Question about HP LaserJet 1320 Printer
Hi there my printer is not working, everything is connected
Everything is connected but printer is not printing at all.
  • 40 Answers
Does your computer recognize the printer? Did you select the right printer under the printer Name? What error messages do you get if any? Was the printer working before?
Basically, I need more info in order to better help you.
Posted on Dec 10, 2008
My printer won't print, it says it's disconnected but everything is plugged in. I rebooted my computer, unplugged everything and let it rest but it is still indicating "not connected"
So what is the connection ? USB or Wireless or Ethernet ?
Did you try connecting though other ports ? Connectivity, standard
  • 1 Hi-Speed USB 2.0
  • 1 Host USB
  • 1 Ethernet
  • 1 Wireless 802.11b/g/n
see wireless setup shown in the below video at 24.34 minute mark
HP Officejet Pro 8610 Unboxing Setup
Mar 16, 2016 | HP Officejet Pro 8610 Inkjet Multifunction...
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
How do i get my hp1200 printer to print, is on a off line mode
Hi Joy,
Disconnect the printer completely from the PC.Unplug its power cable too.
Reboot your PC.
Connect everything again from scratch but use a different USB port to connect to the PC.Make sure everything is well connected.Try printing now.Cant print?
Under printers and faxes,check whether 'work offline' is checked by right clicking on the printers icon and 'Uncheck.Still cant print?
Uninstall the printer driver on your PC,reboot the PC and install software again.If you don't have the installation disks,install from this Hp Support site making sure you select the driver that corresponds with your Operating System[Windows 7,Vista,Windows XP etc]
Hope this helps.Thanks!
Please rate this answer.
Dec 02, 2011 | Office Equipment & Supplies
After hitting print button,dialog box comes up printing, but there is nothing printing. Per control panel Printers & faxes everything is ok shows D2600 printer ready, per box item in que is printing
Hi there please try these.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Feb 03, 2011 | HP Color LaserJet 2600n Printer
My printer will not print.
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Hope this help. Please Rate My Response! Thanks!
PREM
Mar 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
I can no longer print to my Lexmark 6500.
hi.
if u dont have the cd,try the downloaded version from www.lexmark.com ..try connecting usb cable and check if printer works,,,if it does then its an issue with wireless connectivity..
good luck
Jan 25, 2009 | Lexmark Office Equipment & Supplies
I can not print when I connect to my jetdirect print server.
Hi, sorry for late answer, I have been offline for a while.
Connect RJ45 to router and parallel to computer
You need to download Software here first selecting 300x and windows version.
Then you can use the HP JetDirect Wireless Setup Wizard
to setup your printer on network.
You may also be required to install printer drivers, to do this use printer CD or download them from the Internet.
Regards
May 01, 2008 | HP JetDirect Print Server
Can not get printer to print
have you got the cable connected between Printer And Computer ?
or any on-screen error messages.
Check printers In My Computer/Control Panel to check the printing has not been Paused.
mike @ compurepair.
Feb 24, 2008 | HP Photosmart 4180 All-in-One Printer
HP LaserJet 1320 Printer Logo
Ben Johnson
