Question about Brother MFC 7420 All-In-One Laser Printer
I have a Brother MFC 7420 with a bad paper jam in the back
It says open the back door and I can't get it open. I don't want to force it and break it and run into the same problems some of the others are facing. I can't seem to pull the paper through from the front after removing the drum and all. From the picture in the manual it looks like it should just swing open but it doesn't, it seems hooked on something. Help Help I need a white knight.
    Champion:
  • 320 Answers
White knight to the rescue. the back door is quitew tight to open. pull it open with a firm **** of the hand.there you will see the paper jam. pull the paper out slowly as not to break the paper sensor in the back. let me know how it went. brother tech
Posted on Jan 13, 2009
Paper jams brother mfc 7420
Paper Jams are routinely caused by bad roller in the printer. The Heat of laser printers can render these rubber roller pretty useless in a couple of years or less if you print often. If you have recently replaced the drum (according to the recommended print output number), Then If an $80 dollar roller + labor is worth it to you, go for it, otherwise buy a new printer and Brother gives the best ink value per page. hope this helps.
Jan 28, 2013 | Brother MFC 7420 All-In-One Laser Printer
I have a paper jam in my MFC -7420. I removed a sheet from the back but there is more stuck in the front. The message says to open front cover and remove drum. I have opened the front cover but...
Don't try to remove the drum by itself while it's still in the machine,
just simply remove the drum and toner cartridge together.
There is no lock you should just be able to pull the cartridge out.
Jun 09, 2011 | Brother MFC 7420 All-In-One Laser Printer
PAPER JAM MESSAGE APPEARS WHEN THERE IS NO PAPER JAM
Please follow the directions below to clear the paper jam error orincase there is one somewhere.
Turn off the Printer. Remove the drum and toner from the front cover. Remove the toner from the drum. Look inside machine incase of possible paper jam. Open back cover and paper tray incase of jam. Close all doors and put toner and drum back in machine. Turn on the printer, and see if the error message is gone.
Apr 04, 2010 | Brother MFC 7420 All-In-One Laser Printer
Brothers MFC 7420 keeps displaying Back Door Open. Have cleaned etc. everything suggested on help websites, nothing works. Help coxmwc@aol.com
The back door is a double door. Inside the gray door is a black plastic paper guide that hinges down, also. Mounted on the inside of that is a thin, black rod, leading to a lever on your right, that swings through a slot in the side of the machine. Sometimes the lever gets bent so it doesn't fit into that curved slot. If that's your situation, gently force it back into the slot so it can block the sensor that tells it the back door is closed, and you'll be printing again.
Nov 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
Back door open
Inside the back door is a black plastic guide, in the center there's a lever that moves when paper goes thru, on the right is a flag that needs to be in between the horseshoe shaped sensor on the right. Make sure the lever moves freely...
Oct 02, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 keeps saying - back cover open - close thre back cover? How do I reset the printer orf find the underlying fault?
First be sure you close the back cover and remove all the jammed paper. after that, turn off your printer for 1 min to see is it okie.
Jun 10, 2009 | Brother MFC 7420 All-In-One Laser Printer
My MFC-7420 jams paper after each copy what is the problem.
First you need to clean up the drum and inside the printer.
after that if still jamming paper.
you better check all the rollers and check the drum unit.
if possible, please chang the drum and that should be working fine.
May 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Message on brother MFC7420 "back door open" when it's not
Actually, you need to double check the back cover and front cover, open them all to check all paper jam.
Besure to check the back cover, normally all paper jam is from the back.
be sure to close the front cover at the last cover to close.
Apr 01, 2009 | Brother MFC 7420 All-In-One Laser Printer
''Back door open, please close back door'' - back door is closed
This Error Is Reoccurring On All These Units Open Close Back Door Then Unplug For 30 Seconds And Then Plug It Back In. Check For Error.
The Brother Website Says To Check The Paper But Almost All Of These People Have Checked For Paper Problems And For Jams With No Result.
Jan 14, 2009 | Brother MFC 7420 All-In-One Laser Printer
Brother MFC 7420 All-In-One Laser Printer Logo
174 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
