Question about SanDisk Sansa e260 MP3 Player
When i power on my mp3 player it goes to refresh database state and get hung.
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Dec 10, 2008
Can't get past "Refresh Database" Screen
Try taking it back to the shop.
If not go to
Jul 21, 2009 | SanDisk Sansa e260 MP3 Player
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Frozen sansa at refresh database
This is from the Sansa Website at
My e200 freezes on the “Refreshing Database” screen
STEP 1 – Reset the device
  1. Press the Power button and hold it for approximately 10 seconds.
  2. Release the Power button once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater
I this helps please dont forget to rate my answer.
Mar 07, 2009 | SanDisk Sansa c240 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
I would recommend that you get a firmware upgrade for the get the firmware upgrade just follow the link below...
Jan 30, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e200 mp3 player -hung
Hi , can you connect to pc computer for scan anti virus clean and heal viruses.
Jan 22, 2008 | SanDisk Sansa e200 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Refresh Database
Have you tired to re-set the e260 to factory settings?
Nov 10, 2007 | SanDisk Sansa e260 MP3 Player
Sansa e200r
my Sansa M200 has a frozen screen, tried removing battery but comes back screen frozen
Jan 04, 2007 | SanDisk Sansa e200 MP3 Player
Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
