Question about Sony DRU-820A DVD RW Dual Layer Burner
DVD - Slow burning speeds
I recently upgraded my cd burner to a dvd burner. The first 3 or 4 times I burned something, it was fine, then it suddenly slowed down and now it takes anywhere between 1 hour and 3 hours to burn something. I have searched the internet and tried pretty much everything. Everything is set to DMA. Any suggestions would be appreciated.
  • 944 Answers
Unlikely that there is a problem with the drive itself, most likely cause is software settings - which burning software are you using? if it is nero 6 then once you click burn after arranging the files for burning, the burn info page should pop up. click on the burn tab and make sure that "determine maximum speed" is checked and that write speed is set to maximum. hopefully this should solve it, if not try setting write speed to one of the slower settings listed and see if you get a better result. Sometimes dvd drives can slow right down when you are trying to push them to go at maximum. if you want to check what it should be able to do, try http://www.pcpro.co.uk/reviews/87363/sony-dru820a.html also worth trying is updating the drivers http://drivers.softpedia.com/get/FIRMWARE/Sony/Sony-DRU-820A-10b.shtml to make sure you have the most recent version. Another thing worth trying if you haven't already is try a different brand or type of disc - just occasionally there can be clashes with certain types and burners - if this seems to solve it, don't throw your pack of discs away, give them to someone with a different burner. The final possibility is a power supply problem. If your PC's power supply unit has spare connectors for a drive then try a different one - possibly your supply doesn't have enough guts to run a more modern drive - take the drive out and try it in another pc with a higher power supply wattage rating. Hope this helps :)
Posted on Feb 28, 2007
I have one problem,my dvd burner can writes any song or movie to the cd,but when i wan to write on the dvd the dvd burner cant write it,how i wan to solve it.
Posted on Jul 13, 2008
DVD wont burn with dvd maker gets to 99% then stops
HI THERE,
When was the last time it was working fine?
• Do you have any third party CDDVD burning software?
• Are you able to burn DVD's using windows explorer?
First I would suggest that you try burning using another DVD and check if it works.
Method 1
Try one or more of the following:
Verify that the DVD burner is connected properly to your computer and powered on, and that any necessary software drivers for the DVD burner are installed. You can check your hardware settings in the Device Manager by doing the following:
1. Click Start, and then click Control Panel.
2. Click Hardware and Sound.
3. Click Device Manager.
• Make sure that the videos you're trying to burn are not corrupted. To see whether the videos you want to burn is corrupted, try playing or viewing them using Windows Media Player. If the files don't play using the Player, Windows DVD Maker cannot burn them.
• Choose a slower burning speed for your DVD burner by doing the following:
1. Return to the Add pictures and video to the DVD page, and then click Options.
2. In the DVD burner speed box, select Medium or Slow.
Troubleshoot problems with creating a DVD-Video using Windows DVD Maker
http://windows.microsoft.com/en-us/windows-vista/Troubleshoot-problems-with-creating-a-DVD-Video-using-Windows-DVD-Maker
Change Windows DVD Maker DVD-Video settings
http://windows.microsoft.com/en-US/windows-vista/Change-Windows-DVD-Maker-DVD-Video-settings
Method 2
Check if you are able to burn DVD successfully using Windows Explorer.
Burn a CD or DVD
http://windows.microsoft.com/en-US/windows-vista/Burn-a-CD-or-DVD
Method 3
Check in the event viewer to know the cause of the DVD burning failure and post back with the details.
What information appears in event logs? (Event Viewer)
http://windows.microsoft.com/en-US/windows-vista/What-information-appears-in-event-logs-Event-Viewer
Hope this helps!
Halima S - Microsoft Support.
Visit our Microsoft Answers Feedback Forum and let us know what you think.
Aug 25, 2011 | Compaq Computers & Internet
When i clicked on burn cd..there is a window that says burning up top on the left corner and status:preparing....progress: 0%....elapsed time: 02:19:38....remaining time:--:--:--....is there an issue with...
1. some burners only like certain DVD disk and some only will burn at a certain speed
2. the burner may be in need of repair
3. check the users manual for troubleshooting and see if you have done something incorrectly.
Mar 13, 2011 | LG GP08NU20 DVD±RW Burner
I want to know how to speed up the burning process.
To speed up the burning process, you have to buy a cd or dvd which has the maximum speed. When burning you can set the burning speed by changing to maximum speed this will automatically detect the speed of your cdrom disc. Example for cd 52x and for the dvd 16x, another way is to upgrade your system ram memory by adding or replacing your memory or ram with a higher memory or capacity. Have a nice day
Feb 22, 2011 | Acard Technology (ARS-2030LD) DVD±RW...
My dvdr/rw wont burn dvds properly
There are many reason for this.Try following steps to look out for solution.
1>Use better quality Dvd to burn .DVDs are just a few cents worth of plastic, manufactured in massive quantities. Sometimes you end up with a bad disk or a bad batch. Try a new disk, or a whole new brand, and you may have more luck burning your DVDs
2>Dust in your DVD burner can prevent it from burning DVDs correctly. Buy a lens cleaning disk and use it in your DVD burner drive. This can clean things up and give you a clean, successful burn.
3>For better quality burn at slow speed.It’s always tempting to burn DVDs at the highest speed possible. In theory, you’ll save time and can get more DVDs burned. In practice, though, higher speeds can result in unreliable burns.
Slow things down and set your DVDs to burn at 4x or even 2x. This may eliminate errors.
I hope this will solve your problem.
Mar 22, 2010 | Computers & Internet
Low burn speed
I had the same problem before upgrading my RAM. Seems video burning software like nero are RAM hogs; if you do not have a large amount of RAM then it slowers the burning speed down to a crawl.[ BTW I didn't get maximum burning speeds using nero on a Windows Vista computer until I upgraded to 2 GB RAM] Hope this helps & please remember to rate my answer.
Dec 31, 2008 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
Dvd writer problem
taking too many time to burn a dvd movies and all others dvd disc.
Mar 24, 2008 | LG GSA-H42N 18x DVD RW DL IDE Drive...
Couldn't format and burn the DVD+RW
It could be a problem of the version you are using with Nero 7, try upgrading. It also could be that you are try to burn the DVD RW at a speed it cannot be burned (say 4x), try burning it at 2x.
Hope this works!
Feb 18, 2008 | KHypermedia (KDVRW8X) (20730176) DVD+RW...
Slow Writer
Hey there dhruvr, your problem is minor. Even though your DVD drive has max speed of 16X, the software you use to burn can vary this according to their default setting. ranging from 4-16 times. You can change these by opening the extra option boxes, when you are burning, or going into the settings for each of your burning programs. You should only have to do this once. It will remember your last setting. Good Luck!
Jan 31, 2008 | Lite On Lite-On SHM-165H6S DVD+R/RW -R/RW...
Philips dvd burn not burning?
1. see to it that you have set your burning software to write to the disk.
2. try to use it on a cd, if it finishes the job, something is wron with your dvd drive.
3. make sure that the drive you have is really a dvddrive and not a cd drive.
4. upgrade youe burning software.
Jan 05, 2008 | Philips (JR4DVDRWK/00) DVD+RW Burner
Sony DRU-820A DVD RW Dual Layer Burner Logo
271 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
