aug 26, 2008 | LG 24 in. LDF 7811 Built-in Dishwasher
Ie problem on lg dishwasher
The IE is telling you it is not getting enough water. Could be your water pressure is low. Check to make sure the there is not a build up of grime, or calcium deposits in the water hose, and at the valve.
The other thing is if your unit is an older one, prior to mar 07, you may have broken wires in the door. Remove the door panel and look for any wires that are stuck in the insulation. The sensor wires are thin and gray in colour. Splice the wires and put some of the white insulation in between the wires and the door so it cannot happen again.
Broken wires can be hard to find if the break is not all the way through.
Sgt Lauder
May 11, 2008 | LG LDF6810 Built-in Dishwasher
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
2,610 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
